Results 1 to 4 of 4
    Established Member Two Rings ironman9's Avatar
    Jan 25 2016
    Brunei
    Speedometer and another spacer help question !
    Hi all! I really do appreciate your help! theres 2 parts on this. Appreciate if you would read and help me!
    Okay Part 1: I know there's plenty of threads on spacers but I would want to ask this. Why do people use different size spacers for front and rear? for example, 15mm front and 20mm rear? Is it better for handling than same size spacers? or just looks?
    What is the best size spacers for wheels not being out of the fenders? just slightly right in the fender is good. My car is lowered using Audi sports spring. It came lowered from factory.
    Part 2: I have an A5 coupe and my speedometer area is just the normal red needle and red lights. I know that the S5 have white needle and S5 logo on it. Is it possible to change the colour of the needle to blue or white? and the other lights on the speedometer? instead of red, i like it to be blue or white. I can't seem to find anything on this.
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Part 1 answer... from what I know it's just for looks and not handling.... the rear track is approx. 5mm narrower stock so the 5mm wider spacer rear allows you to even out the look having front and rear both flush.
    Quote Originally Posted by ironman9 View Post
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Regarding your needle question, you will likely need to pull out the entire gauge cluster, disassemble it and replace the needle.
    I had to pull out the gauge cluster in my old Honda to replace some burnt out LEDs and it wasn't too difficult. It can probably be done but not sure how easy it will be on the A5. I haven't seen anyone else do it so you'd probably be on your own to figure it out.
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Jan 25 2016
    Brunei
    Okay thank you much on both your answers! Really appreciate them!
