Originally Posted by
AKPS4
Does anyone have recommendations for type of paint to use to paint some pieces inside of the headlights? I'm considering this but also want to black out the heads like with some accent colors while everything is opened up.
Also, not completely clear on how to seal the headlights back up. Do you simply apply some head and follow with another bead of some butyl based sealant? Or other method?
I'm just going to reheat the original sealant that's there and push it back together.
Good luck with the lense job - I gave up LOL - if it was one piece to remove it would not be so bad but seems like there are several you need to remove. Many of the screws are virtually impossible to get to so you have to pull on components to try and squeeze a screwdriver between them etc.
EDIT!
I ended up doing this project this eve. It was a PITA for sure... LOL. It took me probably 5-6 hours end to end.
I found a DIY for the B8 (sort of) - I followed this backwards. I have advanced lights so it was not exactly the same. Also the LED strip cover and the side marker carrier both would not come off independently so I had to reverse the order of some of the components...
New vs old lense:
The OEM lenses I have did not look anything like those of the OP. Perhaps it's because I have advanced lights? They did not have any dimples in them at all. OP's was covered in those dots/dimples. Mine were completely smooth. The new lenses were not much clearer than what was already in there either.
Removing the lense:
Once I got all the bits removed to get to the cage holding the lens - Again because i have advanced lights this is different - but I was not able to separate the aiming bracket from the cage (It was a mess of nuts and bolts and so many that seemed impossible to get to) so I ended up just removing the top two screws holding the cage to the aiming bracken and bending it down to get to the lenses. Worked fine.
Putting it all back together - was much easier, I just followed the above vid. I ended up with a couple screws left over - not sure where they go but everything seemed tight so I"m not worried.
Back on the car: Had to aim the lights again. Cut off is sharper but not drastically better. I was able to clean the inside of the headlight cover and black out my side corners so the lights look better and I think I have improved output probably due to the clean covers and slightly improved lenses.
Sorry I didn't take pics as I worked. This was just too frustrating a job to try and document. My bad...
