Results 1 to 11 of 11
    Oct 12 2015
    Montreal
    1.8T B5 2001 help issue cant go to work anymore
    I have 1.8T B5 2001 and having issue like its under water, i changed coil pack and body throttle bit no change still breathing hard, so i decided to remove plug on throttle body and it stopped but car went into limp mode 20km/h max acceleration , so i plugged it back and problems started again. Please help dont know what else to do
    Oct 12 2015
    Montreal
    Here is video of sound when idle
    https://youtu.be/2rCKLDuhC5k
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    throttle body adaption
    2000 S4- Working?
    Oct 12 2015
    Montreal
    Quote Originally Posted by redline380 View Post
    ?? You mean remove battery for 10 min and plug it back in and the key in ignition turn and leave it for 5 min remove key and start car????
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by neil1976 View Post
    either that or a hard adaption with vag come
    2000 S4- Working?
    Oct 12 2015
    Montreal
    Vag come hmm sounds dirty but please explain ? Lol
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    use teh googlez
    2000 S4- Working?
    Oct 12 2015
    Montreal
    I got it, ill do the steps and if nothing ill go buy obd2 to reset
    Oct 12 2015
    Montreal
    use teh googlez
    You think it could be other issue, i thought CCT but it should continue even after removing plug from throttle body right?
    Dec 05 2007
    You def need to do a throttle body adaption with VSDS or a similar program. You can not just throw on a different throttle body. It is an electric component and was adapted to the last vehicle it was on. Doing it with battery cable removal and leaving key in the starting position afterwards won't cut it. That only basically adapts it to it's old adaption, like a reset button. This requires a full throttle body adaption only capable programs can do.
    Hopefully someone close to you will let you use theirs. Try the regional section and ask, or mahbe someone here will chime in. But I don't recall too many b5 montreal owners on here. More b6 guus, so you can try posting a thread in their chatterbox section too, in hopes one will respond. After that, we can try and help you further. But your engine does not sound the greatest...like a bad cct.
