Results 1 to 11 of 11
    Oct 22 2015
    Wichita Falls, Texas
    Drivers side mirror adjusting with unlock button?
    2004 S4. When I'm unlocking my car from outside with the key fob one press will cause the drivers side mirror to start turning towards the outside until I press the unlock button again as if I were trying to unlock all the doors on the car. I seem to be having this issue intermittently. It'll do this 9 times out of 10 for maybe a week or two then wont do it again for awhile. It's quite annoying as I have to adjust my mirror back to the correct position every time I get into my car. Any help you guy/gals have would be greatly appreciated.
    May 18 2012
    2005 S4
    Portland, OR
    Yeah, mine has done this too and I have no idea why. Quite annoying.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    that's the weirdest thing i've heard
    May 18 2012
    2005 S4
    Portland, OR
    Also, I think the last time this happened I pressed the seat memory button that I had set (which sets mirrors too) and it didn't fix it. So it actually overrides the mirror position entirely.
    Probably some weird body control module glitch.
    Oct 22 2015
    Posted the same thing in the A4 forum. Might have something to do with the seat memory settings. Clearing the seat memory and resetting it with the key fob may be a fix to the problem. Either that or piece that calibrates and adjusts the side mirror may be bad.
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    have you tried turning it off and on again ??
    I mean disconnecting the battery for a couple of minutes
    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    Quote Originally Posted by jakeoboy67 View Post
    What, are you an IT guy? Lol
    Sent from my Nexus 6 using Tapatalk
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by evildsmr View Post
    lol, you never know
    May 18 2012
    2005 S4
    Portland, OR
    I had my battery disconnected for a couple of MONTHS while dealing with a plethora of engine crap. Made no difference.
    Nov 03 2011
    All Over!
    Water ingress.
    1986 Type 85 Audi 90 quattro
    Veteran Member Four Rings Hyde's Avatar
    Sep 05 2008
    Northwest Florida
    I usually turn this feature off because the same thing was happening to me (driver side as well). Eventually something broke within the base of the driver side mirror so that it wouldn't fold in or out properly, and when I bought a replacement one from a forum member, the problem I shared with the OP disappeared.
