99 A4 1.8T AEB, Ok so i looked around for several hours and found no vac leaks anywhere, and i found a page on the audiforum that explained the exact symptoms im experiencing, but it was never solved, more or less when i press the gas down it revs, the issue is the throttle lets go and makes the car go back to idle even if i open the throttle up while its going back to idle it does nothing, is there a way to fix this?
"OK 99 A4 1.8 when I give it gas, and hold it at any RPM it just revs and lets off to idle, revs and lets off to idle, like I'm doing it with the pedal , but I'm holding my foot steady So i scan the car and come up with only 2 codes under engine, 18010-Power Supply Terminal 30:Voltage Too Low-P1602-35-10. And then 17953, but won't tell you says Gotta pay for the upgraded version to find out what it is??? Can anyone tell me if it's got to do with the throttle situation.. Thanks" < From audi forum
except mine wont let me check codes for some reason ICM is not the issue, changed it with one i know is bad but let the car drive, Same issue but with a missfire, i tried to leave the key in the on position for a few minutes to let the throttle body align itself And nothing changed, how do i fix this issue?
https://www.facebook.com/Trololololo...9013833807661/
the last rev is when i put my foot to the floor, and i didnt take my foot up Yet the car returns to idle on its own
Is there a ghost in my car? :P Probably not but still annoying, I cant move the car because of this
