Results 1 to 24 of 24
    Jan 26 2015
    Clemmons
    Brakes squeaking
    2014 S4 EPL Stage 2 have 33k miles on it, brakes squeaking at times. No pad indicator has come on yet but wondering if its maybe time for new brakes.
    If the answer is yes then should I just go ahead and upgrade all 4 rotors and pads to something else? I don't track with the car really just a daily that I push hard whenever I can get away with it.
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    The OEM brakes get noisey after 50% wear or if it gets cold. You can visually inspect the pads as well to see if you have enough pad material left on all 4 corners. If it's really bothering you, get some Akebono brake pads and call it a day, otherwise just use up the OEM brake pads and then replace them with the Akebonos when the brake light comes on.
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Welcome to the club, get used to the sqeaking.... - that's the response I got from AoA. They acknowledged the defect in material and claim they are actively working on remedying the problem, but it's still a wear and tear item, and so they basically blew me off...
    That's why I'm going swap my pads to stop techs, even though there's plenty of pad life left on my stock ones. I just can't take the sqeaking anymore. It's embarrassing.
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Jan 26 2015
    Clemmons
    Quote Originally Posted by Dannydyn View Post
    I complained at my 25k maintenance and got the same answer. It is embarrassing I agree so I would rather just go ahead and replace them at this point.
    Is there any reason to get new rotors as well or just the pads? Also I am assuming everyone is getting ceramic pads at this point right?
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by Elderan View Post
    I've been told that squeaking is from the pads, not the rotors, so new pads, 'should' correct the problem.
    Jan 26 2015
    Clemmons
    Sorry main point was how long do the rotors last? I am already at 33k miles. I dont want to do the pads and then need new rotors in 5k miles.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    the rotors probably have enough thickness so the could be machined. However German Car companies such as Audi & BMW insist you replace rotors every time you replace pads. Maybe an indy would just turn rotors the first replacement cycle
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    It is hard to tell without knowing your driving style and commute. An indie VW/Audi shop will probably check them out for free if you are not the DIY type.
    Jan 26 2015
    Clemmons
    I think I will just replace the rotors, pads at the same time. I have an indy shop that will do the install since I dont want to do it myself.
    What do people recommend rotor/pad wise.
    Jul 24 2015
    There is a minimum thickness on the stock rotors....if the current thickness is close to the min number, get new rotors else if they have enough life left, you can just get your stock ones resurfaced.
    Apr 22 2013
    maine
    I've got a new 2016 with 1,000 mi and have heard brake noise. Nice.
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    19k miles on my 2014 S4 and sometimes the squeal is unbearable. Audi told me there is no TSB on it and they'd charge me $350 to relube the brakes. Yeah, no thanks.
    Jan 26 2015
    Clemmons
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I have their slotted rotors with Akebono pads. Many will tell you not to bother with cross drilled rotors, as they may lead to premature failure on a rotor. But I'd say if you are not tracking the car, and you like the look, go for it.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jan 26 2015
    Clemmons
    Quote Originally Posted by sacandagaD View Post
    So ?
    https://www.ecstuning.com/Audi-B8_S4...nce/ES2189933/
    https://www.ecstuning.com/Audi-B8_S4...ear/ES2189938/
    https://www.ecstuning.com/Audi-B8_S4...nce/ES2569618/
    https://www.ecstuning.com/Audi-B8_S4...ear/ES2063841/
    Is there anything else I need?
    Jul 02 2013
    Looks like you have all the pads/rotors there.
    I also replaced the caliper bolts and carrier bolts, but many have done brakes without doing so. I assume you have a Vag-com cable or Carista app for rears?
    Jan 26 2015
    Clemmons
    I was planning on taking the parts to an indy shop and have them do it. Last time I did brakes was when I was in high school 1995 and they were drum brakes.
    I like the idea of replacing the bolts as well. How many bolts do I need?
    Jul 02 2013
    I replaced these:
    ES#450990 front bolt set, 2 sets needed,
    ES# 472036 front bolts, 4 needed,
    ES#252691 Rear bolts, 4 needed.
    Aug 06 2015
    MA
    You (and everyone else with squeaky brakes that have some miles on them) may be able to fix it without any new parts. The bevel on the stock pads is at low angle and depth that, after a certain wear, will squeak. You can chamfer (SP?) Your current pads on the leading edge or the side if your rotor has a lip.
    Best link I could find at the moment.
    http://www.v11lemans.com/forums/inde...howtopic=10898
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by mungie View Post
    That might work. They did that on my 2010 and it did help. BUT, Audi actually admits that the squeal is normal and the result of the brake pad compound. I replaced my stock pads with Stoptech ceramic pads and the squeal is gone. PLUS, I no longer have the ugly black brake dust. FYI, any ceramic pads will work. Best mod I ever did on my S4. Kick myself for not doing it earlier.
    Jul 10 2015
    SATX
    If you use the right tactics they can be replaced by AOA vs Dealership as a goodwill gesture. Mine were replaced free at 15k miles due to freight train brakes. Used a video recording and the fact that there was >3mm pad left as the reason it was inexcusable and not within "normal" operating limits.
    Mar 04 2014
    Falls Church, VA, USA
    For those of you who were told by Audi that this is normal or whatever excuse they gave you, ask them about TSB#2027636. This TSB was created by them to solve this squeaking problem. My car had 24,372 miles when Audi of Arlington replaced front brake discs and pads on 9/24/15 to solve this problem. Free of charge! Common guys, how much did you pay for your cars and you're being told that squeaking brakes are normal! Be ready to replicate the noise when you take it to the dealer or they won't do anything.
    2012 S4 Premium Plus, Moonlight Blue Pearl, S-tronic, Nav.
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by aty View Post
    Hmmm.... I'm definitely giving my dealer a call on Monday. Thanks!
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Quote Originally Posted by jzinckgra View Post
    This is not a "defect" in material, it's just that the material in the pad is semi-metallic and that's what happens. I promise if you do a handful of hard 60mph stops and get the brakes hot they won't squeal at low stops until they cool down again.
    The supposed TSB that I've heard of and never acted upon, so I can't speak first hand, but have heard that they will replace the pads with a less metallic pad. Less aggressive braking performance but less noise.
    It doesn't bother me personally. Your car's brakes are fine though.
