Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
  1. #41
    Established Member Two Rings p310b's Avatar
    Jan 15 2016
    Indonesia
    12.5V , when not running. 12.5-12.7V when idle.
  2. #42
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Do a draw test maybe? See if you have a draw thats crazy high.
    Any aftermarket electrical stuff installed? Anything plugged into the cigarette plug?
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
  3. #43
    Jan 15 2016
    Indonesia
    Just an aftermarket HU, and a phone charger. Those were there before this happened but I'll try.
  4. #44
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    How about the voltage regulator? You should be idling around 14V.
    Voltage regulators are supposed to limit the voltage to 14.3 so it could be limiting it too much either because of a bad ground or too much resistance between the regulator and the battery
    Sent from my SAMSUNG-SM-G925A using Tapatalk
  5. #45
    Jan 15 2016
    Indonesia
    Strange problem -will paypal some $
    The voltage regulator is new from the rebuild alternator. I was hoping a bad ground too, but haven't able to find it.
  6. #46
    Oct 24 2015
    Perth, WA
    Please check the multimeter battery first. It will give you erroneous issues if its bad.
    My respray thread
  7. #47
    Jan 15 2016
    Indonesia
    Replaced the batt twice. Still checking wires at the garage.
  8. #48
    Jan 15 2016
    Indonesia
    Replaced battery harnesses, got 13.5V on idle but still those code is not going anywhere. G247 malfunction code when the sensor is upluged, and 2 cdes when I pluged G247 , the codes are P0652-002 sensor reference voltage B to low and P2127-002 acc position sensor signal too high
  9. #49
    Oct 24 2015
    Perth, WA
    Replace the fuel rail sensor and if that doesn't fix it then move on to the HPFP. Also just double check all your earths, voltages at different points. And finally, please replace the multimeter battery, a common issue that provides incorrect values.
    My respray thread
  10. #50
    Jan 15 2016
    Indonesia
    Bumping up...
    So its been 3years ago.
    My car was mostly in a garage.
    And this past few months I brought it up to an Audi dealer.
    So far have been replacing HPFP, ECM. G247,G410, G31. And only one problem remains a52230b0-7802-46d5-82d1-e71f244ea131.jpg if anyone can help i replaced hpfp with an seeded part number do i have to replace the G410 the updated one. The one that i use belonged to MKV that happended to be in the dealership. The dealership even attached my G410 and G31 to the MKV. And everthing was fine except in my car. Thanks for everyone who can help.
  11. #51
    Jan 15 2016
    Indonesia
    P0652 will pop up if i plugged g247. If I unplugged it I will get P0190
  12. #52
    Jan 15 2016
    Indonesia
    Bump
  13. #53
    Established Member Two Rings KingKostas's Avatar
    Oct 13 2017
    Long Island, NY
    U have to use parts that are for ur specific vin number, parts may “work” but theres many differences. Get the correct hpfp
  14. #54
    Jan 15 2016
    Indonesia
    Yep, i have a correct Hpfp vin spesific. But old g410. Do i need to update the g410 as i have the superseeded hpfp.
