Results 1 to 9 of 9
    Apr 24 2016
    California
    Recaros installed in the front, rubbing on console
    I'm going to take out the passenger seat and make sure I didn't bend any rails in transport/install, but does anyone have any input on this, is it normal for Recaros to rub on the center console? If I adjust the seat at all it makes that terrible leather fart sound, and even just driving I can hear the seat rub and make sounds when I go over bumps etc.
    Seats are from a 2008 S4, my car is an 05.5 A4. Thanks in advance
    Nov 13 2011
    b7 s4 avant
    thats normal. i can't imagine that if you somehow bent the rails that you could have bolted it into the car. Also, the consoles are the same size.
    I drive a truck now.
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Mine dont rub, in fact, i actually see a gap in between the center console and the seat. On my stock seats though, it was pretty normal for them to make some squeaking noises on the center console.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Mine rub only if I move them all the way forward.
    Established Member Two Rings L'Audi's Avatar
    Apr 06 2016
    Long Island, NY
    OP.. How tall/short are you? Those seats only rub when they're waaay forward?
    06 Dolphin Gray tip 2.0T
    GIAC Xplus | USP Testpipe | RevMotoring Springs | 19X8.5/9.5 Niche Targa | pioneer 80PRS | Taramp's HD1200, HD8000, HD10000 | 18-Sound 6's | B&C 8's | Audiocontrol Three.1, Audiocontrol Epicenter | Clarion EQS746, MCD360
    Apr 24 2016
    California
    Quote Originally Posted by L'Audi View Post
    I'm 5'11 but I should specify only the passenger seat has this issue. It rubs on the console in the front when it's moved way forward, but in any position it also rubs near the back of the console, which like I said makes little squeaks and rubbing noises as I'm driving normally. Also the fore/aft adjustment is, for lack of a better word, pulsing as it adjusts. Instead of a solid constant motor movement, it seems to have some obstruction which causes it to cyclically have more and less resistance as it spins. Hard to explain maybe I'll put up a video of the sound. This is what caused me to think the rail might be bent or something.
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Mine rub when all the way forward too
    Jun 17 2013
    jersey city nj
    x4 on the rub all the way forward
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Mine squeaked for a bit too. I just used some leather conditioner for a while and it stopped making noise.
    2018 A5 S-Line Manual
