Results 1 to 14 of 14
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Unhappy 2014 Audi S4 B8.5 - Mustang AWD Dyno Run - Black Exhaust Smoke
    So I put my car up on the Dyno today and saw some strange black smoke coming out of exhaust at high RPM's. The tech's at the shop were suspecting knocking/pre-ignition. But the condition seemed to improve every run, wondering what you guys think might be causing this?
    1st run - Lot of black smoke puffs (see video)
    2nd run - 1 or 2 puffs of black smoke, followed by 2-3 specks of tiny glowing embers (I do have Cats, so not sure wtf that was)
    3rd run - No black smoke at all until the tech let off in the end around 7K rpm.
    Car: 2014 Audi S4 B8.5 ~23K mileage
    Apr Stage 2 - 93 map
    AWE touring exhaust with Res. DP
    Injen CAI
    I see no fault codes etc., maybe the tune is running rich, but i'm not sure since it seemed like it was getting better every run.
    Dyno Results:
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Mar 21 2015
    No logs during the run?
    Veteran Member Three Rings rubicant5x's Avatar
    Apr 05 2016
    2001 Audi S4
    Cleveland, OH
    Your dyno results link is busted
    Matt
    2018 Audi RS3
    2001 Audi S4
    Jul 24 2015
    Unfortunately no, since the condition improved quite a bit every pull, I didn't bother. I now wish I had.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Burning off that carbon!
    Nov 20 2014
    New York
    Quote Originally Posted by justr0 View Post
    Starting Line NJ? I was there 2-3 weeks ago with my 2012 B8 GIAC St 2 with intake. Mine did the same thing at high rpms, smoke and sparks.
    I put down 381whp and 345 wtq on that same dyno.
    Jul 24 2015
    Yeap, I think you're the one John was telling me about then. He was surprised to see my numbers, they were a bit on the low end for a Stg2 but I think you ran a 93/e85 mix. I saw your dyno run on their Instagram :)
    Quote Originally Posted by sonic32 View Post
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    That is an ugly 4k map.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    I've never dynoed an S4, but many other cars and black smoke up top usually meant it was getting a bit rich up top. What was the AFR? Computer could have been adding fuel to combat detonation. Any knock retard?
    Nov 20 2014
    New York
    Quote Originally Posted by KnewJack View Post
    I had timing pull up too due to the e85/93 mix I was running. Car could've put down more power.
    Nov 20 2014
    New York
    Yeah but I pulled logs on my 4th run on the dyno and I had so much timing retard that it bumped me down to 93 octane timing. I fucked up the mix that day and got lean codes right before getting on the dyno. I'm gonna go back with a dual pulley and better fuel.
    Apr 14 2016
    Austin Texas
    Black is usually fuel, and probably a bit of carbon
    Sent from my Venue 8 7840 using Tapatalk
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    It's unburned hydrocarbons, or "particulates". It improved with later runs because the cats were hot and doing their job.
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    My car does smoke too but I have no cats and its a tad rich.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
