Audi B5 S4 Nogaro Avant
2002 Audi S4 Avant
-175k on body
-103k on motor and tranny
-6 Speed Swap
-Nogaro Blue /w Silver interior
-Completely stock adult owned
Powertrain swap was done 6k miles ago by PO prior me buying it. Since then I did full motor maintenance including complete timing belt, serp belt, water pump, valve head seals, chain tensioners, gaskets, pulleys, serp belt tensioner, and aluminum thermo stat housing upgrade. Also replaced EGT sensors, fan clutch, coolant sensors and coolant flush. Plugs and fresh oil change with air filter. New rotors and pads were also done along with rear wheel bearings and axles. Just did suspension all around with new shock mounts as well. New Continental ContiContactPro all around. Turbos boost up and hold as they should without any boost leaks. I also had it completely resprayed. There are 1-2 flaw spots but otherwise looks fantastic. I had the front bumper washers shaved prior respray for a cleaner look. Interior has its wear but no rips or major damage. I will also be including some spare parts if buyer would ever need to use. I did my best to keep the car looking and driving great! I don't want to let her go but really want to buy a house. My loss is your gain at the reduced price!
I love driving the car so miles will go up. If you want to come down and see it shoot me a text or call 860-2one2-8one2nine. Low ballers and tire kickers don't waste my time please.
List Date: 5/17/2016
For more info, click here to view the original listing: Audi B5 S4 Nogaro Avant
This item is no longer available.
