Results 1 to 3 of 3
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: Valeo Clutch Kit/Single mass Flywheel Conversion | B5 S4
    Dual mass flywheels are nice in theory, until you have to foot the bill for a new one. Ouch.
    Don't worry, we have a solution you and your wallet can live with. Just install our complete Valeo single mass flywheel kit. An exact fit replacement for the dual mass system, it comes complete with a new friction disc with damper springs, fresh release bearing, and installation hardware.
    Unlike the dual mass, the single mass flywheel can be resurfaced in the future to extend its service life even more.
    Don't Slip Up
    Fits:
    Audi B5 S4 2000-2002
    Jason
    May 16 2008
    WA
    Does this particular single mass work with any other clutch and pressure plate combos?
    If so: Will the single mass be available on its own. Would be a shame to be forced into buying the package if you will never use the included pressure place and disk you had to pay for.
    If not: will a higher holding capacity clutch be available in the future? Otherwise it seems like a billet non-diaphragm aftermarket diverter valve that can only function at the stock 10psi. It has a good foundation but is just a few steps away from expanding their potential customer base.
    It seems most people who switch to a single mass are in the process of adding more power to their car anyway. If there is still a bone stock B5 out there, chances they will just go with a new bone stock OEM dual mass in keeping with the "OEM IS GREAT" mindset that helped them fight off the temptation of more power all these years. lol Or have their original resurfaced by a shop with the correct setup to do so to the tune of <$200
    Either way its nice to see new products being developed and added for this chassis, hope this package is expanded in the future with additional options.
    Oct 02 2006
    Wadsworth,OH
    You can only use the pressure plate and disc included with the single mass flywheel from Valeo. Unfortunately there is no higher holding capacity pressure plate and disc that will work with the Valeo single mass flywheel.
    We do have the Fidanza light weight flywheel that is also single mass and you can use OEM, Spec, South Bend, and Clutch Masters kits with it.
    The advantage of the Valeo kit is you can replace both the clutch and flywheel for a great price if you don't have any plans to go over stage 2 power.
    Jason
