Results 1 to 14 of 14
    Sep 29 2010
    Portland, Oregon
    Ride Height Off?
    Last night I let a friend of mine drive my car as I followed in his. After a while behind my car, I noticed the rear left was a smidge lower than my rear right. Curiosity kicked in and when I arrived home I decided to measure.
    Parked my car in the garage (which is level) and measured the following: Fronts (L&R) @ 25.5" FTG, Rear Left @ 25.75" & rear right @ 26".
    Current Suspension Setup: Bilstein Sport Shocks w/ H&R Sport Springs. Car hasn't been involved in any accidents, alignment is within spec, tire pressures match, have half a tank of gas, etc.
    Anyone here have an idea of what could be going on?
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Bilstein B8?
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Sep 29 2010
    Portland, Oregon
    Quote Originally Posted by Dannydyn View Post
    Bilstein B8?
    Correct. Bilstein B8 Shocks :)
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by mpower3o2 View Post
    Oh boy, I have this setup (B8/H&R OE) on order...
    Sep 29 2010
    Portland, Oregon
    I doubt you have anything to worry about. Have another friend with the same setup and his is just fine.
    Just trying to see if someone might have run into a similar issue that could help guide me to a solution.
    Love the ride & handling!
    Dec 20 2013
    Mercedes Benz ML350
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Did you drop the rear subframe with the install? If so it might be ever so slightly misaligned. I needed to extend one of might rear coilovers compared to the other side due to this issue.
    Also try measuring again, the heights vary depending on the ground and parking position. You more or less need the average of all FTG measurements in 4 or 5 parking situations.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Oct 14 2012
    Empty...for now...
    SE PA
    The fact that you noticed a 1/4" difference from a distance is impressive, but once noticed I'm sure it is bothersome. I'm not sure if this is even related, but on both my old B8 and my current B8.5 the distance from the rear wheel hubs to the fenders on both sides is different. I have read in various places on this forum that it's due to the rear subframe being misaligned relative to the chassis, and specifically in both cases for me the rear passenger side wheel hub sat closer to the fender than the rear driver side. The effect is that the wheel+tire on the rear passenger side sits farther out than the same wheel+tire on the driver side, when the wheel alignment settings are equal on both sides. Maybe the subframe misalignment also affects how the springs seat, resulting in a difference in ride height from side to side? Probably not, but maybe worth considering.
    Or maybe the spring on the passenger side is not fully seated at the top and/or bottom perch? Typically there is a recess in the perch for the end of the last coil to sit in, but maybe the end of the last coil on that spring is not fully seated against the end wall of that recess?
    SOLD 2015 Daytona Gray S4
    Sep 29 2010
    Portland, Oregon
    Quote Originally Posted by B8 S4 View Post
    I bought the car used a while ago w/ Super Sport springs. Wondering if the previous owner's shop dropped the subframe or not.
    Thank you for the advice, I'll have my shop check the subframe alignment!
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Did you get your car corner balanced? If you did the heights won't be the same on all corners.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Apr 27 2014
    United States
    Quote Originally Posted by creativecody View Post
    He doesn't have coilovers.
    435I 6MT - Daily
    Sep 29 2010
    Portland, Oregon
    Quote Originally Posted by SteveYem View Post
    I just had the suspension installed about 3 weeks ago. I might have to ask my shop to check the subframe alignment and possibly fix if they find something. I know they didin't touch the subframe.
    I'm in the same boat as you though. Curious if a misalignment affects how the springs seat, etc.
    Oct 14 2012
    Empty...for now...
    SE PA
    In my case, the best I can figure the subframe is shifted about 5mm off-center. [I say this because last week I installed a set of wheels+tires with 10mm spacers in the rear, and the passenger side was rubbing severely while the driver side was not. Visually, I could tell that the pass. side tire sat closer to the fender than the driver side. I replaced the passenger side spacer with 5mm and the problem went away, both rubbing-wise and aesthetically. Camber angle is the same on both sides].
    It doesn't seem right that a ~5mm horizontal shift would cause a ~6mm [0.25 inch] vertical shift, but I'm not sure what else it is except for maybe a manufacturing inconsistency between the two springs.
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    Put some air in one tire
    Sent from my beeper
    @martino_motorsport
