Results 1 to 10 of 10
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Rust Spots Questions
    Hello Everyone,
    As I am getting close to solving my coolant gauge issue (hopefully), I'm moving down the TODO list on other items I need to address on my B6. A few months ago, I installed some updated S4 Door blades on my car. I saw the following on the bottom of the driver's side door:
    Pictures:
    As you can tell from the first picture, there is a circular rust spot forming. Thankfully those were the only rust spots on the whole car, the other 3 doors are fine. I bought the car originally from the Chicago area, and drove it down to TX back in 2009. So the winter weathers (aka salt) should no longer be an issue, but I wanted to ask a few questions since these spots were hiding behind my old USP door blades originally.......
    Questions:
    1. Should I be pro-active on this small rust spot?
    2. Will it still pose a threat in the future (ie spreading up to the main door area)?
    3. If I do need to stop it, what is the best way to treat it and prevent it from getting worse?
    Thanks in advance everyone! All your time and help is greatly appreciated! =)
    Thanks,
    Asif Ahmad
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    Never let rust "go", it just grows and grows and grows. It's hard to say when it will become a problem, but it will. So it's not and "if" but a "when". Dealing with it now will be much lest costly than when it starts to creep up the door from under the door blade. Ask yourself what the plans for your car are and how long you plan to keep it. That should determine your course of action. But seeing that you're in Texas, deal with it now when it's easy and cheap and you'll probably never have to deal with it again.
    Veteran Member Three Rings kifac's Avatar
    Mar 24 2014
    Mississauga
    Quote Originally Posted by claudiovagkraft View Post
    What about us living in Toronto LOL
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    My fix... Mask the good paint. Spot sand blast, then acid etch and prime or hit it with a quality self etching primer. Some color to hide the fix. I know it's hidden, I'm like that.
    Mar 10 2010
    Quote Originally Posted by kifac View Post
    We need to get on that shit ASAP!!! And follow up with rust proofing, and wash your car regularly in the winter
    Aug 26 2005
    There are rust converter products that change the rust, iron oxide, into Iron phosphate, not rust. One good spray on converter is loctite Extend, it converts rust into iron phosphate, a hard black material that won't continue to form rust, and forms a good base for primer and paint
    https://www.google.com/search?q=loct...w=1536&bih=764
    Extend is available as a spray on or as a water based brush on.
    Vorsprung durch Technik
    Feb 12 2004
    Austin, Texas
    Sir nosticator of Diagnostic:
    Thanks for the info! Have you used this or similar products in the past?
    Thanks,
    Asif
    Mar 28 2015
    POR15 is another coating and in my experience one of the best. The latex based converters (like the loctite) work reasonably well but must be covered over to last. Mechanically removing rust is the best solution. Often time, there will be layers that converters can not get to. I have even used converters after sand blasting. Watch for any breakthrough to the inside of the door skin, that will always come back unless fully prepped.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Another vote for POR-15. But get rid of as much rust as possible first. Keep in mind that any of these products prevent rust from forming where they are applied. If you allow a place where moisture can get in, it will rust again. In other words, if the rust is coming from the other side, covering up one side with POR-15 will not stop rust. The product needs to encapsulate (another rust converter product, btw!) the fix area or it will come back again.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Aug 26 2005
    Quote Originally Posted by A4orce84 View Post
    Thanks,
    Asif
    Yes I have used the Loctite Extend rust converter products, works really good. Extend changes the rust to iron phosphate completely to the base metal, not just a coating over the rust.
