Results 1 to 23 of 23
    Active Member Two Rings audic7s6's Avatar
    Apr 06 2016
    2013 Audi s6, 2014 Bmw 328 sports wagon, 2016 lexus gx460
    nj
    Any problems with wheel spacers on an S6.
    Has anyone ran into any problems after installing wheel spacers, on a lowered S6? I have lowering links and thinking about installing 12mm all around. Want to make sure there are no issues. Thanks
    2013 Audi S6. APR stage I, AWE touring exhaust, AWE intake, airmatic lowering links, Eurogear CF front spoiler, Eurogear rear valance, black optic wheels.
    Jun 18 2011
    markham, ontario
    Quote Originally Posted by audic7s6 View Post
    I've done 12mm all around, HR spacers with RAD 2-piece bolts, no issues with rubbing on lowered (via VCDS) S6. 12mm is quite conservative, there is more room, but sufficient for my taste.
    However, existing issues tend to amplify with spacers. I had pretty bad vibration issues and had to repair 3 bent wheels. This significantly improved the ride but there was still some slight vibrations/NVH that I couldn't eliminate even with Roadforce balancing. I then changed to Michelin PSS from the P-Zeros and I'm finally completely 100% happy.
    To summarize, get high-quality spacers and bolts, balance your wheels and pray nothing else pops up!
    23 BMW X3 M Competition Brookyn Grey, 17 Golf 1.8 TSI Pure White
    -Traded-in-
    19 RS3 2.5T Nardo Grey, 18 Golf R DSG Indium Grey, 13 S6 4.0T DSG Phantom Black, 11 Golf 2.0TDI DSG Candy White, 11 S4 3.0T S-tronic Ibis White, 10 Q5 3.2FSI 6A Ibis White, 01 Golf GLS 1.8T 4A Black, 06 A3 2.0T DSG 6A Brilliant Black, 04 A4 1.8TQMS 6M Ocean Blue, 00 A4 1.8TQMS 5M Light Silver, 99 Golf GL 2.0 5M Candy White
    Veteran Member Three Rings Bassler's Avatar
    Apr 17 2016
    '14 S6, '18 XC90, '19 Raptor
    North Shore, MA
    I jsut ordered 15mm ECS spacers and airmatic evo lowering links, should have both installed within a week or so. will report back if you've still not made your decision. from everything i've found, you can go up to 20mm without rubbing.
    2014 S6 Prestige DD/Kid Hauler | Glacier White, Lunar Silver & Aluminum/Black Wood | Black Optic | DA / Innovation / B&O
    APR DPs | Milltek resonated Valvesonic | EPL Stage 2 ECU/TCU | RocEuro | Forgeline 21s | Eurocode sways/links/AK/inserts | RS6 grill | Deval diffuser | XPEL/Opti/35% Llumar
    Veteran Member Three Rings MVcycleart's Avatar
    Feb 03 2013
    B7 S4 Avant - SOLD:C7.5 S6 - SOLD:B8.5 S4 - SOLD:B9 RS5 SB
    Gainesville, VA
    I have 15mm spacers, dropped with the VAG 17mm and i only run into rubbing when turning downhill then going uphill right away. Nothing major.
    B7 RS4 Avant Clone - Complete conversion with all the fixings
    Other: 2015 Mclaren 650S Spider: MSO, Akra, HRE, Velocity Tune
    2004 MV Agusta F4 1000S
    PAST - B7 S4 Avant, B9 RS5 SB, C7.5 S6, B8.5 S4, E-tron SB
    Get busy living, or get busy dying!
    Apr 06 2016
    nj
    Thanks. I would love to see photos
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Summer setup
    Wheels: Audi RS6 replica, 20" x 9", 47mm Offset
    Tires: 275/35ZR-20 Michelin Pilot Super Sport XL (102Y)
    ​Spacers: 5mm H&R on all 4
    VAG lowered
    Winter setup:
    Wheels: Audi OEM S6 20" x 8.5", 45mm Offset
    Tires: 255/35R-20 Bridgestone Blizzak LM-32 XL (97H)
    ​Spacers: 15mm H&R on all 4
    VAG lowered
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings Bpaman's Avatar
    Mar 25 2010
    FL
    Quote Originally Posted by S4Per View Post
    Summer setup
    VAG lowered
    Winter setup:
    VAG lowered
    That looks amazing. I'm thinking of going with a 20x9.5 wheel at et 40, a 275/30 tire, and lowered with H&R Springs. Based on the information of above I think I should be good, and probably should not use spacers. Does any body have any thoughts on this set up?
    Current: 2012 A6 Premium Plus, RS Grille, Sport package, Advanced Key, Phantom Black, H&R Springs, Niche Misanos, 20x9 et 32 on 255/35/20's
    Gone :2013 A5 6MT Glacier White, Premium Plus, Sport Package, Advanced Key, Chestnut Brown int. 20% tint, H&R OE Springs.
    Gone:2010 A5 Brilliant Black Premium Plus, 6spd, 20% tint, Hartmann HRS4 - 252-HS 20x9's on Falken 255 30, H&R OE Springs.
    Feb 17 2004
    2013 Audi S6
    One minor note: I did remove the fender liner screws up front (near top center of wheel well), that really do nothing at all (I did the same on my RS4). No rubbing since doing that, even when pushing it hard in the corners. Was getting occasional rub prior.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Good Intel. I might need to do that on mine.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Apr 17 2016
    North Shore, MA
    that is a very well done setup and a thing of beauty, thanks for sharing! notes taken for my summer setup next year...
    How do you like the Blizzaks? Have you run other snows in that sizing? I'm going to pick up my set soon, waffling between the Blizzaks and the Dunlop 3Ds (and wondering if anything new is coming out this year, suppose i need to research more). I have Hakka R2s on my STi but feel like i want something more all around than ice grippy on the S6.
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by Bpaman View Post
    You should be good to go. That is about perfect IMO. I am running 265/35/20 on 9.5" with 39mm offset. 275/30 with the slightly shorter sidewall will work just fine.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Apr 06 2016
    nj
    Quote Originally Posted by Bassler View Post
    Have you installed this yet? I would love to know the outcome. Any issues?
    Feb 17 2004
    2013 Audi S6
    I've had Blizzaks on my last 3 cars and haven't looked back. Love 'em and see no need to switch / look for others.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Apr 17 2016
    North Shore, MA
    Not yet, Saturday I think. I did a 15mm vagcom drop for now so I'm holding off on the links for now. It begs for spacers though and I wonder if I'll want to go to 20s.
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    how have the spacers held up to high speeds like 130+mph?
    SOLD:2017 S6 Mythos Black Arras Red interior all the Wayne tech gadgets, RocEuro, EPL stage 1, 15mm front/20mm rear spacers, Eurocode Sways, end links, billet mounts ALL
    American enjoying the autobahn
    Jun 07 2016
    Europe
    Quote Originally Posted by fatherdeath View Post
    I drove 300km/h with ecs 12,5 rear and 5mm front, no problems. What i don't like that in the front spacers make steering heavier.
    Jul 20 2016
    Tampa, FL
    ok good to hear im on back stadt roads for the last week, but going to munchen next week and i only travel 150kmph or more
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    5mm amazon spacers with no issues
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Apr 17 2016
    North Shore, MA
    15mms, no issues to 127mph at least
    Sent from my SM-G930V using Tapatalk
    Sep 10 2015
    VA
    I run 20mm front and back on summer wheels. No rubbing issues upto yet.
    Veteran Member Three Rings AdrianLee's Avatar
    Jul 19 2011
    2016 A7 3.0T & 2016 Q5 3.0T (Wife's Daily)
    SW Michigan
    The only problem you'll run into is if you buy spacers that aren't hubcentric. I tried putting 5mm spacers that weren't hubcentric on mine for winter, and it caused the center of the wheel to not sit on the hub as designed. I have 10mm H&R spacers that are though and there have been no issues. Hope this helps
    C7.5 A7, APR Stage 2, APR Heat Exchanger, Fluidamper, AWE Exhaust, Eurocode Swaybars, RS7 Airbox, Trans Tune
    Feb 25 2014
    Texas
    EDIT: found answers
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Apr 15 2007
    WNC
    For a 2014 S6 on the 5 arm rotors what kind of spacer would get me flush without rubbing if I dont want to lower the vehicle at all?
    2013 RS5, 2014 Q7
