Results 1 to 11 of 11
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Thickness of spacer between center support bearing and vehicle?
    To try and fix a clunk and vibration i Picked up a used driveshaft then replaced enter bearing. Also replaced cv joints/.boots with gkn brand parts. Then brought the driveshaft to a local shop and had it ballanced.
    Today installed the driveshaft to find out that between the center support bearing and the body of car wasnuts instead of a spacer. Used some hardend washers to mock up the nuts thickness.
    After install the car vibrates worse then it did before so im thinking the thickness is off and the allighnmemt of the shaft is no good.
    Any clue on what thickness the missing spacers are? Or different each car?
    Jul 04 2012
    Woodbridge, VA
    Assuming you got the center support from 034?
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    I'd venture a guess at 10-15mm. I had them in my hand somewhat recently so a guess is all I have
    Aug 04 2014
    Gloucester MA USA
    Yes i wnet with 034, blauparts dont sorce the bearing anymore and 034 is all i could find
    Thanks zba!
    I need eaxact measurements or a used set of spacers if possible by some one parting out a car or something.
    Nov 03 2011
    All Over!
    20X10X4mm.
    1986 Type 85 Audi 90 quattro
    Aug 04 2014
    Gloucester MA USA
    Where did you get dimmensnions from?
    And thats 20mm as od, 10mm as thickness? And 4mm from id to od? The screw is a 8mm so the id hole cant be 4mm and no way thickness is only 4mm
    Nov 03 2011
    All Over!
    Quote Originally Posted by f4m0u5 View Post
    Those are the correct dimensions. I purchased a couple from Audi for my own car, and those are the measurements.
    Nov 03 2011
    All Over!
    My mistake, I was looking at the wrong invoice.
    Dimensions: 20X10X8
    Part number: 857521143C
    Feb 27 2011
    Winnipeg
    I've got 2 spacers since I converted to a single piece shaft, can throw them in an envelope for postage if you want them PM me.
    Aug 04 2014
    Gloucester MA USA
    Ok thanks guys! I just bumped a old thread regarding the driveshaft and bearing shims. According to the bentley suposivly you measure the gap and use a different size shim.(and he was sayong to go smaller shim when in reality youd want to go bigger to take up for gravity dropping shaft?) Or does the reasoning have nothing to do with gravity droping the shaft after removing tool?
    So is there realy just a part number or is it going to be different per car / support bearing?
    Aug 04 2014
    Gloucester MA USA
    Just looked up part number. They have one for letters for each thickness . Bis 6mm C is 8mm d is 10mm
