Page 1 of 6 123 ... LastLast
Results 1 to 40 of 201
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    HID Lens replacement - DIY (E-codes alternative)
    Having heard people speak highly of how good the light cutoff on the e-codes and not having that stupid looking amber marker, made me wonder if there was a cheaper alternative than full blown e-codes. After doing some searching here on the forum and online, I came across these ZKW-R 3” clear HID lenses that have no dimples in them (link below). I realized that for a mere $40 (plus shipping) I could get better light cutoff than e-codes at a fraction of the cost . The E-codes, albeit having fewer dimples, still have them too. I figured for $40 it was an absolute no brainer and it would allow me at the same time to take care of those stupid amber markers.
    The Retrofit Source ZKW-R 3” Clear Lenses for Audi S4 B8.5
    The problem was, I couldn’t find instructions anywhere on how to take the headlights apart in order to get to the lens.
    After searching endlessly, I contacted a couple of very nice guys here on Audizine who had taken their headlights apart, in hope to pick their brains. They were nice enough to share some bits and pieces off the top of their heads, as well as pointers on how to go about this project. I had no pictures, no visual cues, and no step-by-step instructions to follow. All I had were a few tips and suggestions.
    Having to go through this project flying blindly, without a DIY as a reference was quite frustrating and daunting. So I figured the right thing to do would be to document the process to the best of my ability and offer this set of tips for anyone who is looking to disassemble his headlights. This DIY only pertains to the post facelift B8.5 headlights (2013-2016). I have no clue what the process is for the B8.
    So… to save anyone else here the guessing, hassle, and anxiety I had to go through, I figured I’ll post this tutorial, with pictures I snapped along the way.
    Now, before we dive into the process of performing this surgery on your car’s eyes, an obligatory....
    DISCLAIMER: I am in no way shape or form responsible for any damage you may cause to your headlights! This process involves a lot of delicate parts, requires a tons of patience and discretion! I HIGHLY recommend you take a step back and take the time to consider whether you are really comfortable taking these very expensive headlights apart. You may follow this DIY at your own risk!
    Also, if you have bulky hands or have the tendency to break things easily, this is NOT for you to try. One wrong step and you will be looking at buying brand new set of headlights.
    Just to give you an idea of how involved this gets, this is what you can expect your 'operating table' to look like at the deepest part of this project. If this picture makes you uneasy, you may want to reconsider (there are plenty more parts, screws, clips, ballasts, bulbs, etc. outside of the frame, to the right):
    Tip: Even though I’m providing you with visuals here, I HIGHLY recommend you snap pictures at every step you take along the way so you can backtrack your progress and have a point of reference in case you run into difficulty with putting parts back together.
    With that out of the way, let’s go over the tools and parts you will need:
    • T30 torx screwdriver
    • T25 torx screwdriver
    • T20 torx screwdriver
    • Flathead screwdriver
    • Heat gun and/or oven (I recommend using both in conjunction)
    • Long nose pliers
    • Box knife
    • Matt black Plasti-Dip (optional) – if you use this opportunity to black out the amber markers
    • Blue painter's tape (for masking)
    • A few pairs of rubber gloves (to prevent finger prints). You will need more than one pair, trust me, they will rip
    • KZW-R 3" Clear lenses (link above)
    Headlights removal
    Use a T30 screwdriver to remove the 4 screws holding the radiator cover:
    Driver’s side headlight removal:
    1. Using a T30 screwdriver, remove the 3 screws circled in RED
    2. Remove the screw bracket (GREEN square)
    3. Loosen (DO NOT REMOVE) the two screws circles in BLUE
    4. Disconnect the harness (ORANGE square)
    5. Disconnect the drain hose (not picture), located at the lower part of the headlight (mine was already disconnected for some reason).
    6. Remove headlight
    Passenger side headlight removal:
    Note: If you have relatively small hands, you *may* be able to get away with removing the headlight without removing the airbox. I was able (just barely) to get it out, but had to remove the air scoop and loosen the airbox (though I did not have to remove it altogether). The following are steps for removing the headlight without removing the airbox:
    1. Remove the 2 yellow screws attaching the air scoop to the radiator frame.
    2. Remove the air scoop and set aside.
    3. Release the airbox by lifting it up and away from the anchor shown on the left side of the picture (YELLOW)
    4. Remove the 3 screws circled in RED
    5. Remove the screw bracket (GREEN square)
    6. Disconnect the harness (ORANGE square)
    1. Loosen (DO NOT REMOVE) the 2 screws circled in BLUE
    2. Disconnect drain hose (not pictured)
    3. Remove headlight
    Opening the headlights
    I will skip this process as there are plenty of links here on AudiZine, elsewhere on the web, and some videos on YouTube. Some people prefer the oven method, other prefer the heat gun. I used a combination of both. If you live in the hot area, I recommend driving the car for a little bit with the headlights on. The heat will give you a jumpstart.
    • Remove HID ballast (3 screws + 2 harnesses) - make sure you remove the rubber ring as well
    • Remove LED ballast (3 screws + 1 harness) - make sure you remove the rubber ring as well
    • Remove headlight anchor attachment (2 screws)
    • Remove HID Bulb cover
    • Remove turn signal cover
    • Remove HID bulb
    • Remove turn signal bulb
    • Remove rubber bumper strip - it's attached with a double-sided glue
    • Remove drain attachment (1 screw)
    Pop the headlight in the oven for 5 minutes at 200 degrees, then remove, and proceed to heat the sealant along the lines using a heat gun, working your way in sections.
    Start prying the cover from the outer corner (amber marker side), and work your way inward towards the grille side of the headlight. Use a box knife to separate the cheesy-effect you'll get from the glue.
    Once the headlight has been opened, if you choose to blackout your side marker, remove the 3 screws holding the marker bracket to the front lens. I tried removing the marker from the bracket but gave up after a few minutes when I realize I was on the brink of breaking the damn thing. I went on to mask the bracket using blue painter’s tape, and sprayed the marker with 4 coats of matt black Plasti-Dip.
    Onto the lens swap....
    Remove the screw circled in BLUE. This will release the top bracket sitting right on top of the turn signal. The opposing side of this bracket is anchored on the opposite side to the turn signal plastic cover with a tab. Be careful not to break it. Then proceed to unscrew the 2 RED screws:
    Proceed to the bottom of the headlight, and remove the screws circled in RED (There are 2 more screws to the left that I forgot to snap a picture of):
    Unplug the LED side marker harness:
    Now comes the most frightening part - detaching the shroud from the base. Just to double check me, make sure you have loosened all the aforementioned screws, and there are no other visible screws that are holding the shroud attached to the housing. At this point, the shroud should have some leeway, kind of jiggle, but still intact and attached to the housing. CAREFULLY, start pulling the shroud outwards, towards yourself, rocking the shroud lightly left and right. Essentially you are trying to unsnap it. It is being held in place by the two ends of the LED bar, attached in their electrical sockets. You need to unsnap it. As you wiggle it back and forth, it should eventually snap out and you should have successful separation.
    Below, circled in RED is one of the two ends of the LED bar after it had been detached from its socket in the housing:
    Removing the lens
    The lens is strapped inside a 4-prong bracket that is attached to a mount connected to the auto-leveling motor bracket (screw marked in RED X 4). In order to get to the lens, you will need to first remove the lens bracket from the mount (screw marked in BLUE X 4):
    From a bit closer:
    Start from the back of the housing, through the reflector's back-end (where you would insert the bulb), and remove the 4 mount screws circled in BLUE (there are two more to the left, hidden by harness) to release the mount from the auto-leveling contraption (black plastic bracket):
    Once the mount is off the auto-leveling contraption (Black plastic bracket), proceed to remove the lens bracket from the mount by removing the 4 screws in RED (only top 2 are pictured below. there are 2 bottom ones to remove as well):
    Bottom 2 screws marked in RED, as well as the high-beam shutter circled in GREEN. Note: once you undo the lens bracket from the mount, the high-beam shutter will get undone as well.
    Let's stop here and review what we're looking at:
    Yellow - LED bar sockets (yes, those that cause you the anxiety as you were trying to free the shroud from the housing)
    Purple - Auto-leveling gears
    Orange - Side marker LED harness
    Green - High-beam shutter
    Blue - Main mount, holes and screw positions
    Red - Lens mount holes. Note: When putting everything together the lens mount 'overlays' on top of the high-beam shutter. There are two protruding pins on each side that should be lined up through the shutter's and the lens' bracket holes (see in the forthcoming pictures)
    Bottom of the picture shows the lens mount freed up
    Lens swap
    Flip the mount upside down, and using a pair of long-nose pliers, push the 5 teeth circled in RED, back and outward to release the lens. Then proceed to remove the metal pressure ring holding the lens in place. Note the notch in the lens (circled in BLUE). When installing the new lens, make sure that the notch lines up with the notch in the bracket:
    Disassembled:
    Lens comparison: Stock on the bottom, ZKW-R on top:
    Install the ZKW-R lens in the bracket. Again, remember to line up the notch with the one in the bracket. The ZKW-R lens lip is a tad thicker, so expect to spend a couple of minutes messing around with it, trying to level it off in the bracket's socket as the fit will be tight. Replace the pressure ring, and use the pliers to push the 5 teeth back to their anchoring position:
    Assembly
    Start working your way backwards.... start with attaching the lens mount onto the bracket. As I mentioned above, the lens bracket overlays on top of the high-beam shutter. It is imperative that the two line up with the pins that are protruding (immediately to the right of the screw circled in RED) from the main bracket. Failure to line up the shutter and lens bracket properly onto the main mount, will result in the shutter's inability to open up fully, or worse, become detached altogether.
    Another angle showing how the two line up:
    Circled in YELLOW is the pin that lines the lens bracket up, while the one circled in GREEN, lines up the high-beam shutter. Once two are properly lined up, insert the mounting screw (RED) through the two brackets and proceed to PARTIALLY tighten it up. Do not tighten as you will need leeway when lining up the opposing side:
    From there, proceed with the rest of the assembly process in reverse order:
    1. Attach the top two screws to the mount.
    2. Attach the 4 screws to the mount that attaches onto the auto-leveling motor bracket.
    3. Tighten all 8 screws (4 on lens bracket, and 4 on main mount).
    4. Reconnect the side marker LED harness.
    5. Line up the shroud so the two ends of the LED bar are positioned against their respective sockets (shown above), and firmly but carefully push the shroud in until the LED bar ends click into their respective sockets.
    6. Proceed with attaching the shroud mounting screws.
    7. Attach the black plastic bracket sitting on top of the turn signal (1 screw and a snap-on, on the opposing side).
    8. Attach the corner reflector bracket using 3 screws if you removed it in the beginning to blacken them out.
    9. Before proceeding to reseal the headlight : I recommend attaching the ballasts and bulbs, and test the whole thing on the car. Just lay it on top of the engine bay, connect the harness, and make sure nothing got screwed up. Everything should work as before. Make sure to test the high-beam to verify that the shutter opens and closes properly.
    10. Proceed to reseal the headlight: REMOVE THE BALASTS AND BULBS, close the housing and put in the oven for a few minutes, then follow with the heat gun. Reconnect all the clips while pressing everything into place as hard as you can.
    11. Reconnect the ballasts, reinstall the bulbs, replace the rubber covers over the bulbs openings, attach the drain hose, the rubber corner-bumper, and mounting bracket.
    12. Reinstall the headlight in the car (don't forget to reconnect the drain hoses)
    13. Replace radiator cover
    YOU'RE DONE!
    Now take your car outside in the dark and turn on your headlights! Congrats! You now have better light beam than e-codes at a fraction of the cost!
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Wow awesome, are there upgraded projectors that bolt in?
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by theswoleguy View Post
    They might have something.... check their section here (input make/model/year): https://www.theretrofitsource.com/co...rojectors.html
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Thumb up and Nice DIY
    i will be looking forward to open up the headlight to clean up the burn mark.
    Apr 05 2016
    Portland, OR
    Awesome Danny!
    Thank you for the diy!
    Veteran Member Three Rings TappaNuKegga's Avatar
    Apr 07 2016
    PA
    Excellent writeup man, really appreciate the effort put in.
    Will most likely be following this writeup within the next few months although I'd ideally hold off until glass headlight shell/housing lens become available(if ever) for our cars.
    Jun 30 2015
    Quote Originally Posted by TappaNuKegga View Post
    something for your reference. Headlight cover
    Please search it on aliexpress
    OEM Car Headlights Cover For Audi A4L B9 2012-2014 Headlamps lampshade PC Glasses Accessories Shell Replacement Mounting Parts
    http://www.aliexpress.com/store/prod...432851784.html
    Apr 07 2016
    PA
    Quote Originally Posted by lowjonathan View Post
    I saw those on Alibaba the other day they appear to be plastic though.
    "Material: ABS"
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    You sir are a very brave man. Nice writeup!
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by DannyDeez View Post
    Agreed!!! Very Brave... Love the extra light output..
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by whiped View Post
    Awesome Danny!
    Thanks guys. Just trying to save time and guessing for my fellow Audi nuts
    Quote Originally Posted by HeymyA4 View Post
    Ha! Brave.... Stupid.... synonymous.....
    Oct 14 2012
    Empty...for now...
    SE PA
    WOW. Thank you so much for this. Now the task does not seem daunting at all.
    EDIT: I can't tell from your photo, but are you getting a blue/indigo line at the cut-off (like Acura headlights achieve)?
    SOLD 2015 Daytona Gray S4
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by SteveYem View Post
    You're welcome!
    Yes, there's a thin 'rainbow' strip at the cutoff line.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by Dannydyn View Post
    You're welcome!
    Sweet. Lenses ordered!
    Veteran Member Three Rings kobrian85's Avatar
    Oct 23 2012
    Danny - Maybe I missed it... Do you have to add more sealant to the assembly when you are ready to button it up? Or just reheat the existing sealant and press the two halves back together? If more sealant is needed, what did you use?
    Fantastic DIY, thanks for the effort.
    Dec 20 2013
    Mercedes Benz ML350
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by kobrian85 View Post
    You didn't miss it. I didn't add any sealant, just reused the existing one.
    Based on the research I've seen from other people, most don't add their own sealant, but rather reuse the existing one.
    I haven't washed the car since, nor has it rained, so I don't for sure yet if the seal is good. I've seen people who added sealant just for added measure, but the vast majority do not.
    I think any type of heat resistant silicone at your local hardware store, should do the job.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Fantastic write-up with photos. I'm in awe with how amazing the cutoff is with the new glass and how little light bleed there is above. Do you have a before as a comparison? I doubt I'll try this project and will end up paying my buddy to do it. I just don't have the patience and determination like you. Very well done!
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    nice work Danny. afraid to do this myself! But,,, definitely one of the most detailed DIY's I have ever seen, both on AZ and other forums in my past car lives.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by zcspec View Post
    Sorry, I don't have before shots because I swapped both lenses during the day.
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by XxSullyxX123 View Post
    Thanks Sully!
    Apr 05 2016
    Portland, OR
    I've contacted a few local shops to see what they would charge for this.
    I will post some figures up once they get back to me. If it is anything astronomical I will probably just do them myself.
    Geoff
    Established Member Two Rings 300zx2g35's Avatar
    May 03 2016
    SoMD
    Thank you!!! I have been searching trying to find what lenses fit our projectors and this finally answered my question.
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by 300zx2g35 View Post
    You're welcome
    Good luck!
    Established Member Two Rings S4Robo's Avatar
    Aug 30 2015
    Royal Oak/MI/Mid West
    Awesome write up man! Which lens did you order? I see they have 4 different ones you can choose from. Looking to do this on my B8.
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Just received the zkw-r 3" lenses, new headlight cover replacements (lenses too) from Bulgaria and some new butyl sealant from lightwerkz. I have a b8 so the disassembly will be a bit different. Gonna take pictures too!
    Jul 16 2010
    Colorado
    Just finished replacing the bulb lenses and covers... and let me tell you that it definitely isn't easy. The pre face lifted headlights are a lot more intricate and need to be removed piece by piece carefully. I don't have any experience taking apart these headlights regardless any headlight and it took about 4 hours each.
    One thing that really annoyed me was how delicate the chrome paint is. I managed to peele some of it off removing the parts that I taped over. (definitely use plastic wrap as its way less forgiving) but, even a little paint came off using that too.
    If your are brave enough to do this you need to dedicate an entire day if you've never done a lens swap
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by EHesh14 View Post
    Glad you were able to swap them. It's not easy, and requires quite a bit of patience, but well worth it.
    Also, I agree on the delicate 'chrome' coating. I managed to scratch it as well.
    My next project is to black them out, so thankfully that scratch is going away.
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by S4Robo View Post
    ZKW-R type (non-B or stock type).
    Dec 07 2012
    Atlanta, GA
    Is there a better best bestest as far as lenses?
    Apr 25 2016
    Anchorage
    Subbed
    Jul 16 2010
    Colorado
    I don't know, but let me tell you the clear lenses paired with Phillips extreme vision bulbs are so good. When you face the car and move your head around the light goes from white to gold! The cutoff is great of course with the zwk r from lightwerks. High quality and worth the price!
    Jul 16 2010
    Colorado
    Yea that would look really nice. Decided to keep the chrome and peal off the black plasti dip on the reflectors and painted them metallic silver for a classy OEM + look since meteor grey looks best with silver accents (wheels, trim, grille, badges).
    I really appreciate the DIY and high quality pictures they helped me out tremendously!
    Dec 20 2013
    Mercedes Benz ML350
    Glad I was able to help. That's what this forum is about. Great community to share and exchange information.
    You mentioned you painted them. I tried taking the shroud pieces apart so I can paint them separately, but got too anxious with swapping out the lens, and ended up plasti-dipping the whole shroud as once pieces. This meant I had to mask the LED bar, which in turn ended up looking like crap when removed the masking tape. On that topic: did you take the shroud apart - meaning separated it to the different pieces before painting them, or did you spray-paint the whole thing as one piece?
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Is there a way to take the LED bar out of the housing? I want to black out all of the chrome in the housing. I think it will look amazing with the rest of the black accents on my car...
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by poweredbyaudi7 View Post
    Funny you ask that, I'm in the middle of doing this same project. I have the headlight open in front of me. Trying to take the different shroud components apart. There's definitely a way, a lot of plastic tabs to mess around with....
    Dec 19 2006
    996TT
    San Antonio, TX
    Can you post a picture of what you are looking at? When I retrofitted my Tacoma I used Krylon Fusion satin black paint. Zero prep and it sticks extremely well.
    Jul 16 2010
    Colorado
    I think we're talking about two different things I just painted the orange reflectors that came apart from the shroud completely
    Dec 20 2013
    Mercedes Benz ML350
    In that case we are. I already had my amber corners painted, and had the LEDs disabled via Carista. I was paining the actual shroud. Pics of the final proudcut can be found in my >>>Build thread<<<.
    Jul 13 2015
    Central PA
    nicely done! Glad to hear it worked out well for you!
    There is way. I took mine off for the full black out. You just have to be very careful and separate ALL the plastic trim/shroud apart. It is basically held by a bunch of tabs and a few screws in places. Then you will be able to take out the LED strip (or what is just a round plastic tube).
    Tip: Before you put everything together, make sure you power your headlight installed and see of you like the focus of the cutoff line. I had to refocus the lenses by using small washers in the projector that holds the lens to the main body. Since the lens has a slightly different shape, the focus is altered.
