Results 1 to 4 of 4
    Jul 30 2010
    Los Angeles, CA, 90094
    F&R Sway Bars ontop of Coilovers, Yay or Nay?
    So i recently got a set of Bilstein PSS10's and am pretty damn excited to get them on my car.
    The question i have for the forum is whether or not you guys think a Front and rear sway bar is necessary with the new coilovers? Now obviously, nothing is necessary, but just based on personal experience, does the sway bar make a huge difference ontop of coils?
    Also, if i were to get sway bars, are the end links really worth getting as well?
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Based on several threads in this forum, upgraded end links are not needed unless you do tracking. Sway bars are not only to reduce body roll in the corner, which PSS does well, but also to reduce understeer (rear) and give better turn-in feel (front). Therefore sway bars are very beneficial even on top of the coils.
    One thing you can save is the front sway bar. This car tends to understeer, adding a stiffer front sway bar could make the understeer worse although you get better turn-in feel. The rear sway bar is a must in my opinion.
    If you get both sway bars, be sure to set front softer and rear stiffer.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Get them both. Front soft rear stiff. I have the end links but not sure what they're actually doing...
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    In my no sports diff car I only did the rearARB/sway.I can now get myself a touch of oversteer when needed
    To enhance steering feel I fitted an uprated strut brace
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
