Results 1 to 7 of 7
    Aug 29 2013
    Rockville, MD
    Intercooler hose keeps blowing off
    Hey guys,
    I've been having some issues with one of the intercooler hoses in my ECS tuning FMIC kit. The coupler in question is the second coupler that goes from the turbo into the hot side of the intercooler. The interesting thing is that none of the other couplers seems to be having this issue and I changed the clamp from a regular hose clamp to a t bolt clamp but it doesn't seem to have had any effect. After changing the clamp to a t bolt clamp I didn't have any problems for 5-6 months. Could this be a boost spike issue? I have a boost gauge and I can't see any spikes and the car doesn't go into limp mode. Is gradual failure of the n75 a thing? It does have a stage 2+ tune from motoza and after upgrading from the stock intercooler I actually got more boost and boost builds faster than before so I was thinking its probably not an issue with back pressure form the intercooler core. Any ideas?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Tighten the clamp and make sure its not binding, or being pulled/stressed in any way.
    2019 SQ5 Prestige
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Wipe down both your surfaces with some thinners/metho to get rid of any residual oil so you have a clean surface to join with, check your clamp isn't bottoming out also. I had a problematic inlet on the intercooler a while back, I ended up roughing both surfaces up with a little bit of sandpaper after cleaning with a solvent, bolted it back up and it's been perfect ever since.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Dec 05 2007
    ^That. Was just about to say the oil from the blow by is most likely causing the issue. Not a 100% certainty, but most plausible explanation. And after wiping the surface, use hair spray as like a glue between metal and rubber contact area. Very old school trick.
    Jun 29 2014
    America
    Make sure your mounts are fine. Excessive engine movement will pull the hoses apart no matter what clamp you use, particularly on FMIC kits that don't have S shaped hoses like stock, which can bend and stretch a great deal.
    Dec 18 2011
    Colorado Springs
    Remove coupler, clean, light sand w/ 500-800 grit, spray with hairspray upon reinstall, tighten clamps.
    Consider a hump coupler to allow more play if needed
    Aug 29 2013
    Rockville, MD
    wow thanks for all the advice guys, im not sure a hump coupler will work because the pipe has a slight bend in it. Will try scuffing and hair spray and report back.
