Results 1 to 40 of 41
    Active Member Two Rings Jroc's Avatar
    Oct 23 2014
    2001 F21 S4
    British Columbia, Canada
    Blown transmission stage 3-... whats it worth?
    I love my car, but she's been seriously testing my patience.
    Ive been sitting on my b5 for about a month or two. wondering if its worth it to rebuild/replace the tranny and sell, or sell it as is.
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    List of mods and the condition of the body would help. Any rust issues at all?
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Dec 10 2013
    Borden, Ontario, Canada
    Pics are a must
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    Just fix it people will try and low ball the shit outta you because it needs a trans
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Aug 24 2014
    Newport Beach, CA
    Tiptronic or 6 speed?
    2024 M3 Comp xDrive
    Dec 16 2011
    Windsor, ON
    If its a 6spd please post how much everything cost to fix if you decide to go that route.
    Oct 23 2014
    2001 F21 S4
    no pics currently. im out of town working and theres nothing on my laptop. theres a bit of surface rust on one front fender. paint is in good/fair condition.
    f21's
    daz tune for 3-
    dv's
    boost fittings
    inlets
    vast stg 3 clutch
    borla catback
    bbs ch wheels
    lowered on a strut spring setup
    short shift kit
    im sure theres other small bits im missing.
    Aug 25 2012
    Elmore alabama
    Wasn't there a part out that the guy was selling a trans for like $350? Check out the classifieds, you will just buy another s4 if you sell this one.
    Aug 25 2012
    Elmore alabama
    Edit, $600 and located in PA if that helps you out.
    Oct 23 2014
    2001 F21 S4
    if there was a trans a little closer i would. im in nw canada
    Dec 10 2013
    I can't even find a trans in Ontario. People only sell 6-spd swaps and don't want to part with the trans. Just grab the JHM rebuild kit and be done with it
    IG: 24_et
    Sold:
    RIP:
    Aug 24 2014
    Newport Beach, CA
    I agree with Bordom, I would not sell the car just because you need to rebuild the trans. It sounds like a well set up stage 3 car based on parts, rebuild the transmission and you'll be very happy or if you've got time, wait for a working trans to become available.
    2024 M3 Comp xDrive
    Feb 09 2016
    Scottsdale/arizona
    Define "blown"
    Jun 14 2012
    2000 Jeep Wrangler TJ
    Tampa, FL
    I just had to replace my 01e.
    $450 for used 6 speed found on Facebook
    $650 for JHM Rebuild
    $900 rebuild labor
    $1200 Transmission Swap
    You are at an easy $3k if you need a shop to rebuild and install
    Dec 16 2011
    Windsor, ON
    Fuck that...
    Oct 23 2014
    2001 F21 S4
    well my symptoms are ..
    insanely difficult to shift into r without finding a sweet spot between 2500-3000rpm, even then its difficult.
    1-2 is a little clicky but not bad. 3rd is clunky to shift into, reallllllly hard to shift out of. 4th is reasonable. 5 and 6 are fine.
    although during the motor swap i notice it was slightly worn, if that has anything to do with it. im not too keen on transmissions/clutches.
    Nov 02 2013
    Is it hard to shift into 1st from neutral at idle?
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Quote Originally Posted by Jroc View Post
    try having your Queen sit for 5 years... you got it made kid(dude). dont sell!!
    GIAC-X, STASIS TS,VAST,034 MS
    Oct 23 2014
    2001 F21 S4
    Quote Originally Posted by dozer103 View Post
    a little. not too bad though.
    - - - Updated - - -
    Quote Originally Posted by GiacGRs4 View Post
    still a kid, 22 :P i've only had her for a year and driven it for probably 5 months.
    Nov 14 2006
    Land of the Eagles
    - - - Updated - - -
    what i would do for her ETA to be 1 month watching her every morning when I go to work and saying good night when coming home at 9, you just blow her a kiss and say sorry just like an actual wife lol...but in your case .. you got it made kid( i got a good 12 years on you) ;)
    Dec 10 2013
    Quote Originally Posted by InglisLeslie View Post
    $900 rebuild labor
    Convert to the Canadian Peso and you're already at $5k. Especially with what these trans go for used in Canada. Easily $1k just for the trans
    How does it shift with the motor off? (Unless you already answered this) Sounds more like shifter alignment now
    IG: 24_et
    Sold:
    RIP:
    May 30 2015
    canada
    like bordom suggested try aligning the shifter first, just wondering how did your transmission problems start happening, was it a failed shift or something? if it actually is a broken trans and youre looking to sell it let me know as im in BC too
    Dec 10 2013
    Quote Originally Posted by reverse.rake View Post
    Sells you Stage 3- that needs a trans for cheap. Turns out to be loose shifter bolt lol
    Obviously OP, I don't want that to happen to you.
    IG: 24_et
    Sold:
    RIP:
    Aug 25 2012
    Elmore alabama
    Quote Originally Posted by Bordom View Post
    Or a worn out joint on the shift rod.
    May 30 2015
    canada
    hahaha i wouldnt be surprised if something like that has happened before , knowing these cars.
    Oct 23 2014
    2001 F21 S4
    car also shifts like shit when off.
    happened after an extremely spirited run in the early hours of the morning (15 mins drive done in 5 mins)
    fucked up a 5th to 4th downshift and grinded hard. had immediate issues after the cooldown on the way home.
    Dec 10 2013
    Then yes, probably have shavings in the oil that have plugged the shift collars. Definitely time for rebuild
    IG: 24_et
    Sold:
    RIP:
    Oct 23 2014
    2001 F21 S4
    now to pull the trigger on another 3k purchase..
    Veteran Member Three Rings Audimilo's Avatar
    Apr 19 2014
    CO
    Fix that shit, get it overwith, be done with it, love the car again. till the next thing lets go. its B5S4 life. get used to it or get goin
    Sep 09 2014
    Grand Rapids, Michigan
    $500 + shipping for an 01E with right around 100k on it. Second gear when cold is sometimes notchy. Located in Michigan.
    Dec 16 2011
    Windsor, ON
    Does the B5 S4 share the 6spd with any other audi/vw? Allroad?
    Sep 09 2014
    Quote Originally Posted by Whiplash_89 View Post
    Yep. Same transmission in the Allroad and A6. I believe those have all have transmission coolers though. Not that that's an issue.
    Some of the early b6 models have a variation of the 01E that can work too.
    Dec 10 2013
    Quote Originally Posted by Trb1 View Post
    FYI:
    The B6 3.0 from 02-03 is a 01E trans with shorter 3-6 gears. They are also less durable.
    The C5 A6/Allroad also use 01E transmissions, but the Allroad uses a different final drive. 4.35 compared to 4.11 in the S4. You can swap the front diffs but then you would have to reset the backlash and everything for the ring and pinion to be kosher.
    The Allroad also has much shorter gear 1-6
    IG: 24_et
    Sold:
    RIP:
    Sep 09 2014
    FYI:
    Huh, no kidding. Didn't realize that the all road ratios were any different. With the b6 3.0 01E you have to modify the speed sensor for the speedo as well.
    Dec 10 2013
    Yeah, so the 3.0 01E, just swap the left cover and speed sensor tone ring, as well as the VSS from the B5 trans and you'll have a working speedo. You may/may not have to swap all the flanges, but that's shit simple
    IG: 24_et
    Sold:
    RIP:
    Oct 23 2014
    2001 F21 S4
    ordered rebuild kit. shipped out today.
    Dec 16 2011
    Windsor, ON
    Good info.
    Established Member Two Rings dammitcam's Avatar
    Dec 21 2015
    B5A4 Avant, 1G DSMs, FC, SC300
    B-Town,IN
    This is true for some of the B6 transmissions. Trb saw my car lol I have a trans out of an 03 and the speedo is ran off of the ABS sensor, the 02 B6 has the speedo ring.
    Dec 21 2015
    B-Town,IN
    Depending on the year of 3.0 you will need to put the speed sensor ring on the output shaft i believe it is on the driver side behind the diff cover. I just had to do it on my 2003 A4 3.0 trans. 2002 is hit and miss
    Dec 10 2013
    Quote Originally Posted by dammitcam View Post
    That is exactly what I mentioned. Typically 02-03.5 will be 01E. Anything else will require too much modification to work properly
    IG: 24_et
    Sold:
    RIP:
