Results 1 to 4 of 4
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Rear o2 Sensor question
    What's up guys!
    I wanted to do a little maintenance last weekend but was foiled by being stumped on trying to get my rear o2 sensor out. I recently replaced my exhaust system with HF 3" Cat, rear o2 extender, new down pipe and cat back so this thing has been off before. My issue was that I had no room to get it off even with o2 sensor wrench. I removed my airbox and all miscellaneous hoses out the way while was turning to the left on the rear o2 sensor leaning over the passenger fender, was this correct way or I had to turn to the right? I really hope I wasn't tightening it instead of loosing it.
    Nathan
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    If you are leaning over the passenger fender, you would be twisting it to the right. Seems you were backwards
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    That one likes to be difficult. I've got the 034 HFC + 034 spacer on mine.
    I use the stubby O2 sensor socket and a wobble extension with a ratchet. Then just get the proper angle on it and turn it little-bit-by-little-bit.
    It may help also that I use 034's super-high-temp antiseize paste on the threads.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Apr 26 2010
    North Jersey
    Quote Originally Posted by redline380 View Post
    I figured. There wasn't much space to turn the wrench in between the false firewall and the engine block. I think its like 3-5 inches...
    Quote Originally Posted by MetalMan View Post
    My installer put on my exhaust and I have no idea if he used antiseize. I hope he did! If I can't get it out by myself I am going to reach out to them.
