Results 1 to 20 of 20
    Buncha motorcycles
    Memphis, TN
    Apr stage 2-test pipe?
    Apr and dealer are telling me different things. One says I need downpipe but no test pipe other says just test pipe/hfc...
    Anyone run a test pipe with stock exhaust? I don't want this car as loud as my last one. Getting old.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Stage 2 requires at least an HFC. Test pipe is optional instead.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by Papachristou View Post
    APR's downpipe includes the HFC/testpipe portion. You only need the actual HFC/testpipe. The true downpipe section isn't needed, but APR sells it all as one piece.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    This should help clear it up.
    Buncha motorcycles
    Memphis, TN
    Great thanks. Will it be fairly quiet with just test pipe?
    - - - Updated - - -
    I'm trying to figure out if it's worth it to ceramic coat the test pipe.
    Apr 26 2014
    San Diego, CA
    Not at all. Go with an HFC.
    Veteran Member Three Rings PBKIDD24's Avatar
    Apr 30 2015
    Quote Originally Posted by adamazing View Post
    Even my HFC definitely increased the sound, but on the stock exhaust it shouldn't be too loud.
    2015 S4 P+ Daytona Grey Pearl Effect
    APR / Milltek / Bilstein / Eibach / 034Motorsports
    Build ThreadInstagramFlickr
    Past Cars: 2015 A4 Build Thread
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    i had my hfc on my stock exhaust and the sound did not change one bit. I was disappointed.
    Sent from my SM-G925W8 using Tapatalk
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
    Established Member Two Rings kiw1's Avatar
    Mar 29 2016
    2022 BMW X5
    Santa Monica, CA
    My testpipe didn't increase my sound that much. Its noticeable but not bad. You will notice the smell though although its not too bad.
    2012 A4 Avant - APR Stage 2, JHM FMIC, EuroCode Test Pipe, Front and Rear Sway Bars, Bilstein PSS10, CR15, ECS Turbo Inlet Hose, aFe, RS Front Grille
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    What smell, I've never had that issue I swear people just say that.
    Feb 04 2016
    Ontario,canada
    Quote Originally Posted by bluetori View Post
    It's so funny, all the different opinions I read about smell with HFC/test pipe. I have a HFCC and I can smell the difference.
    Mar 29 2016
    2022 BMW X5
    Santa Monica, CA
    I can def notice the smell when i am idle with my windows down. As i said its not bad but its there.
    Mar 07 2015
    i run a test pipe with stock exhaust and apr 2. sounds stock to me.
    May 16 2016
    gauteng
    Do you need a resonator or can I just run it with one box
    Sent from my D5503 using Tapatalk
    Buncha motorcycles
    Memphis, TN
    My last a4 had test pipe and neuspeed exhaust. Yes, there was some smell but not intolerable or anything.
    Just don't want it as loud as my last car. Still kicking around the awe exhaust
    Established Member Two Rings D21burggraf's Avatar
    Oct 15 2011
    03 Dodge Ram
    KS
    Quote Originally Posted by PBKIDD24 View Post
    How bad is the smell after adding the HFC?? I had a testpipe on my old B6 and ended up taking it off because I couldn't stand it any longer. I know a HFC would be better, but am hoping for zero smell if at all possible. How about the sound increase? I have the APR cat-back exhaust currently. Not looking for any (much) sound increase, just wanting to move up from APR Stage I to Stage II...while not sounding like a ricer every trip I make.
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by D21burggraf View Post
    Should be 0 smell.. I had test pipe on my old k04 b6 and I know the smell.. I have 0 smell on my apr dp setup..
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    +1 with 0 smell with the APR downpipe/HFC.
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Active Member Two Rings cdmx's Avatar
    Apr 01 2009
    2004 Audi a4 3.0 Quattro, 2002 toyota 4runner sr5, 1994 bmw 325ic
    Charlotte, NC
    Mine smells like a tractor. Lol
    Veteran Member Three Rings wabbit23's Avatar
    Mar 20 2011
    2011 Avant Quattro & 2010 Jetta TDI
    San Diego, Ca
    Just took off my testpipe and downgraded to Stage 1. There is defintely a deeper tone and smell with the Test pipe on the stock exhaust alone.
    OP, you can safely run a stage 2 tune with a Testpipe alone. Its a slight bump in power from a HFC, Ive had both on both of my B8's. However, If I were keeping my car I'd most likely be going to a HFC option again.
    Mine- 2011 Avant Quattro- Premium Plus w/ Sport Package- APR Stage 2/ SPM Downpipe/ AFE Prodry S/ R8 Coilpacks/ ECode HFIP/ ECode Intercooler Piping kit/ 20% F & 15% R tint/ Dipped Parts & Vagcom stuff
    Hers- MKV Jetta TDI- Matte Black VMR V710's / H&R OE Sports/ Koni FSD's/ Dipped parts everywhere
