Results 1 to 9 of 9
Thread: A4 Coil Pack
    Feb 01 2016
    09 A6 3.0T (Sold), 11 Cooper ALL4 S, 2013 S5
    Lowell, MA
    A4 Coil Pack
    Hi All,
    My wife called me on the way home last night to say the check engine light was flashing and the car was running very poorly.
    Of course my mind jumped to all the worst scenario's but a quick read of the forum seemed to suggest the likely cause as a coil pack. I plugged Carista in and it identified cylinder 3 as a misfire. So, swapped 3 and 1 coil packs, reset OBD and waited for it to trigger the CEL again, about 5 seconds! Sure enough the misfire is now on cylinder 1 so coil pack it is.
    My question is this, am I ok to change just one coil pack, or should they be changed as a set?
    Thanks
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    I think you can replace just the bad one and you should be fine.
    Established Member Two Rings L'Audi's Avatar
    Apr 06 2016
    Long Island, NY
    You CAN just change the one, but if funds permit, I'd recommend changing all four. Whats to say age didn't play a role and another one isn't on it's way out?
    06 Dolphin Gray tip 2.0T
    GIAC Xplus | USP Testpipe | RevMotoring Springs | 19X8.5/9.5 Niche Targa | pioneer 80PRS | Taramp's HD1200, HD8000, HD10000 | 18-Sound 6's | B&C 8's | Audiocontrol Three.1, Audiocontrol Epicenter | Clarion EQS746, MCD360
    Feb 01 2016
    Lowell, MA
    Thanks guys
    2013 S5, B&O, Sports Diff, Nav Plus, Carbon inlays, Akebono, APR Stage 2, Dual Pulley, DSG Tune, APR intake and back pipe. KW HAS. Variant 20x10, Carbon Imports rear spoiler, RS Grill, Passport 9500i and night surveillance by Blackvue :) Ultracharger and Intercooler, ECS X-pipe
    Oct 23 2015
    Australia
    You probably should read post #22, here:
    http://www.audizine.com/forum/showth...an-quot-F-quot
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    The others usually follow.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Don't do that. Replace all 4 and save a headache. I would say go OEM but the advance auto parts coilpacks have lifetime warranty and i had them since 50k miles and i'm at 102k miles and still working perfect. If they go bad for what ever reason change and get a new one for free. But if you want to go oem that's the safest way.
    Sent from my C5306 using Tapatalk
    Ivan
    Oct 23 2015
    Australia
    Quote Originally Posted by dalmation53 View Post
    No,don't just change one if finances permit...I was showing that info just so he doesn't mix and match wrong.
    I just changed all of mine to RS4 ? red top-we're all confused now about them-too much information !
    Like some physical ailments that just creep on slowly and are almost unnoticeable plug packs are the same.That one change lifted pickup amazingly.My originals were OEM 140,000km
    Feb 01 2016
    Lowell, MA
    Advance auto parts it was, thanks for all the input.
