Results 1 to 7 of 7
    Aug 11 2012
    Beaufort, SC
    HELP! I think I blew a fuse
    So I went to SoWo's European Experience out in Savannah, GA this past weekend and picked up a couple of things from the vendors. Among those were led interior lights from USP Motorsports.
    Now here is where I need your help. I installed led interior lights from USP motorsports in my A4 and all except the glove box light worked and turned on properly after installion. I noticed the pack I purchased had 2 spares and I tried to remove the glove box light which wasn't working to replace with one of the others and I think I may have shorted something out or blew a fuse when removing the non working led. I removed the led but now none of the interior lights turn on at all (dome, vanity, etc). I also changed the puddle lights to LEDs from halogen bulbs and they seem to still work fine. Radio turns on as well. However it feels like the power steering is out because I literally have to muscle the steering wheel to get it to turn and the horn doesn't work now.
    Does anyone know what may be the cause for this? And if so how can I fix it?
    Thanks in advance for any help and/or info you provide.
    -Jeff
    Established Member Two Rings inv3rtig0's Avatar
    Oct 22 2014
    1976 Toyota Celica GT
    Paso Robles, CA
    Pretty sure its fuse #7. Search around the LED thread and you'll find your answer.
    2010 A4 Quattro Prestige 6MT S-line | build thread
    Revo stage 2 | 034 HFC | AWE Quad exhaust + downpipe | 034 trans mount insert | interior LEDs | ECS short throw shifter
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    I did the same thing changing out that stupid glove box light to LEDs as well.. same things out... definitely think it's fuse number 7
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Aug 11 2012
    Beaufort, SC
    Quote Originally Posted by hyperunion View Post
    Thanks for the responses. Hyper, what did you end up doing to fix it?
    Aug 11 2012
    Beaufort, SC
    Ok found the fuse panel. Trying to get the pick plastic cover off of the red fuse box to get to the individual fuses. Seems kind of hard to do without breaking the damn thing
    Feb 24 2013
    CA
    Quote Originally Posted by Mod.Kill.Yut. View Post
    Weakling lol
    Aug 11 2012
    Beaufort, SC
    Quote Originally Posted by Slick_B8 View Post
    Weakling lol
    Lol haha I was being delicate because Audi tabs love breaking. Ended up just said screw and pulled until it gave according to the manual it isn't necessary anyway. Fuse 7 from the top was the culprit as the other guys mentioned.
    Now that I already have the fuse panel off might as well install my p3 vidi boost gauge
