Results 1 to 20 of 20
    Aug 12 2013
    Lexington KY
    Got and Installed Chipwerke Pro Last Night: Reflections
    Overall, I'm happy. Hell, overall I'm elated. I purchased it from another guy who was getting an RS5 so I was fairly confident he wasn't having issues but was just getting a new motor (V8). The unit came yesterday and I was proud of myself for waiting to install and going to the gym first. Got home, and even before showering, I unboxed everything and installed. It's really a 10 minute install. My harness was already prepped with zip ties so I just installed everything as he had it. It's just unplugging two map sensors, plugging the harness in and then the sensors into the harness. I ran the box over behind the drivers side headlight and ziptied it to a cooling line. I'll go back in and do a better job of installing /cleaner job later.
    So, I go out and I just felt this goofy grin coming over my face. You can feel it for sure, even at lower speeds. I finally get to a spot I can open it up and in S auto mode, I got a bit freaked out. It short shifted first and then second, but you could still feel the power. I flipped over to Manual and it was awesome. A little hesitation at first, but it really came together after about ten miles. I think all of it was stemming from adapting to the car even after resetting codes before starting the car. I'm thinking I'll beat on her for a week and it should get even better.
    Best way to describe it: a stupid, poo eating grin as your RPMs are climbing. I can think of no better analogy. I went back into s/auto mode and the short shifting seemed to dissipate as well as much of the delay. I think any delay I'm feeling now is only in my mind bc it just initially freaked me out.
    I may pull my positive battery cable tonight just to ensure I'm doing everything but overall, I'm a happy camper. I did freak out while testing it in manual mode. I floored it in second gear at one point and it took off and then immediately bogged down. I freaked until I saw it was the traction control light going off and I'd spun the tires. I turned esp/nanny state off and it was AWESOME. In my old SRTs, we would get diablo sport tunes and that was cool, but the power you get from this thing is ridiculous. Yeah, an ecu tune might be better/more power/more refined, but damn, for a quarter of the price and ensuring your warranty, this is a dag gone no brainer here folks. I just want to keep monitoring it and also make sure my install is exactly where I want it but overall, my grin's still on my face!
    Jan 12 2010
    SE Pennsylvania
    Great!
    Coincidentally, I had my cw delivered yesterday and installed it last night.
    I disconnected the negative battery terminal overnight and drove to work this morning.
    So I need more drive time to get a better read on the differences/improvements our cw will make.
    Good luck with your cw and let us know how things go over with moire driving.
    Do you have a 6MT or the DSG?
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
    Oct 30 2012
    Oxford, MS
    Seriously thinking of going this direction. How much did you give for it?
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Quote Originally Posted by 4wheelpilot View Post
    Great!
    since he is talking about being in S and D mode, its DSG
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Aug 12 2013
    Lexington KY
    Yeah,sorry: I've got a DSG car. It drove well this morning but I couldn't really get on it in morning traffic.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Ive had my Chipwerke on for about the last 10,000 miles and its been great. Good bump in power! I just got the box updated for stage 2 and bought the CTS pulley, curious to see how much power Chipwerke stage 2 has!
    Apr 22 2013
    maine
    I've got a lease and may consider this. Any concerns on a leased car I may need to think about? Seems like a reliable plug and play unit
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by ModItNow View Post
    Just installed my CTS pulley with updated stg2 CW pro two weeks ago. Didnt feel too much of a difference, I think that's due to I didnt reset ecu. The after-shift hesitation problem feels a bit more serious. I might change the settings to 3-1 later before I get serviced and $$$ and go for a 'proper' tune. The jerkiness is driving me crazy.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Oct 08 2015
    Quote Originally Posted by jzinckgra View Post
    No need to worry to much, just be sure to remove it before you go to the dealer you are good to go. Use VagCom to clear DTCs or leave the battery disconnected for a night after you install / remove CW is recommended.
    BTW:
    If you are looking to get some more power, CW is currently the only way you can go. You can also upgrade the intake but just be sure to bring it to stock before you go to the dealer, otherwise they can manually mark you TD1 if they are jerks.
    Also consider to upgrade: powertrain mounts, sway bars, brake rotors+pads, wheels+tires, interior leds, led turn signals and reverse lights. These mods are easy to install and reversible.
    Current: '18 M3 ZCP
    Apr 22 2013
    maine
    Quote Originally Posted by yjypm View Post
    BTW:
    Do I need vagcomm to clear potential codes or will disconnecting battery do the same?
    Oct 08 2015
    As for CW install/uninstall, they are the same. If you want to do other stuff like checking fault codes and doing some VCDS mods VagCom is very useful.
    Current: '18 M3 ZCP
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Interesting. I would definitely reset your ecu but also when I got my chipwerke back from from getting it updated for the pulley Murat said to use it on the 5-1 setting. This is for 91 octane also. Maybe your getting some bypass with the setting too low. I haven't installed the pulley yet so I'll see how it goes when I do..
    Sent from my SM-G925V using Audizine mobile app
    Oct 08 2015
    I actually drove to CW to get the update. I haven't checked the settings yet but I don't think they left it too low. It could be the crappy CA 91 too. Also, leaving the settings high leads to more jerkiness but leaving the settings low leads to less power. Such a headache.
    Current: '18 M3 ZCP
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Yeah I feel you, always runs better and smoother with higher octane. I'll probably go epl sooner rather than later!
    Veteran Member Three Rings ShopVac's Avatar
    Feb 02 2016
    BMW M4 Comp / Abarth 124 Spider / RDX A-Spec / Jetta / Elantra
    Pittsburgh
    I'm running 5-1 now...with 93 and a 6MT. Tossing in 5gal of e85 gives it a real nice boost, of which I was told I can take it to 7-1 without the pulley.
    I'm just happy that with the MT...I don't have all the lag issues the automatic folks are talk about. Only wish...that we has a little higher rev limit. Its so easy to hit in 1st...
    __________________________________________________ _____
    Proud owner of four turbos and one supercharger.
    Oct 08 2015
    I was about to pull the trigger on EPL until I saw 034 is working on a tune too. I will wait to see the result of 034's project while having 3k miles away from next service.
    Current: '18 M3 ZCP
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I'm sure that's going to be a solid option! 034 is only an hour and a half away from me too
    Oct 08 2015
    Well, 5 hrs from me... Lucky you. I guess you can call them to be an early bird. For me, 10 hrs drive for a tune is just not worth it.
    There might still be a long way for 034 to release their stg2 and dsg tune though. If I couldn't wait until then, EPL is a great option too.
    Current: '18 M3 ZCP
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I did contact them but whenever was successful in connecting with them unfortunately. Good luck to you and your tune!
    Oct 08 2015
    Thanks. I just need to wait.
    Current: '18 M3 ZCP
