Page 1 of 5 123 ... LastLast
Results 1 to 40 of 164
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    adam's rotors inc. | customizable, made-to-order, plug n' play rotors for your Q5!
    BUILD YOUR CUSTOM ORDER | MACHINE PATTERN, ZINC FINISH, HUB COATING, METALLURGY, & BRAKE PAD/STAINLESS STEEL LINE/FLUID PKGS.
    WWW.ADAMSROTORS.COM
    adam's rotors inc. started out small and remains that way...a tight knit, self-owned & operated company established & going strong since 2006.
    the small outfit and one-on-one interaction creates only the best service w/quick response & even faster made-to-order set-ups. with top notch products, this lends hand to our success thus far.
    working 24/7 throughout the day, any and all questions are answered within the hour to the best of our ability, if not instantly.
    being an online company we do business direct via email, instant message, PM, and over the web in our ever growing threads...we're always here ready to reply!
    we are a fully made-to-order, replacement disc brake, rotor manufacturer...we offer only factory fit, OE spec, plug n' play discs.
    WE CATER TO THE CAR ENTHUSIAST WHO NOT ONLY NEEDS NEW BRAKE ROTORS, BUT WANTS SOMETHING DIFFERENT BEHIND A NICE SET OF WHEELS.
    be it looks or performance, adam's rotors is the only company to bring you over 20+ machine pattern variations (most of which are exclusive to AR), 3 zinc finish offerings, and 5 ceramic-silica hub coating options.
    YOU PICK, WHAT YOU WANT AT AN ALL-INCLUSIVE PRICE | COMPLIMENTARY CORROSION PREVENTION, FREE SHIPPING, CHOICE OF DRILLING, SLOTTING, AND/OR DIMPLING, ALL LOADED INTO OUR WEBSTORE.
    adam's rotors expertise is in the VW/audi market, but do set-ups for ANY make/models car/truck/van…check to our store!
    WHY ADAM’S ROTORS? WE’RE DIFFERENT!
    because we do what no one else does. AR is a customizable product, having managed to turn a boring replacement product into something different. it's a have-it-your-way, made-to-order modification item ideal for any enthusiast. now, instead of just picking 1 of 1-3 drilled or slotted rotor styles from off-the-shelf inventory, we offer over 20+ patterns for your choice/taste, how YOU want them. after that pick a zinc for corrosion prevention...silver? gold? maybe black? thereafter you can even add one of our coated hub colors in a satin ceramic finish to finalize your set and truly give them polished, unique look. we now even offer upgraded metallurgy, to a stronger premium grade high carbon iron if you so wish. we at AR believe a rotor ISN'T just a plain ol' service part...rather a fun, custom, cool way to not only enhance the look of your car, but add performance, protection, and something different to your build, with a ton of bang for your buck!
    oh yeh...and they actually perform!!!
    track tested, endurance race team approved; check it out HERE.
    QUALITY, IT'S ALL IN THE DETAILS...
    we chamfer each drill hole and pay extreme attention to how we lay down our machining…taking meticulous measures to avoid each and every vent rib; the internal cooling veins in most modern vented brake rotors. AR will not drill a rotor we are unable to do so with and thus unlike most, never have issues. this is another reason why unlike many, we also offer dimples and unique slot patterns, ways of avoiding this and offering better, longer lasting, quality products when we see possible issues with venting. lastly each set is made for YOU without the limitations of pattern & finish pre-made, “in stock”, off-the-shelf parts have. instead, we start each order upon payment & cater to your needs/wants for your car.
    HOW IT WORKS:these are customized by you & made per order; you'll have them in about 2-3 weeks...
    (this takes in account ordering raw material, ship time to the shop, pattern machining, zinc finishing, hub coating & curing, packaging, & shipment pick-up!)
    we hold NO inventory & are held to the same final sale terms as our policy.
    we make ONLY factory fit replacement rotors to OE spec. plug n' play original fitment.
    whatever one-off size you may be after other than what your car came with, will need to be based off another application's rotor that already exists.
    in some cases, we can open up hub bore and modify bolt-patterns (within reason) but we need to discuss via email, first.
    YOU TELL US HOW YOU WANT THEM!
    1. dimpled
    2. drilled
    3. slotted
    4. dimpled/slotted
    5. drilled/slotted
    6. dimple/dimple/slot
    7. drill/drill/slot
    8. AR race (exclusive double slot)
    9. AR street (exclusive double slot/drill)
    10. AR track (exclusive double slot/dimple)
    11. AR sport I (exclusive over-dimple)
    12. AR sport II (exclusive over-slot)
    13. AR speed (exclusive multi-slot)
    14. AR dift I (exclusive triple curve)
    15. AR drift II (exclusive triple curve/slot)
    16. AR drag I (exclusive cross-hatch/slot)
    17. AR drag II (exclusive cross-hatch/double slot)
    18. NEW: AR sport III (exclusive radial dimple)
    19. NEW: AR sport III (exclusive radial slot)
    20. NEW: AR hex (exclusive honeycomb w/radial slot inner face)
    silver zinc, for brilliant rust-free finish is STANDARD on all orders, is a corrosion prevention process/measure, BUT...
    *COLORED ZINC FINISH:
    gold zinc or black zinc finishes are a subtle, unique, aesthetic touch for your rotors, very few offer!
    also...
    *HUBS COATINGS:
    this gives the rotor a nice clean, tailored, finished look.
    the rotor is still standard silver zinc dipped, with a high temp, satin, ceramic-silica finish.
    available in 5 colors…we can do some custom colors, so let us know what you need/want.
    or
    *G4000 HIGH CARBON IRON METTALURGY UPGRADE:
    we have started to offer a premium grade cast iron option, available for most all applications.
    standard grade G3000 is great and more than sufficient for most any use, but in some scenario's, a stronger iron is beneficial.
    reports of longer lasting rotors have been found, ideal for high mileage cars, haulers, or even heavy track goers who really beat up their brakes.
    it also greatly reduces the worry of pad squeal in cases of high friction with high performance brake pads.
    the harder iron is stronger and fights warping and cracking concerns, and higher carbon & chromium levels aid in oxidation resistance.
    another great benefit to the G4000 upgrade, is the price includes a premium black coating on the rotor at no charge.
    WWW.ADAMSROTORS.COM
    ONE (1) YEAR exchange warranty for:
    manufacture defects (cracking) per rotor...on all orders!!!
    EVERY ORDERS IS FINAL-SALE, ONCE PROCESSED | NO EXCEPTIONS.
    again, we hold NO inventory & are held to the same final sale terms as our policy.
    if there is EVER any issue with fitment/error on OUR end, we will ALWAYS make it right!
    AR EXCLUSIVES-
    *NEW: AR sport III & IIII [radial dimple & radial slot] & AR hex [honeycomb w/radial slot inner face]:
    [must be ordered with coated hubs]
    AR drift I [triple curve] &
    AR drift II [triple curve/slot]:
    AR drag I [cross-hatch/slot] &
    AR drag II [cross-hatch/double slot]:
    coated hubs]
    AR sport I [over-dimple] &
    AR sport II [over-slot]:
    coated hubs]
    AR race [double slot] &
    AR street [double slot/drill]:
    coated hubs]
    AR speed [multi-slot] & AR track [double slot/dimple]:
    coated hubs]
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    AR braking BBK w/Track pattern rings: www.adamsrotors.com/BBK
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    bit more effort than plug and play lol!!
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Oct 26 2015
    Norman/OK
    This may be something I look at down the road.
    Quote Originally Posted by q5 dave View Post
    well the BBK is part of our AR braking division, as linked, but actually is very straight forward to install.
    it's an all-inclusive kit that does, bolt right up...other than bleeding brakes, it's essential the same exact process with all components included.
    Quote Originally Posted by TJay74 View Post
    let us know when you brakes are worn!
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    i think that's about as plug-n-play as it gets for a caliper swap haha.
    i wonder how much it costs to get a set of used RS5 brakes? Those would probably be similarly effective to any other BBK as it is an oem brembo 6 pot in the front
    sure, but would require a custom carrier be made...and then what rotor do you use?
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Quote Originally Posted by Adam@SPP View Post
    i would be surprised if the b8.5 hubs aren't all the same. Someone in this section is already running the RS brakes. could ask them
    you guys come to us with the conversion...if we can get the rotor, we're happy to help!
    AR pattern-match program | serving BBK owners w/rear rotor solutions | www.adamsrotors.com/PMP
    here's a set of Alcon/Stassis C-hook rears we did for a customer with a Big Brake Kit up front, who's been forced to run un-matched rears in the past...not with a custom F&R set-up!
    summer is here and it's HOT in California...this looks nice right now!
    would you like to see what other AR customer customer pick/run on their cars?
    we have an ongoing collection, broken down by pattern in the customer gallery of our website, HERE.
    if you are a fan of Facebook, we also have a very active daily wall feed of the like, to help inspire your future order!
    killer shot from a customer, sporting Neuspeed wheels over their AR Drag I's:
    working on new koozies that will feature our popular t-shirt design/logo.
    top quality 5mm thick scuba-grade neoprene w/hand stitched seams & rubber base. never drink a beer the same again!
    opening up your AR shipment is like Christmas no matter what time of year...
    sport II's:
    brandy-wine. new coating options coming soon...email us now if interested in pre-release:
    fall is here and it's cooling off...the rain has started and soon the winter months will be upon us.
    be prepared to weather the storm both on the road and inside & under your car with moisture, road grime, and rust.
    every set of AR leaves the shop silver zinc dipped, at no charge. it's a great way to help prevent corrosion & keep your rotors protected thru the ugly months...gold & black options too.
    we also offer a premium high-carbon metallurgy upgrade w/natural corrosion prevention properties in the iron along with a superior hub & vent coating!
    you can still look good & stop better w/adam's rotors:
    what a month that was...here's to the last one of 2016!!!
    Christmas presents that come in 4...you can't go wrong!
    custom machined to order, in house how you want them!
    -made-to-order, per customer, per corner
    -17+ CNC'd patterns
    -unique zinc finishes
    -custom hub coatings
    -chamfered dimples & drilling
    -double ground rotor faces
    -machine balanced discs
    -high carbon content metallurgy upgrade
    -premium one-to-one small business service
    factory fit brake rotors unlike anyone else!
    happy new year!
    a little insight on adam's passion project!
    with over 3 days of filming, everything you could possibly imagine go wrong, hard work, and months of editing, here is our full length, short film by Layer Media x adam's rotors inc.
    we're excited for everyone to see & let us know what you think.
    www.LayerMedia.com | @layermedia
    www.adamsrotors.com | @adamsrotors
    Established Member Two Rings alpineaudi's Avatar
    Aug 05 2016
    Nor Cal
    really well done!!! looks like the foothills - Calaveras County?
    2011 BBlack 3.2 Q5 S-Line (Traded in)
    2014 Glacier SQ5 (Crashed and Totaled by a Drunk while parked in front of my place)
    2016 Daytona SQ5
    south bay area...morgan hill/SJ; willow springs
    the new project is here:
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Awesome, enjoy it!! 4.0?
    nope, but already love (our first) the 3.0t and it's not even tuned yet.
    stumbled upon this photo from over 7 years ago, of a prototype pattern we did for an old school build, that was never released.
    ...should we bring it back to life?
    follow us on IG: @adamsrotors
    hope everyone had a great weekend!
    back to our roots! the adam's rotors D4 A8L:
    Dec 15 2016
    Russia
    Hello. I need a rotor for my Q5. Brembo BBK 380, part 2
    no problem....email our AR braking division for a quote!
    [email protected]
    what a busy couple weeks. the office is officially moved over and it's business as usual...enjoying the rest of the weekend!
    before and after of out brilliant silver zinc bath, complimentary (FREE!!!) on EVERY G3000 AR order placed!
    (sport II's | over-slot)
    how was everyone's memorial day weekend?
    the AR D4:
    it's the first day of summer but we've been feeling it here in the office for over 2 straight weeks of 100-110 degrees!!!
    working on a new website...v3.0 coming soon!
