Results 1 to 21 of 21
    Senior Member Three Rings Drichardson72's Avatar
    Apr 10 2015
    Vancouver, Canada
    Unplugged my Soundaktor today.
    I found a thread from 2012 taking about the soundaktor and decided to pull the fuse today and test it out. What a difference!
    Obviously the sound is a lot quieter, but it's nice to actually hear what the engine / exhaust sounds like without artificial engine sound.
    The soundaktor literally plays sound files based on the RPM's of the car. While I like the noise it makes, fake sound doesn't sit right with me in a performance oriented vehicle.
    I think this has just moved a new exhaust up the priority list, although may try to install an X Pipe first.
    Apr 29 2014
    2017GLS550 ST1
    Area with Bay people
    Found the thread and pics too. Will do it.
    Cheers,
    Bob
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Vagmod for me
    Steve
    '15 SQ Monsoon
    Apr 10 2015
    Vancouver, Canada
    Quote Originally Posted by BobSF View Post
    Cheers,
    Bob
    It's the 5th fuse on column A, in the fuse panel located on the drivers side. The fuse location is well explained in the manual.
    Be warned, there is a good chance it's going to make you want to upgrade the exhaust. I'm Ordering the Magnaflow 19238 axle back this week.
    Mar 21 2015
    You guys need to check out the S4 and SQ5 side. You'll probably find a bunch more crap to do that you'll like.
    Pulling the fuse will throw a soft code but turning it off with Vag won't.
    Senior Member Two Rings Jay337's Avatar
    Oct 24 2014
    Montreal
    can somebody told us the way to do it with vagcom?
    Sent from my SM-N920W8 using Tapatalk
    Current
    2018 Audi SQ5 Navarra Blue
    Past
    2015 Audi SQ5 Sepang Blue
    2012 BMW S1000RR Tricolor
    2009 VW GTI Candy White Unitronic Stage 2+
    2003 VW GTI 1.8T Reflex Silver Unitronic Stage 1 +
    Mar 21 2015
    Quote Originally Posted by Jay337 View Post
    To mute the Soundaktor (as an alternative to pulling the fuse):
    A9 Structure Borne Sound (in my car, this was in the second Installed tab, not the first one that's shown by default)
    Adaptation 10
    At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
    Enter a value in the proper box (0% = mute :))
    Apr 29 2014
    2017GLS550 ST1
    Quote Originally Posted by Drichardson72 View Post
    Not sure im into that( I also drive a hybrid Lex, so i kinda like it mellow).
    Thanks,
    Cheers,
    Bob
    Oct 24 2014
    Montreal
    nice, was it at 100 before you put the 0 value?
    Current
    Past
    Mar 21 2015
    Is that how you interpreted that statement?
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    I think he's just asking what the default setting was when you did it.
    Apr 10 2015
    Vancouver, Canada
    Adaptation 10
    Thx, 14S4GWM!
    Oct 24 2014
    Montreal
    sorry , just want to know if the default value was at 100 before you put it at 0
    Current
    Past
    Oct 24 2014
    Montreal
    Quote Originally Posted by SQive View Post
    exactly sorry for my English ;)
    Current
    Past
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Apr 02 2014
    San Diego
    Whoah....I thought the TFSI SQ5 had a valve to allow more exhaust directly out the cat back....but I don't think SQ5 uses artificial sound files. Thats for the TDI.
    Sent from my SM-G928V using Tapatalk
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by usavageu View Post
    Exist version for the TDI and TFSI - only the different control unit
    Mar 21 2015
    Yes it was 100 originally. I heard 50 won't work.
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    Let us know how you like it!
    Veteran Member Three Rings NastyNate's Avatar
    May 26 2009
    Quote Originally Posted by spijun View Post
    Whole new meaning to "butt dyno"
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by NastyNate View Post
    I discovered the Soundaktor recently when I was installing a relay under the rain tray...I never knew that this existed. This explains why I could clearly hear the relay from inside the cabin. I just turned it off with VCDS. I am running a Milltek exhaust with K&N air filter in a modified factory airbox so I’m interested to see how different she sounds now...tomorrow morning.
