Results 1 to 40 of 66
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Cool Supercharger Porting/Polishing
    Looking for lower IAT's, 20+ whp and more efficiency from your super charger? I have a proven solution! Porting and polishing the blower case and snout correctly will not only pick up power, but make your engine more efficient at moving air, which in turn will lower IAT's and boost pressure while making more power.
    Unfortunately a core swap option (less down time) will not work due to variance in mileage. You will ship your blower/snout/throttle body to me for the porting/polishing and I will ship it back to you (with tracking) once finished. It will be disassembled, ported, polished, cleaned, reassembled and filled with new oem oil.
    I would estimate a 2 week turnaround time considering there will be shipping to and from.
    Pm for pricing and any questions!
    Will
    *Update*
    I will now be including porting/polishing of the throttle body with my supercharger service at no additional cost ($180 value) going forward. If you've already had your s/c done I will do the tb free of charge if you cover shipping.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Nov 28 2015
    Montreal, QC
    any thread in the s4 section that prove all these claims ? pretty curious about it, seems like no one ever thought about it before !
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by waxxonMTL View Post
    No unfortunately there's only one other person that I'm aware of that ported his blower on the s4 platform. It's been done on a lot of other platforms with great success...I picked up 45whp on my V😳
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Quote Originally Posted by BlownOne View Post
    Have you done your S4?
    Veteran Member Four Rings Black_Pearl_B6's Avatar
    Aug 11 2010
    Agawam Ma
    any pics of the port work
    09 Prestige Package
    Active Member Two Rings chuckhet's Avatar
    Jul 22 2013
    Rochester, NY
    I ported mine myself. I've ported dozens of CTSV/ZL1 blowers and decided to do my S4. There isn't nearly as much to be done inside the S4 blower as compared to the V blower but improvements can be made. There can't be nearly the gain as the V but I'm sure it helps. I did mine without before and after dyno results. Can't give any numbers to prove results but more air flow and less restriction = more power without a doubt. The more air flow before the blower will always gain power. If I had to put a number on it I would guess 15-25 awhp
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by B8 S4 View Post
    Yes I just recently did mine
    Quote Originally Posted by Black_Pearl_B6 View Post
    unfourtunatly I took pics, but cannot find them for the life of me. S4matty had some pics in his thread which looked very similar to mine.
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by chuckhet View Post
    There was less material in the s4 than the V case, but there was also a lot of dimples/pits in the casting that are smoothed out. I didn't dyno it either, but I'm with you on the 15-25whp gain so I went with 20whp to be in the middle. It definitely some easy power that's left on the table by most.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Awesome service to offer! I'd like to see the work. And hopefully, dyno results!
    Apr 27 2014
    United States
    Get some before and after dynos on the same dyno same day and I am sure other will be very interested if the results look good... including myself.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Apr 04 2015
    United States
    I'm also very interested.... but I would like to know an aprox cost too... its the age old ratio of cost vs. HP that would be the deciding factor for me.
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    I did notice a difference when I did mine..Great service to offer Will
    Sent from my SM-G900W8 using Tapatalk
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Pyromatic177 View Post
    Thanks! Hopefully I can find the pics, but worst case I will take more and post them.
    I'll try to get some dyno/track numbers, but there won't be same day results because of how much time it takes to port/polish, clean and put back together. It's already practically summer here in the valley so it will be hard to compare et/mph from my spring numbers. Once 034 releases their tunes and dyno numbers I could get on the rollers and compare numbers between my ported stage1 and non ported stage1.
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by rwtzero View Post
    The cost vs power ratio is definitely fair and better than most other mods on this platform. Trying to figure out cheapest/fastest shipping for such a heavy item is my current issue.
    Quote Originally Posted by s4matty View Post
    Thanks brotha! It definitely makes a noticeable difference...I was always wondering why nobody offered this service.
    Jun 12 2015
    CA
    PM'd
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by colby7 View Post
    PM'd
    Good talking with you brotha!
    Dec 30 2015
    Sacramento, Ca
    Updated with bold on exactly what's included in the service.
    Jul 30 2010
    Los Angeles, CA, 90094
    Interested. Pm'd!
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Goodforyou19 View Post
    Interested. Pm'd!
    Got it! Replied😎
    Feb 20 2013
    San Jose
    Interested, I can drop off/pick up. Pm quote if that is OK. Thx
    Dec 30 2015
    Sacramento, Ca
    All pm's replied to!
    - - - Updated - - -
    Quote Originally Posted by DigitalB85 View Post
    That works just fine...pm coming your way!
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Very interested. I too could drop off/pick up, I'm not far from you. Could you pm me the info?
    Sent from my SM-G925V using Audizine mobile app
    Oct 20 2014
    United States
    Pm'd. But forgot to ask the question of tuning. Would a custom tune be needed to accommodate for the increase in air?
    Current: 2013 Audi A4
    Sold:
    2015 F83 BMW M4 OEM + (Lots done but not too much lol)
    2014 Phatom Black S4
    Mods:| Unitronic Stage 2 | 19x10 Rotiform Ind-T Chrome stepped lip with brushed Aluminum faces | Avery "Dark Grey Gloss" vinyl | Airlift Performance Bags | Autopilot v2 | 5% tint, APR Stage I + II Intake | Carbon Fiber J-Codes | AK | USS system | Miesterwerk SS | Deval Front Lip | AWE Non-Res DP's | AWE Track Exhaust |
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by ModItNow View Post
    PM headed your way.
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by treejs4 View Post
    Got it and replied! No tuning necessary, the ECU will adjust the target AFR via wideband.
    Mar 05 2015
    Exway x1 pro
    Bay Area
    PM headed your way.
    Gracias sir!
    Sent from my SM-G925V using Tapatalk
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    You mention no core swap, what about an entire unit? I'd happily buy a spare sc.
    Veteran Member Three Rings Jcam14's Avatar
    Aug 17 2013
    fully built 1998 Camaro SS/ 2000 Silverado RCSB/ 2000 Camaro SS
    Tucson, Arizona
    super interested........ I'm just wanting to see results from a dyno and some pics of the work. maybe a before and after pic....
    2015 White S4/Lowered/034 CAI/034 STG 2 Tune/034 Upper & Lower Crank pulleys/19" Peelers/Black Leather with brown inserts/full CF inlays/Full LED interior lights/ Prem+
    Aug 06 2014
    California
    interested pm me info. could possibly drop off and pick up as well
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by OnEaNgRyBuNnY View Post
    That's fine by me...it just doesn't work to do a ready to go core as everyone's mileage will vary.
    Quote Originally Posted by Jcam14 View Post
    I've been super busy, but I'm working on getting some before/after gains be it dyno or track. Summer is upon us here in the valley🔥
    Quote Originally Posted by Michaelds4 View Post
    Ok headed your way! Perfect👍🏼
    May 17 2012
    Houston, TX
    Easy to get dyno numbers... Dyno your car then another sim car without the port/polish. Problem solved. May have slight variation because not same EXACT CSR but still something to use. Def worth doing if you expect to do a bunch of these.
    Dec 30 2015
    Sacramento, Ca
    That's the idea, however 034 hasn't released their software numbers as of yet. Going to the track in decent weather is my next best idea, but there will be a variation from my spring numbers since its 30* hotter, plus I will be stage 2 now. Trust me, I'm working on a solution to show actual before/after gains on the same car, in the same weather.
    Will
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    Will
    Waiting for dyno #'s to prove the claims then I'll PM you ;-)
    double thumbin' it!
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by quietcropduster View Post
    double thumbin' it!
    Sounds good...dyno numbers should be coming soon!
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    I'll be waiting on those numbers as well... Sounds super interesting..
    Established Member Two Rings Phoneycutt04's Avatar
    Jun 21 2016
    Wichita, Kansas
    What's the price?
    Apr 04 2015
    United States
    Your PM box is full.
    price please
    zip code 12065
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Phoneycutt04 View Post
    What's the price?
    Pm headed your way!
    price please
    zip code 12065
    Cleared my inbox and pm'd you!
    Dec 30 2015
    Sacramento, Ca
    *Update*
    Will
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    *Update*
    Will
    Any reviews yet?
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
