Page 1 of 4 123 ... LastLast
Results 1 to 40 of 149
    Feb 20 2015
    Nassau County, NY
    Coincidence? Car to shop, work done, now I have an engine knock.
    I don't post here much. Self employed and time is always limited.
    I took my 04 S4 (4.2) to a shop on Long Island.
    Quick history first.
    A year ago, had valve cover gaskets, both radiators, evap, misc. switches etc. replaced. Got the car back and it was still leaking oil. This first shop tells me to bring it back. They tell me the Valley Pan Gasket is shot.
    OK WTF? Why didn't you tell me this while you had the damn car apart? $1,200 to do that job. I held off since it wasn't leaking that bad and only when I drove it. Took 1/4 to 1/3 of a quart a week depending on how much I drove it. This is a weekend car for me. I just stayed on top of oil level.
    Two weeks ago the oil leak got much worse. Came out and there was a puddle on the ground. Talked to someone and they recommended "so & so" shop. Called them told them what the first place had said. I stopped driving the car until I dropped it off. Three guys that work for me were at my house when I checked the oil, started it and drove it to the shop. One followed me to give me a ride back. At this point the car was running fine, no noises. Waited days to hear. Finally they called and said there was an issue. The oil leak was coming from the oil cooler pump. They already charged me $1,100 to do the intake gasket and put the car back together.
    WAIT? WUT? His response was, "You brought the car in for an intake gasket and that's what we did." I said, "Aren't you guys supposed to be the experts? Wouldn't you diagnose the issue BEFORE you do a repair?" He said, "You brought it in saying you wanted the gasket replaced because it leaked oil so we replaced it." Nooo... I said the car leaked oil and THE OTHER PLACE said it was the gasket. If I brought in a muffler bearing telling you it would solve my oil leak would you run with it?
    So... another $900 to fix oil cooler issue and de-carbon the intake.
    A week later I get an email the car is done. I go to pick it up, hand him my hard earned $2k and go to the car.
    IMMEDIATELY I notice there's a misfire. Car is idling rough which it NEVER did. Then my wife sitting in the other car says, "What's that noise?" I get out and hear this fainting rapping. *gulp* I pull the car over to the garage and he throws a computer on it. Misfire cylinder 5 & 6. *NOTE* I run Torque on my phone and have NEVER EVER had a misfire. He hits the pedal and I can hear the knock speed up and get louder.
    Long story short... 2 hours in the parking lot arguing he says it "just happens" and that it's from me driving it with an oil leak. He says they ran it for an hour and none of this happened.
    THE SECOND I GOT IN THE CAR I felt the misfire and my wife heard the knocking from outside the car!!!
    I leave it there and he takes the oil filter out. There's metal in the filter.
    That's funny, 220 miles ago when I had the oil changed there was no metal in the oil filter and no knocking sound. Nor was there a knocking sound or misfire when I left it with him.
    I'm an old hotrodder from the days when average Joe could work on a car himself. A rod knock would come on slowly. This is already LOUD.
    My question is this... can a rod knock suddenly from the time he shut the car off to the time I started it hours later?
    Not only did I lose the $2k I gave them but the car now needs either $7k worth of work or I have to sell it as is and take a huge loss.
    My wife wants to sue but I'm not a fan of courts.
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    Bring to a more reputable shop and have them diagnose it further. I didn't read your whole thread I skimmed but go get it double checked
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Fuck shops. They are all scammers! Do compression test and boroscope the cylinders. Get somebody from the forum with vcds to scan the car and check timing angle. Its sad to say but i would not leave my car at any shop in tristate area. They all suck balls.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Mar 10 2016
    S6 v10, RR l322,
    ny
    Prob has something to do with the carbon cleaning....
    these motors really don't need carbon cleaning like direct injection models do..
    List all mods here
    Established Member Two Rings gaben2racin's Avatar
    Jun 15 2013
    Roseville,CA
    Sounds to me like you got scammed hard.
    Time to sue bud
    Sent from my SM-G900T using Tapatalk
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    What shops? Tell so others wont go there, its a common courtesy and it helps out other members from getting screwed like you. My money is on Elite Motorsports is one.
    You have a VERY hard case here. You may want to see council and see what they at least have to say.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Jan 29 2010
    north ga
    $1200 to change a valley pan gasket?
    Holy shit, what is their hourly rate $500? Valley pan gasket is super simple. Remove the Intake Manifold and it's right there after taking off like 100 little torx screws
    Feb 20 2015
    Nassau County, NY
    Quote Originally Posted by FastEddie View Post
    I didn't want to name names but I suppose I am justified.
    Ding Ding Ding! Johnny tell the man what he has won!
    The first shop was Elite Motorsports.
    The second was Force Fed Engineering in Deer Park.
    I used to be a decent wrencher when I had my 69 Grand Prix and even my 2000 Firebird with an LS1 but this Audi motor... beyond my abilities.
    Thing is... besides what Elite did I also did the motor mounts all around, had an Alpine deck put in it and even named her "Elsa."
    Now the $2k I gave FFE is down the tubes along with the loss on the cars value.
    Feb 20 2015
    Nassau County, NY
    Quote Originally Posted by BCsniper View Post
    I had placed an ad on CL hoping to find someone to do it and thought I had someone but when he said he had never done it... well I stayed away. FFE came recommended from my Geico rep.
    Aug 09 2012
    Bay Area
    Why was a carbon cleaning needed on a B6? Only the DFI motors mostly DFI vehicles need carbon cleaning. Even when I did my timing chain at 100K I hardly had any carbon on my valves. Timing chain valley pan and a ton of other stuff was done at the same time when the entire engine came out.
    Feb 20 2015
    Nassau County, NY
    Quote Originally Posted by Kambesama View Post
    I wish I knew. :(
    I LOVE this car more than any car I've ever owned but I cannot afford to fix it at this point. It has drained me of every dollar I could spare and more.
    Mar 14 2013
    Wow, I brought my car there for a alignment, never had an issue and they are reputable and have had a lot of work and backup to their name. Sorry to hear.
    Quote Originally Posted by richflath View Post
    Aug 09 2012
    Bay Area
    Yeah I love my car too luckily for me i'm still able to wrench on cars haha. I actually did the timing chain myself one of the biggest jobs i've ever done in my career. At first it was daunting but after I got through it I came out more confident than ever.
    I would recommend this. The ticking noise maybe a cause of the valley pan. It maybe possible that they incorrectly blocked one of the oil passages during install. If you can try removing it and inspecting. Taking out the intake isn't that hard, its just time consuming.
    Mar 10 2016
    S6 v10, RR l322,
    ny
    Bring the car back to the shop immediately, ask them how they did the carbon cleaning and let them hear the ticking...
    You most likely have a valve issue....
    They have to take of it for you... If they don't, tell them you are going to have to file something with dmv....
    Feb 20 2015
    Nassau County, NY
    Quote Originally Posted by harry.s.truman View Post
    My original message said;
    "IMMEDIATELY I notice there's a misfire. Car is idling rough which it NEVER did. Then my wife sitting in the other car says, "What's that noise?" I get out and hear this fainting rapping. *gulp* I pull the car over to the garage and he throws a computer on it. Misfire cylinder 5 & 6. *NOTE* I run Torque on my phone and have NEVER EVER had a misfire. He hits the pedal and I can hear the knock speed up and get louder.
    Long story short... 2 hours in the parking lot arguing he says it "just happens" and that it's from me driving it with an oil leak. He says they ran it for an hour and none of this happened. "
    They just want me to get the car out of their place. Talking to a wifes friend who luckily is a lawyer.
    Mar 10 2016
    S6 v10, RR l322,
    ny
    Yeah I just read that... Skimmed through the first time..
    Not looking good.... I would def first go to dmv and file a complaint... Or let them know you will be filling a complaint...
    You could also take it to yelp and Google reviews... Trust me company's don't like that...
    You will prob have to at the minimum go to small claims court... Win a 3/4K judgment, have someone do a leakdown/compression test to get a better picture along with taking the heads off..
    Mar 10 2016
    S6 v10, RR l322,
    ny
    Also who suggested the cleaning?
    Did you see the oil or did they say there was metal in the oil...
    Feb 20 2015
    Nassau County, NY
    They did it without even asking me. I didn't know until they told me.
    They emailed me pictures. Could have been anyones filter! Funny thing is, I had a certified Audi Mech change the oil last fall before I stored it under it's cover for the winter. He said he would most certainly have told me if he saw any signs of metal in the filter.
    Feb 20 2015
    Nassau County, NY
    Download and printed the complaint form from DMV. I will most certainly be sharing my experience on Google, Yelp, the BBB and maybe even Rippoff Report.
    Lucky for me a bunch of my wives friends are attorneys.
    If this was a few hundred dollars or maybe even a thousand I wouldn't be as livid as I am.
    Mar 10 2016
    S6 v10, RR l322,
    ny
    in a normal situation I would say there is a very good possibility of something going wrong in this motor and it could just be random...
    But given the fact that they blindly just replaced the gasket without checking where the oil is coming from means they are ****s at best or just don't give a shit....
    In a normal world you would just do a couple of checks like compression leak down to get your answer on the location of the damage, the problem is these motors have there problems, scoring could cause weak numbers..
    List all mods here
    Apr 01 2012
    Queens
    Quote Originally Posted by [a]bek. View Post
    Your talking about Elite in New Jersey (TOTALLY different company) or Elite in Farmingdale NY. If your talking about Elite in Farmingdale then your full of crap. I know MANY people who have nightmare stories about that place and ive even said it in threads on here that you have posted in. I have a nightmare experience, Tomek had a worse one, Coderedpl has seen their awful work first hand, Our buddy Sal, Shonseb another big contributing member on this site with a RS5. the list goes on.
    Im so sorry to hear about your misfortunes and how you have been taken advantage of. IF your going to bring your car ANYWHERE else, PLEASE for the love of god call Mike at Tryol Sport. He is in Queens and while they charge top dollar, Mike is a straight shooter and will always give you the truth and not take advantage of you. Only problem with them is there is usually a week or two wait.
    Feb 20 2015
    Nassau County, NY
    So I had the car picked up today via flatbed. Just so happens the flatbed owner has a V8 S4 too. He got there before me and they just handed him the keys! No verification, no nuthin! WUT WUT WUT?
    He said, and I quote, "Bunch of characters in there. They all have attitudes."
    I have to say I am pretty appalled at everything about this experience. This is supposed to be a shop that works on higher end cars and usually those people care a whole lot about those cars.
    A. The car has grease prints all over it.
    B. There is grease and DAMN footprints on the wheels! Evidently someone was using them as step stools!
    C. There's a mark in the paint that was never there before.
    Attaching links to some pics and two videos. The first is the noise the car was making when I picked it up.
    The second is what it sounds like idling. I didn't dare run it for too long and it's not knocking but sounds like a damn diesel engine.
    http://logichurtz.com/2/0520161421.jpg
    http://logichurtz.com/2/0520161422.jpg
    http://logichurtz.com/2/0520161422a.jpg
    http://logichurtz.com/2/0520161423.jpg
    The noises when I picked it up;
    http://logichurtz.com/2/s4-pickup.mp4
    What it sounds like today (not fully warmed up)
    http://logichurtz.com/2/s4-rattles.mp4
    Feb 20 2015
    Nassau County, NY
    Yea my experience was with Elite in Farmingdale. SO would you say paying $1,100 for a valley pan gasket was a bargain?
    Mar 10 2016
    S6 v10, RR l322,
    ny
    that is not valve issues.... that's a spun bearing.... Maybe they over revved it....
    that engine unfortunately is prob wasted....
    List all mods here
    Jan 17 2014
    New Jersey
    Dude dont wait, go to court with them. Your engine is probably done. Sorry to say that. Sooner you go to court sooner youll get your car back on the road.
    Insta: luccamentone
    Stage 2 Banner Advertiser Four Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Lindenhurst NY - Long Island
    Rich
    Looks like our name came up so I'll chime in.
    Your car came to us Feb. 2015 with the complaints below. As you can see we diagnosed the car properly but you opted out not to do everything mentioned and only did the valve cover gaskets and radiators and a few other minor things. The valley gasket and the oil filter housing gasket were leaking from day one. I'm sorry you're going through this but unfortunately there is some misunderstanding here.
    You going to to another shop to do the recommendations we told you from day one at a later time mind you just shows neglect. I can understand if cost was an issue at the time but driving the car this whole time just adding oil is not the best thing you can do to an engine.
    The intake manifold has to be removed to do the valley gasket and oil filter housing gasket I think that is where you got mistaken and just told them to do just that and they did just that as it shows. According to what was diagnosed your car came to us over a year ago at 130K miles and it was POURING oil based on our records as you can see below.
    Let me know if you have any questions and feel free to call me at the shop.
    Regarding what Fast Eddie says, he just never gives up and keeps going like a broken record and just sabotages every thread. We stood up to the mistakes with all of his friends including him and handled it professionally. I explained everything on here and the other forum and offered to help yet none of them show up to the shop and to this day what happened with Tomek his offer still stands, so does all the others. Had we had the chance to fix or resolve their concerns we would have done so. Out of the over 2000 cars we do yearly, there will be issues. Its a rule of #'s. No need to go into a lesson but we try our best to resolve issues to the best of our ability but there will always be those few who can never be made happy no matter what you do. It's going to happen.
    If anyone has any questions or concerns please don't hesitate to contact me.
    ELITE MOTORSPORTS
    21 W. SUNRISE HIGHWAY LINDENHURST NY 11757
    www.elitemotorsport.net - www.elitemotorgroupny.com
    P: 631.775.6634
    Follow Us On Facebook
    Follow Us On Instagram #elitemotorsports
    Follow Us On Twitter
    Feb 20 2015
    Nassau County, NY
    Quote Originally Posted by Kai@EliteMS View Post
    Rich
    I came to you saying the car was leaking oil. You "fixed" it and the next day it was leaking oil again. Maybe you should have looked a little deeper while the car was apart? This is why I looked elsewhere.
    BTW, they didn't have great things to say about you or your work so I wouldn't get too chummy with them just yet.
    "Pouring out?" LOL NO. Not even by a far stretch of the imagination was it pouring out. 1/3 qt every couple hundred miles is not "pouring out."
    It WAS pouring out when I finally brought it to them which is why I finally did. I did maintenance on the car the entire time, I'm not stupid.
    Mar 22 2011
    BTW, FFE didn't have great things to say about you or your work so I wouldn't get too chummy with them just yet.
    It WAS pouring out when I finally brought it to FFE which is why I finally did. I did maintenance on the car the entire time, I'm not stupid.
    I don't think you read my post, the car was never "fixed" fully. You opted out on the recommendations.
    It was pouring out while the car ran out of the valve covers and you only wanted to do that not the other concerns. Like I said if you have any questions give me a call but this car had problems from day one. Nobody called you stupid.
    ELITE MOTORSPORTS
    P: 631.775.6634
    May 21 2016
    ny
    Mr Flathmann,
    I am going to respond once to this post. Nothing in this post is going to be anything different from the information that I have provided you in the last few emails. I hope that anyone that is reading takes the time to completely read and comprehend the situation and the way it unfolded.
    Mr. Flathmann contacted me via phone to change a valley pan gasket on his 2004 Audi s4 4.2 V8. We declined to do the job. We are not a regular service facility, and we have little to no interest in working on a car with 120+k miles. Especially for first time customers and ones where clients are insisting what is wrong with the vehicle and providing their own parts. Typically these tend to end up as incorrectly diagnosed or Chinese poor fitting items that leak, or don’t fit.
    With that said do not mistake our disinterest in doing the job for incapability. We build drag cars, off road use. Chassis work, wire harnesses, turbo kits, built engine, custom fabrication, race transmissions, dog boxes, etc. I have jobs that are ranging from weeks to months in duration.
    After high recommendation from a client and insurance adjuster dealing with Mr. Flathmann with one of his other vehicle and a second call for request of services I decided to take on the job as it was a recommended job.
    I was told the following. The vehicle has had a leak for a short while and that he was told by the previous repair facility it needed a valley pan gasket and that he did not wish to go back to the previous shop to have the work done.
    The vehicle was dropped off to my shop outside of my business hours. There was a 3’ puddle of oil underneath the vehicle and there was no oil on the dipstick tube. We were instructed to change the valley pan gasket, and any associated items that would require the intake manifold to be off to access. Due to there being no oil on the dipstick, a huge puddle underneath and a request for LOF change I pushed the car inside rather than waste more than a few quarts of oil to drive it 20 feet into the facility just to be drained again.
    We removed the intake manifold taking notes of everything along the way that we saw. Several injector connectors were broken, there were broken vacuum hoses in the secondary air system, connectors on the front of the intake manifold were broken. We ordered the additional items that Mr. Flathmann did not supply which come standard with a “valley pan gasket kit”.
    The entire engine bay was covered in oil, from top to bottom. Puddled in numerous spots. In front, back, sides of intake manifold, front and rear of motor all the way down to the oil pan and under it. The oil pan gasket was also covered in silicone as it had been replaced previously.
    Once the parts arrived from Audi we completed the top end valley pan gasket seal that Mr. Flathmann requested. All the while we had both called and written emails outlining the job, items missing, items we saw in question and what the items we were ordering consisted of, where we were getting them, how much they would cost and the time table for receiving them.
    At this point we changed the oil, and the filter placing the old filter in the new filters box and setting it aside for later disposal. This is a standard practice to me just to keep parts from one thing organized together if a client wants old parts. We have had many customers over the years wish to send oil samples out to be analyzed. We will come back to this.
    Upon first start up of the vehicle, after cleaning the entire engine bay down with assorted cleaners and rougly 1 full case of brake parts cleaner, we started the engine for the FIRST TIME.
    There was a substantial flow of oil coming from the bottom passenger side of the engine, we immediately turned the engine off. There was no change on the dipstick it ran for under 15 seconds.
    We called Mr. Flathmann and he was immediately screaming on the phone and we asked him to come down to take a look with us. In the last 10 years I have never been screamed at by a customer, especially after letting him know that there was an additional oil leak that we were not told of. Just a notification, nothing more.
    Upon arrival of Mr. Flathmann we showed him the old parts, we showed him the source of the additional (not new by any stretch of the imagination) leak and asked him how he wished to proceed.
    Since the beginning of dealing with Mr. Flathmann he told me several times he had already wasted a ton of money on this car and that he did not want to spend a lot to fix it. He was angry that the valley pan gasket repair only stopped the leak at the valley pan gasket, and didn’t fix the entire car. All the broken connectors, all 8 broken coil pack connectors (just during the job looking around noticing) amongst other typical 12-13 year old vw/audi problems.
    We then started the car for Mr. Flathmann and showed him what we believed to be an oil cooler related leak. The engine had a faint tick that came and went. Mr. flathmann again screaming and cursing saying that it never made that f’ing noise before. I calmly explained the vehicle was multiple quarts low on oil and due to the puddle, I decided not to start the car until I could confirm oil level upon oil change service. We told him the necessary steps to access, diagnose and replace the items in question and gave him a rough quotation verbally depending on if it was just a seal or in need of a cooler. Before leaving he agreed to have us remove the front end of the vehicle to further diagnose. He made sure to tell me that time was a big thing for him (being this was already after hours) I stayed until 1230 am to remove the necessary parts to gain access, pull part numbers (with vin split) off of films and online parts catalogs and email Mr. Flathmann before morning as to the status of the repair. Waiting his response on how to proceed. That was Friday night, email was sent in the early morning hours of Saturday.
    I received no response to that email even though he claims he emailed us back. I emailed him again Monday for an update and he told us that he already said to do it. Moot point, we continued.
    The next business day I received the new orings that were to replace the ones that were dry rotted and falling apart, changed them, assembled the accessories required to remove to gain access to the cooler and again changed the full volume of oil in the vehicle (retained the same “new” 30 second run time filter from the previous days)
    There was no leak pouring out at the oil cooler, valley pan was completely dry and the engine was 100% full of oil. There was still a faint tick. Obviously the car is not new. The pan had sealant all over it, we never touched it, the one valve cover gasket was seeping, we didn't touch that either. I never saw the car or dealt with this client prior to this experience. With the hood shut and the front end installed it was inaudible. We adjusted the headlights as per his request to the maximum they would adjust so they didn’t point at the floor. No charge of course. I drove the car around the block. The vehicle came in to me with 137,029 and left with 137,030 miles. Everything seemed fine.
    We contacted Mr. Flathmann that the repair was complete, there were no more major leaks, everything addressed was dry and it was available for pickup. We did everything we were authorized to do.
    He came in the evening to pick up the vehicle and as he went to pull the vehicle out of the parking lot there was an engine noise, he continued to rev the engine up and start it every few minutes despite the noise. He was again screaming and carrying on that the engine didn’t make noise before. After roughly an hour of him carrying on and speaking to his wife with him in the background we decided to leave the car to determine the potential damage and what was necessary to proceed.
    At this point I contacted Elite to obtain any information and was forwarded the service records. Not 2,3,4,6 months ago was the car looked at. 15+ months, feb 2015 and 6000+ miles ago the vehicle was at Elite and the customer declined to have the items changed that were still leaking until they were just repaired.
    Through all the emails there after with Mr. Flathmann he tried to rationalize to me that the engine ONLY leaked when it was running. Anyone who understands the mechanicals of an engine should realize that this is FAR WORSE than a static leak, broken or cracked oil pan, improperly sealed lower engine oil pan etc.
    If the engine is producing ~30psi at idle and 60+ at higher engine speeds, but you are leaking out ˝ or more quart of oil “on a weekend drive” that Mr. Flahtmann stated the vehicles only use was, that is ˝ quart per say, 25 miles is .02 quarts of oil PER MILE. The standard which I think everyone will agree, even if you don’t the variable in decimal denomination is comical at best, .0002 quarts per mile based on 1 quart consumption (not pouring pressured leak) per 5000 miles, measured in standard oil change interval.
    In short Mr. Flathmann leaking his measly ˝ quart per weekend drive was 100 TIMES more consumption, or pressurized leak starving his engine for oil over the last 15 MONTHS. That is also the time and date documented by elite. No one brings their car for a leak it doesn’t have, so it is a mystery as to how long the vehicle has actually been leaking.
    Mr. Flathmann and his wife threatened to take me to small claims court, slandered me in front of people in the parking lot, yelled and screamed at me on the phone more than once, slandered me to the tow truck driver, who asked me upon arrival if he should decline towing the vehicle as the customer was screaming and carrying on at him on the phone (he did nothing “wrong”)
    I felt the need to explain all of this and will not bicker back and forth, but I will post up the email correspondences to prove the level of competence and thorough explanation exhibited with Mr. Flathmann in private to attempt to resolve anything needing clarification.
    On top of this, after they left the vehicle with me I again pushed the car inside and began to remove necessary items to diagnose and test oil pressure. I figured it wouldn’t be a bad idea to inspect the oil filter. The filter had metal shaving in it.
    I went back to the original filter, for all of you still reading, you will recall I NEVER started the engine on this filter because of the 3’ puddle under the car. It too has metal shavings in it.
    Mr. Flathmann also explained that the engine had started leaking MUCH more in the last few days, with the timeline difference between a few months and 15 from when it was at elite I will give him the benefit of the doubt and say its been pouring oil (as out lined from elites paper work 15 months ago) for at least 2 months.
    No one forced Mr. Flathmann to drive the vehicle to me, he didn’t drive it out, he called a tow truck. Possibly if he would have done this on his drop off to me the vehicle would still be running today without noise, but with no guarantee for how long now knowing the events and timeline with elites paper trail leading me to the long winded explanation of this situation.
    I do empathize with Mr. Flathmann but find it highly improbable that anyone with any sense or competence would blame me running a car for a few seconds with some leaks repaired and a full volume of oil for the failure of Mr. Flathmann engine over his 15 months 6000+ mile
    weekend drives (you typically don’t drive that much in 15 months on joy rides only) with him adding oil as needed. AGAIN pressure based leak, not static leak, he starved the engine of oil pressure for 6000+ miles and it was his decision based on elites documentation.
    Again sorry anyone who had to read this, I hope this clarifys the events leading to another outlandish attempt to slander both myself and elite. I commend elite on their stellar repair order documentation and appreciate kai’s willingness to provide me with that documentation.
    Lastly just to add on, I couldn’t post right away waiting for webmaster approval to post. A few things, Mr Flathmann was not billed for a DI carbon cleaning, this car is not DI, it is port injection. BUT this car was covered with oil, engine bay, under carriage, radiator support, frame rails, transmission, the intake manifold inside was caked with oil, the intake ports were caked with oil, we originally charged him 1 hour labor ($100) to clean his intake manifold out and go through all 8 intake ports of his head and clean the filthy oil build up. As we were in there and he specifically said to do whatever needed to be done with the intake manifold off. He told me he didn't tell me to do that, so I removed it off the invoice, no questions asked. I just spoke to the towing company and there was no damage to the vehicle, and that he would be glad to come on and post about the situation at hand. That the owner showed up when the car was being loaded (after it took me roughly 10 minutes to move cars around the vehicle to easily load the car onto the flatbed.) That he gave me the clients name and that he was here to pick a 2004 audi s4. Of course i knew it was for Mr. Flathmann from his knowledge of the situation. We did not remove the engine, we did not reseal the oil pan. We did not sell him the car, did not provide him with a warranty for this car we didnt sell to him. He bought a car, drove it, had more than 3 different people work on it, it has problems that were not addressed and is far from new. It has 137,030+ miles on it and by no means did we say we fixed the whole car. Drivers side valve cover gasket is still leaking, all coil and many inj plugs are broken, many other electrical plugs are broken and the oil pan was covered with silicone. He also said Mr. Flathmann stiffed him for $10, got the car off the flatbed started it cold and was immediately revving it up and down. I have nothing futher to comment, I will post screen shots of emails and pictures of oil, filters, housing and anything else, I took pictures of the car before it left onto the tow truck just to be safe because I knew there would be bogus allegations….
    Aug 08 2010
    Alaska
    Hey, this is a forum, so why not chime in? With no dog in this show, I feel like there is could be some blame for the shops involved, but most of it lands on the owner.
    - Oil leaks are deceptive, you keep adding oil, but sometimes it might get low and you starve the engine. You can't rely on the oil light (not sure if you did). Sure seems like that happened here.
    - This car is complex and expensive. If you can't afford $5k-$10k to fix something every year or so, then you've got the wrong car. Sorry. Honestly, $5k a year is about a car payment, so if you can't afford it, get an old Honda civic.
    - If a shop says we need to do this to fix the problem, and you DO have them fix it and the problem remains, you have some leverage. If you decline the work, it's on you 100%.
    Mar 10 2016
    S6 v10, RR l322,
    ny
    This is getting interesting...
    Some good documentation from both shops..
    im 50/50 at this point
    List all mods here
    Aug 04 2010
    Queenz/Westchester
    Eddie is reporting a bad experience that he had with your shop. You can't knock a guy for contributing his experience so others can also be aware, that's what these forums are about and he's just looking out for the good of others. I didn't know about the negative experiences with your shop and so I decided to give you guys a try. My experience with you guys was also negative and ended up needing to correct the job you did. In my case, all though the job was done, but the lack of attention to detail meant I had to nearly redo the same job and perform steps you guys carelessly missed. If I had known about the negative reviews and experiences others had, I would have done the job myself to begin with. And because of that lack of attention to detail, why would I want to go back to you guys?
    Shops are really losing sight of what car enthusiasts are about. It doesn't matter that their car is 10+ years old or that it has >100K miles. It's their car and they want it looked at just the same as any other enthusiasts car. For example, I went to detailing dynamics in Mineola because I wanted my car Xpel'd. I figured that would be the best place to go since they work on supercars all day long. I was surprised when I showed up there and I saw a Toyota Prius getting Xpel'd too. Matt, one of the managers there, told me "It doesn't matter the type of car, the age or the condition of the car. We treat all the cars the same because the owner of that prius wants his car car treated like its a ferrari. Who are we to say we can't? We cater to enthusiasts, and to any enthusiast his car is golden and wants it treated that way. That's the level of service we provide." That's the reason I go to places like Eurotech and Tyrol, and I think others on the forums should know the experiences as well. It's what these forums are all about.
    May 21 2016
    ny
    This was not a low oil level problem. He could have had a 50 gallon oil pan and still destroyed the engine. It was leaking out pressurized oil before it made it to the critical engine parts. The oil pan is just a container bolted to the engine. Sure if there is no oil in the pan it will cavitate and supply air (nothing) or foamy oil instead of a steady stream. But even if there was a never ending supply of oil for the pump to pickup, pressurize and supply, it was STILL pouring out of the side of the engine. Now that 30-90psi of pressure (engine speed variable) is far less than half. Think about how long a person lasts with only half the oxygen they are breathing in making it to the critical parts of your body . The valley pan gasket was 100% leaking. You address leaks from top to bottom. I addressed the leak that we could see. After the vehicle was ready to start. Full of new oil and filter I started it for a few seconds with someone watching and immediately shut it off. I didn't fix the valley pan gasket, fill it with oil and tell the customer to come pick it up. I contacted the client and notified him of an additional item that needed to be addressed. I didn't make the leak. The whole premise of this argument is invalid.
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Great documentation and break down from both shops.
    It wouldn't surprise me if something failed finally given the amount of neglect.
    May 21 2016
    ny
    Quote Originally Posted by q_dubz View Post
    No one ever wants to have an unhappy client. No one ever wants there to be a problem. In this instance there was a large issue and it wasn't a loose drain plug or a hairline crack in an oil pan. The lubrication system in the engine was not lubricating the engine. It's almost as bad as having a failed oil pump.
    Jun 07 2013
    West
    Take it to an Audi dealer's service department. They will fix the car, but you will be financially ruined. That will force you to sell the car and rid yourself of further problems.
    Feb 20 2015
    Nassau County, NY
    It comes down to 3 facts.
    1. When I dropped the car off there was NO misfire.
    2. When I dropped the car off there was NO knocking noise.
    3. They "claim" that they ran it and there was no noise or misfire. Then WHY the MOMENT (I mean literally the first 1 second!) I started it after they had it did it misfire and have a knock?
    Add to this the fact that it's already leaking oil all over my driveway the day after I got it home. To me, it is a testament to the quality of work done.
    If I had neglected the oil level and dropped it off making a knocking noise I'd have no case. I also have a certified Audi Tech that will verify there was not a shred of metal in the oil filter when he changed the oil.
    I've already talked to an attorney and this WILL be going to court.
    Feb 20 2015
    Nassau County, NY
    Add to this that they gave some random tow truck driver the keys to my car before verifying I had actually hired them. I was not there when they already had the car on his flatbed.
    If I was a douche I would have just claimed I never saw the car after that day.
    I am evidently not the first customer not happy with FFE's work. Check the Google reviews.
    Feb 20 2015
    Nassau County, NY
    Quote Originally Posted by Ed_ View Post
    Mr Flathmann,
    Here's the kind of guy Ed is. This is an outright lie.
    A. Myself and the driver that picked up the truck got along great! We both have motocross backgrounds and he is an S4 owner himself. There was ZERO dismay between us.
    B. I didn't tell the tow truck driver more than, "I need to be there because there's a knock in my engine that wasn't there when I dropped it off."
    C. As said, they let some random driver pick up my car without authorization from me.
    D. The tow truck driver said, and I quote, "They're a bunch of characters in there aren't they? They all have attitudes."
    The driver was no fan of how they spoke to him. His words were, "My guess is they either started it with no oil in it or over-revved it and spun a bearing."
    It's funny how Ed talked about how bad and overpriced the other shops work is to me, my friend and my wife and suddenly their cohorts.
    Ed... besides the other issues mentioned, my car is already leaking oil 1 day after I got it home. AND from several areas. See the pictures?
