Results 1 to 7 of 7
    Junior Member Two Rings
    Nov 01 2013
    Radiator fan turns on when car is off
    Came out of the gym and heard a noise but didnt sound like my car so i didnt bother to worry. Got home in the garage left car for 30 min and come by and the radiator fan is running. Started the car for a bit the turned it off and fan turned on again about 1 min after the key was out. Key goes in and not full startup, fan turns off. Pulled the fuse so it doesnt run over night. Played with it for a bit and for the most part its on again ina min, but another time it was 10 min.
    Solution??
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Did you check your coolant temperature?
    Probably the fans thermostat (relay switch) is slowly giving in but just a wild guess, maybe nothing is wrong with the fans thermostat and your water is cooking due to a faulty pump thermostat?
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    I think venom is correct
    Nov 01 2013
    I drove it last night to see if it is drivable and all temps were fine. Everything seems good other then the fan turning on. Ibtried to open up the ecu box but it has the one screw that needs a flexable bit. But it looked dry from what i can see. Is that where the relays are? Or are they under the dash? Some other posts point to the fan control module on the radiator, bot sure how to test if its that or not.
    Nov 01 2013
    Update today
    Drove the car and the fan didnt appear to turn on at all. Temps never got over 100. So im a little concerned about that. Ca.e home tonight and started the car and fan started right away....
    More ideas? Gotta be the control module i'd think.
    Also worth noting that it hasnt turned on again after the key is out.
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    I reckon a faulty fan control module is the best bet.
    Nov 01 2013
    Been 3 days and the problem hasnt reoccured. Maybe some water snuck into a connector or maybe i have some electrical part on the way out and is just fine right now. Either way car is running great.
    Got a new golf r on order to either replace the rs4 or join it in the garage, depending if i get the money i want for it.
