Results 1 to 7 of 7
    Active Member One Ring Apulido12's Avatar
    Feb 04 2016
    Kaiserslautern Germany
    Unhappy Trunk won't open/Plate light flickering
    Hello,
    So today after coming home from work I tried opening my trunk with my key remote and got no response. The lights flashed when I pushed down on the button but nothing happened. The button on the driver door does nothing as well. I made sure the valet mode was off. I had to crawl in through the back seat and release the trunk with the emergency handle on the inside. Another weird thing is that when I finally got it open the plate lights cut off completely once the trunk lid goes fully open, I lowered it half way and the lights come back on, I don't know if both problems have to do anything with each other but I thought it was a bit odd. Is my fuse bad or my trunk actuator? Any help would be great thanks!
    Senior Member Two Rings kmunz264's Avatar
    Dec 19 2014
    Port Republic Maryland
    Did you check if your trunk is part of central locking in your car settings
    Feb 04 2016
    Quote Originally Posted by kyleowen94 View Post
    yes I checked, trunk is on under central locking
    Dec 19 2014
    Maybe a blown fuse
    Feb 23 2012
    1985 Ford Bernardi
    West Bloomfield, MI
    You may have an intermittent problem with the ground between the decklid and the body sheet metal. Both the decklid latch and the license plate lamps are grounded through a wire between the decklid and the body of the car, not through the hinge itself.
    You can try wiggling the wire harness while the decklid is open to see if wiggling it affects the license lamp. If so, you've located the problem.
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    Quote Originally Posted by Scribe42 View Post
    +1 for this suggestion.
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Feb 04 2016
    Thank you, i'll try this out.
