Results 1 to 15 of 15
Thread: taillights
    Active Member One Ring Sonicteam120's Avatar
    Apr 27 2016
    Bronx /Coram NY
    taillights
    are the sedan and avant taillights the same ?
    Feb 24 2013
    CA
    No, they are very different from what i understand.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    They are not the same. Similar on pre-fl IIRC, but the difference on 2013-16 is huge.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Feb 24 2013
    CA
    Quote Originally Posted by jmeenach View Post
    Nope even on the pre facelift, they dont interchange between each other unfortunately
    Apr 27 2016
    Bronx /Coram NY
    thanks a lot
    Apr 27 2016
    Bronx /Coram NY
    how about headlights
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by Sonicteam120 View Post
    Those should be the same. The difference there will be Halogen vs. HID and AFS vs. non-AFS
    instagram
    Apr 27 2016
    Bronx /Coram NY
    I'm new to audi so what you mean afs and non afs
    Apr 27 2016
    Bronx /Coram NY
    Aug 06 2012
    Parker, CO
    AFS = Adaptive. They turn to the left and right when turning above a certain speed (15mph???)
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    I would say if you are willing to drop $500 into the above lights go ahead and add $150-250 to the cost of the above headlights and get you a set of factory LED headlights. I have seen factory housings without the HID bulbs go for around $600.
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    Apr 27 2016
    Bronx /Coram NY
    Quote Originally Posted by B7AudiSline View Post
    where @ on ebay
    Jul 14 2012
    Eastern Shore,MD
    where @ on ebay
    I would check the Audizine classifieds and Ebay until you find a set.
    Jul 14 2012
    Eastern Shore,MD
    You could also call around to different salvage yards and try to locate a set.
    Feb 24 2013
    CA
    Wait for my review ill be posting up in s few days. :)
