Does anyone know if an alignment check would be standard procedure for an Audi tech when doing a CPO inspection on a car? I purchased a 13 S4 DSG and no where in the paperwork does it say anything about checking alignment specifically, but it does say they did the 35k mile maintenance (car had 24.5k miles when purchased). I am pretty sure based on tire wear that at least the rear alignment is off, (toe most likely) the outside of the tires seems to be wearing faster than the inside. I will have them check it when i take the car for an oil change in about 2 weeks but i'm wondering if I have a case here to prove that they should have checked the alignment and didn't.
If I do have a case should i push to have the tires replaced? I have driven about 8k miles so far since purchase and it has only been about 3 months.
Thoughts?
