Results 1 to 2 of 2
    Sep 14 2015
    portage, mi
    alzor 881 question
    so i just received my alzor 881's. ecs had them on sale for $38 each because they didnt have center caps, so it was a quick impulse buy. today i was looking at people who had them and noticed that everyone is running 5mm spacers. do i have to run 5mm spacers? and if so, what length lug bolts because i am going to be buying conical seat for them
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    Most people use spacers for looks, and or clearing their front brake calipers. Have you test fitted the wheels? If so you may want to use spacers for looks, now if they start to hit your caliper then add the 5mm spacer and they should be good to go. As for bolts for a 5mm spacer you can use the stock size lug bolts no problem. I have done it before with plenty of threads to seat the wheel no problem. When you go up to 8mm or 10mm that is when you are in need of bigger lugs
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
