Results 1 to 29 of 29
    Jan 12 2016
    Los Angeles, California
    Looking to reduce body roll, but I have some limitations
    I'd like reduce the body roll on my stock Mag Ride S3, but I don't want to:
    Create a harsh ride
    Lower it to the point where I cannot see the top of the tire from a side view
    Do anything that isn't 'easily' reversable
    This is my daily driver, and I live in Los Angeles, which is filled with some decievingly rough roads, and I'd like to be able to switch to comfort suspension and get the same softer feeling ride when needed.
    I like the look of a lowered car, but I personally don't like it when the top of the tire dissapears under the wheel well.
    Thank you for your suggestions!
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    Senior Member Two Rings FabianS's Avatar
    Jan 29 2015
    Calgary AB
    034 rear sway bar...
    Mar 11 2012
    Audi A5
    Ventura, CA
    Swaybars + endlinks
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    Eurocode's rear chassis brace takes about 10 minutes to install/remove and it very noticeably reduced the bit of body roll that's present in hard cornerning with the stock mag ride suspension. Combined with the 034 rear sub frame inserts it's all I need for an occasional track car while still keeping things civil enough for a date night. A rear sway bar is not a bad idea either, so far I've not found it necessary after the other mods.
    The car's stock suspension geometry benefits more from additional rear structural rigidity more than anything else. It helps to induce the ability for power-on oversteer (with the extra power from a tune) as well as reduce the tendancy for understeer from the factory. The front is about as stiff as it needs to be from the factory, additional rigidity up front will reduce your ability for power-on oversteer and have a neglible effect on understeer.
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    Jan 12 2016
    Thank you so much for responses.
    I was leaning towards a sway bar, but I assumed you guys would recommend lowering springs.
    I like the idea of adding bracing, sub frame inserts and the sway bar. I'm not looking to make this thing an over steering track monster, so I think the above additions will be perfect.
    I'll add the bracing and sub frame inserts first, and see if I still need the sway bar.
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    KevinM - Please let us know your thoughts after you do the install of the sub-frame inserts and bracing. I was kind of leaning towards just the rear sway bar and end links. I will wait to see what your thoughts are.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Established Member Two Rings photocycler's Avatar
    Jun 07 2015
    United States
    As a phased approach, if I install the subframe inserts with lowering springs (emmanuele) will I feel a difference or is the chassis brace a better first mod before the inserts? Thinking while I have the springs installed it's probably easier/cheaper to have them install the inserts as well.
    Jan 12 2016
    Is this the rear chassis brace you are refering to: http://www.ecodetuning.com/store/aud...ml#prettyPhoto ?
    I was imagining something mounted to the chassis on the underbody, does this really provide a significant difference in stiffness?
    Oct 30 2012
    Arizona
    The XBQ and UBQ make a significant impact to chassis stiffness. Mine were installed by the previous owner, so I can't compare from stock, but it is worth it IMHO....debating on getting the rear sway bar from 034, but like HURRAYFIVE said....it might not be necessary with the XBQ and UBQ installed.
    The subframe inserts are more for "drivetrain shift/deflection reduction" not body roll. I installed those as well. Unless you are Stage 1 or higher, they are not needed at the moment.
    Jul 21 2013
    Remote
    Quote Originally Posted by KevinM. View Post
    Yup, that's the one. It does a great job of reducing body roll in hard cornering on an otherwise stock car; you preload the strut rod ends on either side during installation and the car deflects load across the brace in hard cornering. I mentioned this part specifically for body roll as that seemed your top concern (as well as ease of install/removal), not overall chassis rigidity. There's a sweeping turn near my house in a generally empty area that is fun to dive into from time to time. When the car was stock, body roll was definitely apparent at the limit. After installing the brace, I can't get the car to induce body roll on the same turn. Spirited driving up a twisty canyon road feels more planted and roll is nowhere to be found. Worth it for the price & ease of installation IMO.
    As A20V mentioned, the XBQ and UBQ mentioned seem to do a great job of increasing overall chassis rigidity, lots of folks here have good things to say about them. The combo that I have between the rear brace, inserts, and the BFI mounts has the car as raw as I'd like it to be for now.
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    Maybe I'm wrong, but the general idea behind chassis braces is to reduce chassis twist/flex, not body roll. Sway bars, on the other hand, are specifically designed to reduce body roll. However, the change in "feel" while driving may end up being quite similar I guess. You probably can't go wrong with either, but I would definitely do one thing at a time so you can see how things change.
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Jul 21 2013
    Remote
    Quote Originally Posted by JohnnyUtah787 View Post
    No, you're right that a beefier sway bar will generally always be more resistant to body roll than a less-beefy (beef-less?) sway bar. If I remember from my suspension dynamics class, oh, all of...dear lord almost 12 years ago now...I think a sway bar increases in stiffness by diameter (d) to the power of 4? d^4 Which is why even a relatively small increase in diameter (say from 21mm to 24mm) results in a bar nearly twice as rigid. (21^4 vs 24^4)
    On this platform in particular, in stock form, it seems that rear chassis flex and rear chassis rigidity are large contributors to the feeling of body roll under hard cornering, based on the car's tendency to understeer at the limit, and just from driving one at the limit. This is why I mentioned the rear chassis brace did a solid job of reducing the body roll, because it targets those area's specifically. Before and after, just the rear chassis brace, was a very noticeable reduction in body roll under hard cornering. It also improved the tendency for understeer, to the point that power-on oversteer is very possible (and fun) with the extra power from a tune.
    That's not to say it wouldn't be even better w/ a rear sway bar, in all likely hood a rear sway bar by itself is probably more effective than the rear chassis brace by itself, it's just not the route I went. If the car ever spends more time dedicated to the track, it's never too late to add one :)
    I am also with a stock mag ride and i just wanted to reduced body roll... went with the super pro 24mm rear sway bar and no more body roll, car feels planted and solid during hard cornering, which it just what I wanted.
    Sent from my SM-N910T using Tapatalk
    Dec 06 2015
    Columbia, South Carolina
    dont do coils.. just H&R supersport springs, then Eurocode front and rear sway bars (both for $340) plus Eurocode rear chassis brace.
    Then also Unibrace XBQ and UBQ.
    Now you are ready for track days.
    Oct 30 2012
    Arizona
    There are some of these items in the classified section.
    http://www.audizine.com/forum/showth...ings-A3-S3-MQB
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    Create a harsh ride
    Seeing that you are in LA, we have a number of customers in your area with springs and sway bar combinations. We are also right in Anaheim, so you are welcome to come check out our shop car to see if the parts on it will suit your criteria.
    Jan 12 2016
    I often fold my seats to fit large items in my car, so the XBQ and Eurocode strut won't work for me.
    What are your thoughts on just the UBQ and sway bar (and maybe the 034 subframe inserts)? I like the 034 sway bar because I can set it to the 134% setting for the road, then when I head to the track I can dial it up to the 152% setting.
    Oct 30 2012
    Arizona
    The XBQ is held in by 6 bolts and can easily be removed if need be for transporting larger items.
    The UBQ is definitely an upgrade and will tie the chassis together. The 034 insert are ONLY to firm up the drivetrain parts and reduce the slop in the OEM bushings.
    So if you can swing it...do the UBQ and the 034 rear sway bar together if the (back seat) XBQ is NOT an option...if the XBQ and UBQ are an option to that.
    Jan 12 2016
    Alright, about to place my order for the UBQ and 034 Sway Bar. I will probably install them at the same time, instead of the planned phased approach.
    I am not sure if I need the 034 subframe inserts, unless somebody can convince me that they will make a big difference in the feel of the car. It seems like they just make the car feel more "raw," which isn't a bad thing, I'm just not sure whether they are worth the money and effort to install.
    -Also, if my car is not lowered, do I NEED new end links? I understand the benefit, but do I really need them with my current setup?
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    I would highly recommend the 034 subframe inserts. I wouldn't say it's more "raw", I would say the car feels more stable and control in the rear. It's a 10 minutes once you jack up the car. Check out this thread for more information.
    http://www.audizine.com/forum/showth...unt-Insert-Kit
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by fasts3 View Post
    How can you say to not do coils, but instead recommend Springs with stock shocks for track days?
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Oct 03 2015
    Illinois
    Quote Originally Posted by saxon View Post
    Maybe because his car has mag ride?
    Jan 12 2016
    I got the UBQ and the 034 Sway bar and installed them this past Sunday at home.
    My dad used to be a mechanic, and likes to work on his cars himself, so we have a lube bay in our garage. The installation of the UBQ was as easy as it gets, nothing special there, just a few nuts and bolts.
    We thought we'd be able to remove/ install the swaybar without having to lift the car, but we realized that it would be too difficult. With the car over the lube bay, we jacked it up and put it on jackstands so we could access the sway bar endlinks more easily. The hardest part of the sway bar intallation was the removal/ installation of the sway bar from/ onto the end links. Hard, not impossible by any means. I had originally planned to get the sway bar set up on the softer of the two settings, 37% stiffer than stock, and then go to the 52% setting whenever I go to the track. Because of how time consuming the process of jacking up the car and disconnecting the sway bar from the end links would be, I decided to just go with the 52% setting. The entire process of the removal of the old sway bar, and the installation of the new one took a little over an hour, including the time it took the get the car jacked up.
    The results:
    In my head I had two possible outcomes: Pretty noticeable difference with a pretty significance reduction in body roll; or no real change
    I was very happy, I could totally feel a difference in the way the car behaved. I haven't had a chance to drive through any mountain or especially fun roads, but I am very happy with what I've felt. There is without a doubt less body roll, but more than that, the car feels more locked in. I noticed a little bit more of a tendancy to oversteer in areas when before the modification, it wouldn't. Overall I am really happy with these upgrades, they did everything I hoped they would.
    Mar 15 2016
    Denver/CO
    If you want to reduce body roll and not change the harshness of the car, just get a bigger rear sway bar. Hopefully if lowering springs are made right, will also be stiffer, but I don't think that is what you are looking for. Also a sway bar will be much easier to install and take out in the future to go back to stock.
    Jan 12 2016
    Yup, changing the sway bar and adding some bracing really improved the performance without compromising ride quality.
    Thank you to everybody who suggested these upgrades
    Jan 29 2015
    Calgary AB
    How do you like the 034 sway bar? Considering one myself to go with my Emmanuel Design lowering springs and 034 Rear inserts. Do you have it on the lower or higher setting?
    Jan 12 2016
    Quote Originally Posted by FabianS View Post
    I was very, very impressed with the 034 sway bar, which I have on its stiffest setting. I might do the 034 subframe mounts soon, but I have not, and have no plans to lower my car.
    If your goal is to simply improve handling without sacrificing some daily driving capability, then if suggest getting a sway bar, bracing and if you'd like, subframe mounts.
    May 21 2015
    Pacific NW
    I've got the 034 sway, end links and subframe mounts. Currently 1/4 of the way through installing the ED springs. I'll let you know how it all feels when I get the springs done. All of the 034 parts can be installed in an afternoon.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2008 BMW 535xi (sold)
    2006 A3 2.0T (sold)
    Jun 01 2016
    Toronto, Ontario, Canada
    Newbie here from Toronto Canada. Great thread. I am on the same journey as KevinM, but starting with A3 S-Line Convertible. S3 and RS3 versions are not sold here.
    I am curious about differences between 034 sway bar (22mm) and H&R (25mm).
    I may also have a cheap DIY mod for your airbox. Put in an H&R replacement filter and take out the piece of plastic under the filter - looks like useless restriction to me. Feels and sounds better. I am also considering opening up the fresh air inlet on the left side to provide direct flow/ram to the airbox; currently the airflow comes from the right side while the airbox is on the left. I jerry rigged something by taking out the inlet box and cutting up a super slider carpet (aka tobogan - Canadian thing) to bring flow directly to the airbox. It looks terrrible, but sound was better and acceleration felt better once moving. I think some drainage holes would be needed in the airbox to deal with potential water entrainment. Also, I think opening up the inlet box on the left side is probably a more elegant solution. The problem is the engine compartment is so damn hot, and the airbox so far from the turbo inlet, that the engine heat overcomes anything you do here. Thoughts?
