Results 1 to 1 of 1
    Jan 12 2010
    SE Pennsylvania
    Another Chipwerke Pro Thread...and Drive Select Settings
    Thought I'd try add some driving experience and feedback regarding my CW Pro.
    I have no other performance mods.
    Installed, then disconnected battery (neg) terminal and left this way overnight.
    CW Pro set to 5-1
    Using 93 0ctane .
    I will experiment with drive select engine/transmission settings to determine if there are any differences and/or if certain settings are "better" than others.
    Some terminology I will use when discussing dsg shifting...
    "early" refers to change in gears happening at lower rpms, compared to before CW install,
    "quickly" refers the time it takes the dsg to change from one gear to the next gear.
    "jerkiness" will refer to unacceptable shifting feel
    Setting I-Comfort-dsg shifts early from 1-2-3-4-5 to D6 by 40 mph. No jerkiness but "surprised" by (short) shifting happening within 800-1000 rpm (this early) with moderate acceleration.
    Acceleration feels better with more responsive throttle.
    Setting II will be with drive select in dynamic
    Setting III will be in manual mode
    I'll update my findings as I drive in different driving conditions and for enough time to be able to add to this post.
    What have your CW Pro experiences been, with acceleration, dsg shifting, feel, etc. in the different drive select settings?
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
