Results 1 to 23 of 23
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    ChipWerke Pro Chip Tuning Piggyback System - anyone here using it?
    I know a lot of the S4 guys are and the engine is the same and all but wanted to see what you folks think.
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Established Member Two Rings SeaChiS4's Avatar
    Mar 22 2013
    Seattle/Chicago
    Quote Originally Posted by 01northernS4 View Post
    I've been using the CW piggy for about 6 months - haven't dyno'd the car before or after, but the butt dyno definitely feels the difference to be significant - I went with a piggy after my previous car ('11 S4) was flagged TD1 - this had a flash. The only gripe is a slight stutter on heavy acceleration - the spirited acceleration on the S4, with the flash was definitely more linear.
    '14 S5 DSG Monsoon Gray/Black - Roc Euro
    '15 M4 DCT Mineral Gray/Sakhir Orange - DP's; JB4
    '17 M2 DCT Long Beach Blue/Black - Turbo back FI; JB4
    Apr 29 2016
    Pennsylvania
    Quote Originally Posted by SeaChiS4 View Post
    So this CW tune is similar to a cobb accessport for the n54 engines in 135i and 335i?
    Mar 21 2015
    Quote Originally Posted by swag View Post
    No where near the same. This is plug and play and tricks the ecu. It does not change any part of the factory tune.
    Oct 18 2006
    Audiville
    So consensus is its a great mod in term of bang for the buck, simplicity, no td1 and with apr/giac stage 1 type gains from what I read... anyone else with a review to offer?
    Oct 18 2006
    Audiville
    So all else being the same and if there would be no td1 on a "proper" tune would you still go with the cw piggy or pop more $$$ for apr/giac?
    Mar 22 2013
    Seattle/Chicago
    I'll go with the piggy again since I go thru' cars every year or a maximum of 2 - this way I can remove and resell - the flash tune goes with the car...did the same for my M4 - went with a JB4 instead of a Dinan flash.
    Mar 21 2015
    A fair amount of the S4 guys complain about the DSG being very jerky with the CW. Theres a pretty extensive thread on the S4 side.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    There can be hesitation on its more aggressive setting under heavier throttle inputs (50-75%) post-shift.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Oct 18 2006
    Audiville
    Jesus your car is fast.
    Quote Originally Posted by Loe View Post
    Aug 09 2015
    Sarasota, FL
    The CW does work as advertised, it's a simple product and not as sophisticated as piggyback systems on other platforms that can access CANBUS functions.
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Same here. I'm with CW stage 2 map + cts pulley. I feel it every time when I go heavier throttle. Under wot it's pretty linear though. When I had stage 1 CW it was the same. I hate this uncomfortable feeling.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by yjypm View Post
    What is yours set at? I know we are using it for different purposes, but I only need mine at its more mild settings (3-1 or 4-1), which integrates nicely with the GIAC stage II file in terms of refinement and drivability.
    Oct 08 2015
    4-1 running crappy ca 91 octane. No 93 or e85 is available around here.
    Current: '18 M3 ZCP
    Jan 18 2015
    Are you dsg or manual? If dsg, are you driving in D or S? Power delivery is smoother in S than D.
    Oct 08 2015
    Quote Originally Posted by Rocket Tech View Post
    Dsg. I usually drive in D. I know power delivery is smoother in S and more responsive, but in LA traffic I have to use D to save some fuel.
    I guess I have to go for an ecu flash sooner than later.
    Current: '18 M3 ZCP
    Apr 29 2016
    Pennsylvania
    How is it in Dsg manual shifting mode? I just ordered CW pro on ebay. Can't wait to try it out.
    Oct 06 2014
    Cleveland, OH
    I use it with 93 octane and for me it works great and I saved enough money for other performance goodies. I am Stage II. I only get the "hesitation" when the engine is cold, as long as I let it warm up, about 5 min of so, it is very smooth for me. In either D or S.
    Deactivated Four Rings
    Jun 23 2011
    With the EPL tune you are able to sell your tune.
    Mar 21 2016
    2018 SQ5
    Scottsdale, AZ
    Has anyone tried this on the 2.0T yet? I am so close to ordering it but cant find a single post or review of it on the 2.0T.
    Established Member Two Rings Mobileguy's Avatar
    Aug 07 2014
    S5 Cab, Q5, eGolf
    Kali
    Here is another thread about some other users' Chipwerke experience (including mine):
    http://www.audizine.com/forum/showth...7366-Chipwerke
    I run it on a Q5 3.0 for about a week but removed it again. If you want power for cheap and don't mind jerkiness or potentially other issues down the road - I guess its not a bad mod, especially since it can be easily removed. Personally, I did not like the power lag during shifts and I was also concerned about an add-on device feeding false readings to the ECU to get the extra power gain.
    2015 S5 Cab DSG | APR Stage 2| Dual-pulley + Ultra | APR DL501 | Roc Euro | Milltek non-res | Snow w/m | + lots of other stuff
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by Sales@EPL View Post
    Chris, do you mean "with EPL you can keep your tune when you sell the car"? I think he was mentioning one drawback of a flash is you don't get to keep your tune, if you sell the car.
    If that is was you mean, that is a great benefit for an EPL tune!
    Jun 23 2011
    Well either way whether you sell the tune out right or pay the transfer fee and keep it.
