Results 1 to 15 of 15
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Leaving car parked for a long period of time question
    I currently have my 2010 A4 for sale in the classifieds section and it's been parked since April 14, with the exception of me taking it out for a spin around the block once a week. My question is, should I be driving more frequently in order to prevent anything bad from happening? Thanks.
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    If you don't plan on driving it for an extended period of time, I would put some fuel stabilizer in the tank, drive it around just to mix. You should be covered from the fuel breaking down into varnish.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by doowopaudi View Post
    No need, my car was resting 5 years, 4 weeks over 4 weeks, have not seen anything bad happend with this schedule, brakes needed to "drive in" a bit longer after 4 weeks:), all rest good!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    I have been deployed for 10 1/2 months. Only issue on my car after the first 6 months was my battery was bad. I say put a tender on it and you should be fine....
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    For any vehicle, over a long period of time (I'd say multiple months), you should prime the oil again. This will ensure bearings are not damaged as the oil, over time when the car is sitting, will eventually run off from the areas it was at. To do this, disconnect the fuel pump fuse and pull the spark plugs then turn the motor over several times. This drives the pump and you'll prime oil and basically achieve idle oil pressure. Reassemble and start it up.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Aug 15 2014
    If its up to 3 weeks, a battery tender is enough. If its a month or longer, i'd probably add some kind of fuel stabilizer especially if the car is stored outside. It its inside you can go a decent amount of time without anything additional.
    For Sale: Mini Part Out
    Aug 10 2011
    North Whittier
    It's garaged until sale. So what about driving it once a week? Is that also enough?
    Aug 15 2014
    Thats plenty.
    Jun 12 2013
    Yeah, that's plenty. Just ensure you get it up to operating temp for a bit.
    Build Thread
    Aug 10 2011
    North Whittier
    Thanks gentlemen.
    May 31 2004
    If possible, you should also try to lift the car so the weight is not resting on the tires - this will help you avoid flat spots. Additionally, if you're going to drive the car, you should drive long enough so the exhaust gases are hot enough to evaporate any moisture that can accumulate in the exhaust pipes.
    2011 2.0T P+ Sport 6MT, Integrated Engineering Stage II, STaSIS Exhaust, Spulen HFC, Roc-Euro SS, TDI FMIC, aFe Pro Dry Air Filter, E-Codes, 034 Transmission Mount, 19" AluFelgen SF-71, RS Grille, SunTek Carbon CXP 45, Shadowline Trim
    Jun 12 2013
    Quote Originally Posted by EuropaVin View Post
    Good point too.
    To my reply, if you drive around enough when the car is at operating temp, that will avoid that. Also, you want to avoid moisture buildup within the crankcase which is what causes a 'milk shake' effect where water vapor and oil mix. Driving around while under operating temp boils that water off and isn't an issue.
    Build Thread
    Sep 09 2010
    Destin, FL
    I go on many long period work trips and leave it in the garage for years now, some 6 month periods too. I've never had an issue what so ever.
    Nov 10 2014
    Apex, NC
    my mechanic had my car parked for 2 years only to change the spark plugs... car still ran so yeah its possible
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Oct 01 2014
    Pittsburgh/PA/Penn hills
    Quote Originally Posted by Shimmy View Post
    i agree
