Results 1 to 6 of 6
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    :: Excelerate Performance :: SPRING SERVICE SPECIALS
    EXCELERATE PERFORMANCE
    What is a Timing Belt and why is it important?
    What is a timing belt? The timing belt is crucial to proper engine operation; the timing belt maintains synchronization and control of the timing components. Components such as the crank(s), camshaft(s) and operation of the valves to allow the proper amount of intake air and exhaust gas flow. Why is replacing your timing belt useful? The timing belt is a rubber product and resides in a sensitive environment where it experiences extreme heat cycles. The extreme heat cycles and constant tension. The heat cycles and tension cause the rubber to dry out and stretch. If this happens it can be catastrophic and cause complete engine failure. It comes highly recommended that one follows factory recommended maintenance intervals because if you wait too long you may wind up in a bad situation with an even bigger problem. We consider this preventative maintenance, replacing parts because it’s a problem.
    Kit includes: Timing Belt, Tensioner Pulley, Idler Pulley (if applicable), Hydraulic Damper (if applicable), Water Pump and Gasket, Balance Shaft Seal (if applicable), Camshaft Seal
    Comprehensive parts kit:
    • Hydraulic Damper – For applications requiring the use of a hydraulic damper, Pro Series timing kits contain an OE-quality unit ready to go. One less thing to slow you down.
    • Water Pump – An OE-quality water pump is included in all Pro Series timing kits, along with any necessary seals and gaskets. In selected cases, we even offer an option of metal or plastic impellers and a choice of housing or no housing.
    • Timing Belt – A durable OE-quality ContiTech timing belt is the heart of every Pro Series kit, and it’s covered by a written guarantee that matches the vehicle’s original service interval.
    • Idlers – All necessary idlers and pulleys for the belt path are included in Pro Series timing kits. OE-quality, of course.
    • Tensioner – A Pro-Series OE-Quality tensioner will keep the proper amount of tension on the timing belt system.
    • Cam & Balance Shaft Seals – The new Pro Series Plus kits add these critical seals to the already strong Pro Series parts list. (Recommended But Not Included – Additional Labor Also Required)
    PRICING
    • VW TRANSVERSE 1.8T - 5.5 hours of labor - $799 - Kit includes: Water Pump with Metal Impeller, Timing Belt, Tensioner, Damper and Cam Seals. - (Interference Engine)
    • VW/AUDI LONGI 1.8T - 6.5 hours of labor - $899 - Kit includes: Water Pump with Metal Impeller, Timing Belt, Tensioner, Nut, Washer, Damper and Cam Seals. - (Interference Engine)
    • VW TRANSVERSE 2.0T FSI - 5.5 hours of labor - $799 - Kit includes: Water Pump with Plastic Impeller, Timing Belt, Tensioner, Idler Pulleys and Bolt - (Interference Engine)
    • VW/AUDI LONG 2.0T FSI - 5.5 hours of labor -$799 - Kit includes: Water Pump with Plastic Impeller, Timing Belt, Tensioner, Idler Pulleys and Bolt - (Interference Engine)
    • AUDI 2.7T - 6.5 hours of labor - $949 - Kit includes: Water Pump with Metal Impeller, Water Pump Gasket, Timing Belt, Tensioner Pulley, Tensioner Damper, Idler Pulley, Bolt and Cam Seals. (Interference Engine)
    • VW 1.9 TDI - 4.5 hours of labor - $699 - Kit includes: Water Pump with Plastic Impeller, Timing Belt, Tensioner, Idler, and Cam Seal. (Interference Engine)
    • VW 2.0 TDI - 4.75 hours of labor -$799 - Kit Includes Timing Belt, water pump w/metal impeller tensioner pulley, idler pulley, ideler pulley w/bolt, relay roller, & installation instructions.
    Tire and Alignment special
    Purchase 4 Michelin tires from us, have us mount and balance them with Hunter Road Force and receive $50 off your alignment.
    Carbon Cleaning Special
    Walnut blasted and finished by hand.
    • VW/Audi 2.0T TSI/FSI – $699
    • Audi 4.2 FSI – $999
    • Inquire for Audi V10
    Brake Fluid Flush
    Brake Fluid should be flushed once a year or every 20k miles. $129 with MOTUL DOT 5.1 (up to 1 liter)
    CLICK HERE TO SEE OTHER OFFERS
    Check Us Out on Social Media!
    Established Member Two Rings jerrone's Avatar
    May 25 2013
    Detroit, MICHIGAN
    That A5 at the Uconn Carshow last month was amazing!
    Forgot the guy's name who I spoke with at the show, but I'll definitely be over there to see you guys soon.
    Do you guys do tuning also? Any idea of price?
    Do you Sell H&R suspnsion?
    2004 Audi A4
    1.8T manual
    Stock engine
    magnaflow 2.5" Turbo-back
    -Jerrone
    Silver B6 USP.....Ming Blue B6 Sport......Hibiscus B5 S4 clone.........Dolphin B6 USP Conversion
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Quote Originally Posted by jerrone View Post
    2004 Audi A4
    1.8T manual
    Stock engine
    -Jerrone
    Hi Jerrone,
    That may have been me (Gregg) and/or my car at the Uconn show. Awesome crew at Excelerate, they definitely do tuning and my H&R suspension was purchased and installed by them as well. Worth the trip to see them, I'm always looking for reasons to visit.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Feb 14 2014
    Audi's
    Branford, CT
    2004 Audi A4
    1.8T manual
    Stock engine
    -Jerrone
    Jerrone, if it was the black car you saw, it was Gregg's S5 (the poster below) We most certainly do sell H&R and offer APR software for these cars. We can also get just about anything for these cars. We probably even have parts in stock for the B6. Shoot me an e-mail and I would be happy to put together a quote personalized just for you. [email protected]
    Thanks,
    Greg
    Quote Originally Posted by Powderhound View Post
    Hi Jerrone,
    Its been a while, stop on down anytime. Its spring time and I'm sure you're getting the itch. I have some updates for you too.
    Feb 14 2014
    Audi's
    Branford, CT
    Tired of warm 85*+ air trying to cool you driving with the windows down? Beat the heat with a fresh A/C Service!
    Feb 14 2014
    Audi's
    Branford, CT
    More customer taking advantage of carbon cleaning specials and more as the offers end. Still time to save!
    See our service special page for more exciting offers!
    http://excelerateperformance.com/servicespecials
