I have a 2010 A4 2.0T and Just finished doing the WG replacement as car was running great for about a week holding 12psi, peaking a bit more.
So Sunday I start car up, runs fine. I creep out of my neighborhood and get about 10 mins away when I notice My idle is abnormally high, like 1100rpm, when it should have settled by now. I notice its rough like a misfire so I accelerate off the line and get a flashing CEL and I now hear a whistling noise which sounds like air squeaking by thin rubber like a balloon so I’m thinking PCV is bad.
I took the oil cap off and there is suction pulling the cap back down and also on the hole in the pcv there is suction as well there.
My car currently has the PCV valve with the clear portion (no "XX" letter suffix). Going to replace it but which revision should my car have as I’ve read conflicting stories that black is the update one. When I called Audi previously about my pcv they said “oh your car already has the updated one – it came in for pcv service before”
Later that day I swapped cyl 4 coil around cleared codes and started car and it now runs worse, to the point of nearly stalling and codes read misfire on all cyl/random misfire. I checked to ensure the harness was clicked in and it is. Could PCV cause Random cyl misfires?
I did notice that there is a bit of oil in 2 of the cylinders. There is not a lot so possible that the pcv broke and did that in the short time it was run.
As an aside plugs were changed 30k ago and car has original coils (only changed one so far to newer all silver style oem – others are black oem)
This is after I cleared all codes and started it up after examining coils
Car currently has Beige PCV and parts guy says I need one ending in AE. He doesn't know about reflash and crank case seal service department is busy so I cant ask if that's been done on mine
EDIT:
I installed the new PCV. My old one was beige but had no suffix where as the new one is also beige but has suffix AE. It eliminated the squeal but It did not help the problem, still suction on oil cap. I do notice there is oil leaking from front of engine as I can see when underneath the car flowing down onto oil pan from above dripping onto belly pan , no apparent oil leak at rear. I see that my front most belly pan has accumulation on it and I just cleaned it 2 months ago (thought nothing of it figured mess from oil change or top up.) I'm guessing the pcv caused the front crank shaft seal to be blown out? If so how involved is this repair? What's involved in it?
