Never worked on a convertible top.
Starting to troubleshoot 'roof not closing'.
Starts moving, but stops about half way down. Also sometimes not smoothly coming to a full close.
Motor/pump running.
Sounds like 'low fluid' at the pump if that is possible?
Where to start with troubleshooting the convertible top?
Where are the hydraulic components located (pump, tank)?
If leak (maybe cause for low fluid), what and where are the typical leak points?
So far, only found an oil spot on the driver side cover (where the spring loaded 'strut' would roughly land with top up).
