First off you do not have access to a lift, I would not attempt the install. The overall install takes around a hour depending in your skill level. Initial review. Ever so slight NVH( noise, vibration,harshness ) at idle and in reverse. Shifting feels very smooth but firm and solid. I could not even even feel the car shift when driving under normal acceleration. The difference between stock and now is night and day. Stock is very soft to soak up the vibration . I could squeeze it with my fingers. The 034 is made of 65 Durometer and I was not able to squeeze it with my fingers. Overall it was a simple install. And well worth the money, if you don't mind a slight vibration at idle which isn't that noticeable . I do have a slight clicking sound when I turn left of right. Which may be over tightened bolts. My transmission is a 6spd tiptronic. ⭐⭐⭐⭐⭐
