Results 1 to 18 of 18
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    Oil on upper intercooler hose
    Why is there oil on intercooler hose the one connected to throttle body. It's right by the clamp area and you see oil on frame and some on belly pan also. Is this normal? Maybe the hose is deteriorating?
    Sent from my SM-G900T using Tapatalk
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    Unfortunately that's common with this platform. The intercooler pipes collect some oil blow by from the turbo. If it's only a few tablespoons, just empty it out periodically when you do oil changes. If more, it could point towards a failed PCV or worse case deterioration of your turbo bearing. The drivers side typically collects the most. The hose usually does not deteriorate but your clamp may have loosened thereby permitting some of the oil to migrate topside during boost. Some find that a catch can eliminates this issue and kelps keep the pipes dry.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Quote Originally Posted by 67Twisty View Post
    What he said. Pull those IC pipes and see what comes out. Are you having any oil consumption issues?
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Oct 01 2014
    Audi Q5
    chicago,il
    I only use 1/2 quart to 1 quart of oil in between oil change. I might have to pull the IC hose. Pcv seems fine did the oil cap test no problem get it out. I think I have a boost leak also bc I'm on jhm stage 2 and my buttdyno don't feel like it's pulling hard.
    Jun 27 2011
    That seems like a lot of weeping. I would make sure the TB hose and MAP sensor area aren't leaking air past. With that comes a bit of oil in the intake (which is normal/unavoidable to an extent with turbos).
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Worse than mine but I had the same issue recently...Just cleaned off the area completely, pulled on the hose a little, and re tightened the clamp with a flat head and now its been dry for a new days so all good
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Established Member Two Rings snappytom's Avatar
    May 27 2015
    Wheaton, IL
    I came across this video on draining the intercooler a few weeks ago. Next time I have the car up on stands I plan to give it a shot and see what comes out.
    https://www.youtube.com/watch?v=BO5Q55zggXY
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Quote Originally Posted by snappytom View Post
    My god what a lazy way of being a tech. I'd be pissed if someone did that to my car.
    Dec 19 2012
    Europe
    WTF?? He drills into the bottom of the intercoolers and later plugs the holes with screws...Pretty nice way to ensure a permanent leak in the future
    Jun 27 2011
    Considering that removing a IC hose takes all of 10 seconds and requires only a flathead screwdriver, I'd say that video and the monkey in it are fucking retarded.
    -CP
    2017 Q7 3.0t
    Feb 15 2016
    Cambridge,Ontario
    I couldnr realy see was that plastic he was drilling into or a rubber hose . ? if it was thick enough to tap and put a plug and seal in it may not be a bad thing. just looked like a thin plastic or rubber hose though.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 27 2011
    The IC ends are plastic. Probably that. Still idiotic though.
    -CP
    2017 Q7 3.0t
    Feb 15 2016
    Cambridge,Ontario
    " I Just plug it with a wood screw " .. yikes !!!
    that guy actually does some good vids so this one surprised me . oh well.
    if you want a complete walk through of your stat this guy does a great video beginning to end. helped me immensely
    1976 Yamaha XS 360
    Oct 01 2014
    Audi Q5
    chicago,il
    I watched that video and I thought that's the stupidest idea drill a hole to drain the oil and plug it with a screw. It's up on a lift just disconnect the hose simple as that. Whoever that car is might have leak now. I had this car for 8yrs so definitely sure there's quite some oil on IC hose. Since these hose are aging gonna get some silicone hose and swap these out.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by miA4 View Post
    I'm with you. If I found this, I'd be pretty pissed.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    May 27 2015
    Wheaton, IL
    In hindsight I agree that drilling the holes and plugging with screws is a shoddy way of doing this .......
    Feb 15 2016
    Cambridge,Ontario
    wow talk about your amazing timing....
    When my son headed to work yesterday the car sure enough had left a decent size mark . I decided to drop the pan and tighten up the oil drian plug .. hmmmm its dry .. uh oh where is it coming from ? after about 30 seconds I saw an oil drop on a clamp and because of this thread I new exactly what it was and not to panic. Took about 200ml from the drivers side. Something I would consider normal from a totally neglected car. the clamp was really loose so it collected enough then started dripping.
    While in there I did the passenger side , exactly one drop . cleaned it up tightened the clamp , put the pan back on and out of the pits she goes.
    Another baseline project done for me to monitor.
    1976 Yamaha XS 360
    Feb 21 2015
    Rip City
    Sounds pretty normal. My IC piping used to fill up with alarming amounts of oil - like 1/3 to 1/2 a quart, and I was having to add oil often. Gave me crazy predetonation issues.
    Replaced my turbo last weekend and its running like a champ (thanks vortexjunkie) but I haven't checked the ICs yet.
