Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 126
  1. #81
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Correct. You will want a North American RNS-e if you don't want to flash. There is a 2010 North American model number now but I don't know if its a straight swap like all the previous versions. There's a large thread about it on audiform.
    All North American disks are compatible for North American RNS-es.
    However, you'll definitely want the newest maps DVD, because these DVDs include firmware updates for the RNS-e as well. That is, unless you want video-in-motion (for playing DVDs, or back up cam), which has been disabled for software versions 0260 and above.
    Edit: For that last DVD part number (AR), AGCC means "Arab Gulf Countries Council". You don't want that one.
  2. #82
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    All of the '09-'11 have the newest screens and are much more expensive (and harder to find)
  3. #83
    Jun 07 2010
    stockton on tees
    im looking into retro fitting my a4 b6 with rns-e,it has a concert II,single din.
    apart from changing to double din cage.
    would the the rnse work with the wiring????
    would i recieve the info in my dis.i have the red/orange display,not multi colour.
    regards.
  4. #84
    Feb 12 2009
    T.O.
    does anyone know if the T revision will allow for the VIM hack?
  5. #85
    Mar 11 2008
    B7RS4 & e46Ms
    ^^yes.
    FRRG AZ Ring
  6. #86
    Veteran Member Four Rings jamerican1's Avatar
    Nov 15 2009
    2008 A4 S-Line Titanium TQM, 2000 A4 1.8tqm, 1993 Audi 90S(sold)
    VA
    I have an 2008 with RNS-E and ipod integration. Would I be able to add my trunk mounted cd changer from my 2000 B5?
  7. #87
    Established Member Two Rings TRON1C's Avatar
    Mar 03 2011
    2011 Audi A3 2.0TFSI
    San Diego, Ca
    Anyone successfully hooked up their 2011 RNS-E unit to play videos off the factory ipod hookup? Or enable the 2011 RNS-E unit to play video by whatever means, at all?
    2011 Lava Gray w/ iPod linked MMI Navigation
    Mods: 20/40 Tints, Vagcom
    Still Want: License plate delete, Stasis chipping, Radar Detector, Video Link through Ipod
  8. #88
    Apr 08 2011
    toms river nj
    HELLO, I HAVE A 2007 A4 CABRIO WITH SATTELITE AND BLUETOOTH WITH SYMPHONY II. LOOKING AT RNS-E 8E0 035 192F WITH DISC, GPS ANTENNA, AND CODE. WHAT ELSE DO I NEED? I HAVE FOUND A LOT OF DIFFERENT ANSWERS WITH ANYWHERE FROM NEW HARNESS TO CANT BE DONE OR SIMPLY SWITCHING THE "K-LINE". PLEASE HELP!!!!!! THANKS RUSSANT
  9. #89
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    I just got an RNS-E from a 2006 A3. I was wondering if all the Nav DVD's will work in it. I believe some are MMI disc's if I am correct. Will the MMI discs work in an RNS-E or do I need a disc specific to the RNS-E?
    Thank you for any help/clarification!
  10. #90
    Senior Member Two Rings AudiA4b6US's Avatar
    May 10 2005
    Chicago, IL
    Only DVDs that say RNS-E on the label will work, MMI DVDs won't work in the RNS-E.
  11. #91
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by AudiA4b6US View Post
    Thank you very much for the help
    Now I just gotta wait and see if this unit I purchased has a DVD in it or not...
    Now my next question is, what is everyone's preferred way to connect their iPod to the unit?
  12. #92
    Established Member Two Rings NODO-GT's Avatar
    Jul 30 2010
    Audi A4 B7 2.0T Quattro 6MT
    Tbilisi
    is it possible to change menu color on audi RNS-E in Audi A4 b7?
    navi is coloured in blue, SD/CD is in orange and i don't like orange...
    also can anyone give me a link to full Bluetooth kit for RNS-E... on ebay or something...
  13. #93
    Dec 25 2006
    2012 A4 Avant Ti, 2014 Allroad
    Pinehurst
    Will my 2008 RNS-E(bose) fit and work with the new 2012 a3 w bose?
  14. #94
    Active Member One Ring dedread6's Avatar
    Jul 22 2008
    b6 s4
    new jersey
    What do I need to install the RNS e into my B6 S4 ?
    I am here: http://maps.google.com/maps?ll=40.867297,-73.826594
    iPhone - Tapatalk
  15. #95
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by Sharkfin View Post
    Is this true for sure? I've got a 2010 unit, but the PN is 192T, indicating old hardware, correct?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
  16. #96
    Apr 02 2012
    So Cal
    I just purchased a 2011 A3 TDI and the audio system says Audi Concert. Does this mean it would be better to go aftermarket or could I still go RNS-e? Which would be the best option? I've seen some nice aftermarket systems for half the price of the RNS-e.
    Cheers,
    Bill
  17. #97
    Jan 20 2010
    Duluth GA
    You can retrofit a RNS-e fairly easily; audiforum.us is a good place to learn how to do it. You'll need a VCDS cable (or access to a friend with one) to reprogram the car to recognize/accept the new headunit.
  18. #98
    Veteran Member Three Rings Lou-quattro's Avatar
    Dec 29 2009
    B5 S4
    Peoria, AZ
    any fitment issues for an rns-e coming from a b6 a4 cabrio to a b6 a4 sedan?
    B8.5 S4 manual | AWE x GIAC stage 2 | CTS turbo intake | AWE track exhaust w/ non-res DP | H&R Street Performance Coilovers | Rotiform IND
  19. #99
    Established Member Two Rings lorensson's Avatar
    Mar 31 2012
    Charge Mixer (bicycle), Ladera skateboard ;-)
    Huntington Beach, CA
    I have a 2004 s4 sedan with the 2-din tape + 6 CD unit (don't know if it's symphony or symphony II?) and I have the Bose audio option.
    Sorry if this has been answered but I read through everything and it's all a bit much to understand at the start. I am interested in installing the RNS unit, but not sure which version (RNS-E, D etc) and I want the Bluetooth option. Could someone list the parts and costs of each to do it? Is it something that is a plug and play install or would I need to have it installed professionally with the Bluetooth unit?
    Thanks so much!
  20. #100
    Jul 22 2008
    b6 s4
    new jersey
    RNS-E for sale $600. includes harness Nav antenna and map cd
  21. #101
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Does anyone make a kit with all you would need to put an RNS into a B5 S4 with DD Symphony Bose system?
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
  22. #102
    Established Member Two Rings Bull-D's Avatar
    May 06 2012
    Colorado
    if it is anything like it was to install into my 09 A3, there isn't really a kit needed. you need removal tools which you can get off ebay or likely one of the install placed in town, maybe even audi. just 4 little metal pieces that look like key blanks. also a 32 pin connector you can get from audi parts for about 28 bucks. i have the part number somewhere if you need me to dig it up. you use that to swap 3 wires from one
    connector in the back to the 32 pin connector....this was done so i could use my OEM aux port that came on my A3. after that, it requires some VAG-COM mods to get all the features to work. that was it on my install. so far very happy i did the swap.
  23. #103
    Apr 27 2011
    MD
    Quote Originally Posted by Bull-D View Post
    Pics?
    IG: @s4dad
  24. #104
    Mar 10 2004
    08 A4Avant 2.0T
    So no info on retrofitting Reverse cameras? ECS has the 700$ kit
    Found this........
    http://www.factory-direct.jp/SHOP/73...6408/list.html
    Gives us hope that there are cheaper solutions. These are around 200 or less.
    I'm going to look into this further and report back when I can.
    '17 A4 Allroad
    '08 A4 Avant 2.0T Titanium Edition
    '11 TTS Coupe (sold)
    '01 A4 Avant 1.8T S line (sold)
    '90 CQ 20v (sold)
    '95 VR6 "Getta" (sold)
    '85 4000s quattro (sold)
  25. #105
    Dec 29 2009
    B5 S4
    Peoria, AZ
    Alright well... After successfully using the nav for a few weeks after installing my RNS-E, my gps location is totally off now. The map DVD it came with is a burned copy and the bottom looks pretty scratched up. Could that be the problem? My gps antenna is located behind the head unit magnetized to that metal bar by the steering column which seems to be a common spot from what I've read. Audi and navteq haven't been helpful in telling me the best place to get a new map disc or which version. I'm definitely not buying one through Audi for $400 which is what they quoted me LOL. Any help would be appreciated.
  26. #106
    Dec 29 2009
    B5 S4
    Peoria, AZ
    Bump for help.
  27. #107
    Mar 16 2012
    Perth
    Quick question:
    I've been reading all afternoon from various sources and am trying to figure out what I need to do this conversion. I have a 1999 S4, euro model so has pre-facelift centre console and concert headunit, I'm in the process of converting this to facelift now so space won't be an issue. What parts do I actually need for the conversion in my model? My dash has an analogue clock so I'm led to believe it does not have CanBus am I correct? What will I need?
    Any help appreciated.
  28. #108
    Feb 12 2013
    Australia/New South Wales/2440
    Hey, just a question, I'm trying to sell my RNS-D nav plus that I pulled out of my 2003 a4, and I have a guy thats wanting to know if it will fit into his 2004 A8L ? He said Audi told him it was to hard and costly?
    I'm thinking of selling it for $550 bucks if anybody's interested??
    I'm in KEMPSEY, NEW SOUTH WALES, AUSTRALIA
  29. #109
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    what is the part number for the rns-e with updated screen and sd slots
  30. #110
    Aug 29 2013
    '06 A4 2.0T 6MT, '11 Q5 2.0t, 99 A6 Quattro Avant, 95 F-150, 73 Opel GT
    MA
    I apologize for the necro-bump, but I have been searching without success in finding how to access the hidden EQ settings for the RNS-E with Bose. I think this is the most relevant thread for that function. Any suggestions appreciated.
  31. #111
    Established Member Two Rings macster9090's Avatar
    Sep 01 2011
    B7 RS4 DAYTONA GRAY CF 1 OF 195
    Hope, NJ
    long story short i just got a 2012 unit for my b6 a4 its all new tec built in the style housing for the b6 cars i dont know anything about this unit but would like to get the best possible bluetooth working, i found an oem audi original bluetooth adapter for my car but idk how or if it will work with my unit i also want full functionality, i plan on doing a steering wheel swap soon.
    thanks help is much appreciated
    INSTA - @Braedon_RS4
    B6 A4 1.8T K04 APR (DIED) SALVAGED FOR PARTS
    (REMI) B6 A4 3.SLOW ULTRASPORT 6SPEED - SOON TO SWAP OVER TO BUILT 1.8T
    (ALEXANDRIA) B7 RS4 DAYTONA GRAY CF 1 OF 195 - BUILDING
  32. #112
    Jun 19 2007
    02 A4 3.0 Avant
    NY/FL
    Has anyone used the repairservice.web.com software to unlock their rns-e? I recently purchased one and dont have the code and the dealer cant get the code.
  33. #113
    Sep 20 2015
    Today my RNS-E display (along with other center console display) keeps getting dimmer and coming back and getting dimmer and coming back like a constant loop. Today is particularly hot and my car has been sitting in the sun, not sure if that would cause this issue. I was wondering if anyone encounter the same problem before?
  34. #114
    Established Member Two Rings djinfiniTeeQ's Avatar
    May 09 2011
    Oakland, CA
    Looking at the list on the first post in this thread, it would appear that the A3/S3 RNS-E is not compatible with a '00 B5 S4. Can anyone confirm or deny at their earliest convenience? Considering buying a 1st gen A3/S3 RNS-E on eBay...
    Thanks!!
  35. #115
    Dec 24 2016
    Romania
    Hello to everyone ! I have a power problem with my RNS-E (mk1) . The unit is mounted on an Audi a4 b6 , and it was taked from an Audi a6 c5 .The problem consists that the unit to start need a suplimentary connection beside the +,-,and can wire . The connection is made from continuos 12v to pin D13(radio on) , but the problem is that its consuming batery (the rear amplifier ) , Was anyone experience this kind of problem , is there a inside fuse ? or a relay between the main + and radio on ? P.S The unit comunicates with the dash , its chaiging the lumination ,etc.
  36. #116
    Established Member Two Rings hallvardr's Avatar
    Jul 28 2012
    Norway
    I found a RNS-E from an A3 cheap for sale (8P0 035 192S) can these fit in an A4?
    Is the faceplate the only difference, and it's possible to get a new one, or is it not worth thinking about.
  37. #117
    May 10 2005
    Chicago, IL
    If your car needs a discrete "GALA" (speed) signal (some A4 B5 and A6 C5) then you need to find a 4B0 unit. Otherwise any RNS-E will work with proper coding. The A4 B5 and A6 C5 need the 4B0 faceplate, A4 B6 needs the 8E0 faceplate and A3 8P needs the 8P0 faceplate.
  38. #118
    Jul 28 2012
    Norway
    Allright, thanks! very helpful!
  39. #119
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    Dose anyone know if or about the vim hack working on mk2 rns-e? 193 F (H06 i believe)
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
  40. #120
    Veteran Member Four Rings idotavant's Avatar
    Jan 20 2016
    wv
    Sorry for the necro bump. Anybody know where to get inexpensive replacement screens? Pretty sure my ribbon is ok
    05 Allroad 4.2 ao3 swap; jhm v3 kit
    06 Dakota 4x4 long travel v8 6spd
    03 Tuono 1000
    04 MB c240 4motion wagon (gf’s)
    02 a4 avant 3.0 tip (defunct; part-out or sale)
