Results 1 to 7 of 7
    Veteran Member Three Rings GB5's Avatar
    Mar 12 2009
    SoCal - 92503
    Need Help: Car turned off while driving and did not start again.
    Hello everybody,
    As stated in subject my car turned off while I was driving and couldn't started again. Car stalled and then stoped.
    I did timing belt about 15k miles ago and was my first thought. I opened the hood, checked the TB and it is there and intact. I removed the oil cap and tried to start the engine but i see parts are not moving.
    Any ideas?
    What should I check?
    Can I consider the engine's gone?
    My car: 2001 A4, 5sp, FWD.
    Thanks for your help and advise!!!
    Dec 05 2007
    Unplug your maf and see if she will start.
    Nov 03 2011
    All Over!
    Quote Originally Posted by GB5 View Post
    Hello everybody,
    Any ideas?
    With the highlighted part of your post, possibly your crank sprocket keyway has sheared off.
    I would tear down the front, and check the timing.
    1986 Type 85 Audi 90 quattro
    Dec 05 2007
    ^Missed that part. Honestly, I only read the title and maybe first couple of lines.
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    Did you take a better look at it yet GB5? I'm curious to know what it was that caused this.
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Mar 12 2009
    SoCal - 92503
    Thanks guys for your feedback. So far I haven't been able to check the car..... crazy schedule at work but I think I'l be free this weekend and will check the car.
    Sep 09 2015
    Philly
    Check your timing fuses. This happened to me the other day, a few lights flickered on and off on my dash, engine stalled, would crank but not start...checked fuses, one was blown, replaced it and she's back to normal
    Sent from my LGMS631 using Tapatalk
