Originally Posted by
doug97gxe
my statement says it doesn't work well with 91 octane.. so a few people have issues with it isn't documentation of it not working well with 91 octane? how is that blanketed its a FACT .. no where did i say ALL people who use 91 have a problem with it.. i said it doesn't work well with it.. 1 case makes it a fact.. 2 cases makes it a fact.. multiple cases STILL MAKES IT A FACT..
You stated and continue to state that ALL have had this issue. Thus it's a blanket statement. When there has been DOCUMENTED replies of those saying they have had no issues running 91 octane.
doug97gxe
my attempt at humor to lighten the mood.. see i struck a nerve.. no biggie.. we can move on
Humor huh? made no sense hense why I stated as such. no nerve could care less.
doug97gxe
the only ECU tune that has been programmed to ignore knock is the REVO tune .. all others work with the Knock sensor.. this is also very well documented in the S4 forum. Personally i wouldn't use the REVO tune either because its doing similar as the CW .. so you're statement is incorrect you should do a little more research on these tunes
No revo tune is not doing the same thing. It was actually changing the AFR and allowing it to lean out. The CW does not affect fuel delivery like the Revo tune does/did.
doug97gxe
you're right.. some of use choose a cheaper option for more power cutting corners.. some of us choose to remain stock and some of us choose a real tune .. a real tune isn't about numbers for everyone actually but more that the car is running more boost safely with full understanding of the ECU to make adjustments at anytime.. the fact in your prior post that you're comparing the safety of an ECU tune with the CW alarms me
again this is opinion not fact. Just because it's an less expensive option does not mean it is cutting corners nor does it mean it's not "real". and the fact that you think altering an ECU is with out any risk is also alarming.
doug97gxe
the jump off a bridge comment wasn't another attempt at humor on my part to lighten the mood, but i see you're very emotional about this whole situation .. not sure even if i was narrow minded what buying a civic has to do with anything? are you suggesting people who buy civic's are narrow minded? i'm confused
Humor that again is just ignorance. If you had said $60,000 dollar AUDI vs what you said of a 60,000 dollar CAR then you might have some leg to stand on here. But you dont since you didn't specify. BMW being also a 60,000 dollar car and the piggy back is "proven according to your thinking" to be the best option it held reference in this specific discussion.
as far as honda civic owners being narrow minded. I never said that. you again brought that into this discussion and I suggested maybe you should own one instead of an audi.
