Hi All:
We all know the follower is one of the maintenance items for our generation and I haven't seen any real measurements done before. As an engineer this bugged me and since I have drop gauges at work, I did an easy experiment (currently still on-going).
DISCLAIMER: My experiment should not be held as law as cam followers all will differ in exact measurements and wear rates are highly dependent on condition of the individual's car, parts, oil levels, how 'spirited' you drive, ECU Tunes, upgraded parts, etc. I am not responsible for any damage to your own cars. You can see my upgrades in my signature, I do oil at 5k and top off a quart at about 4000-4500.
I have since bought two INA cam followers from ebay. The first one (I'll call it CF1) measured at 0.079" brand new on the drop gauge. I just removed it after 5000 miles of mostly highway driving, I do like to hit 4-5k RPM at least a couple times a day. There is basically zero wear in height after 5000 miles, the black coating started rubbing off in the center but the numbers didn't change with any real significance.
I measured the second follower (CF2) new this weekend at 0.069" and have installed it into my car. I think I will measure CF2 after it's run for 10,000 miles and remove/remeasure.
So from what we know, the INA followers seem to hold tolerance new from 0.069-0.079 (from a sample size of 2, LOL) and at 5000 miles no significant wear is measurable. My plan is to find a wear rate and divide by a factor of safety of 2 and consider that my time to check/change out followers.
**I noticed that there could be a slight error in measurement technique since the center seems to wear first, I place the CF face down and the unworn parts of the plane may be hiding the wear at the center point. I could do these measurements as well as height drops next time to both sides of that face separately.
