Results 1 to 16 of 16
    Active Member Two Rings AUDI_licious's Avatar
    May 14 2016
    Grand Rapids, MI
    Is there a problem here or am I just a lousy noob!??!
    Noon question disregard!
    Mar 08 2015
    Alaska
    How about when you're driving? Free reving doesn't really do much for boost testing.
    Sent from my SM-G925I using Tapatalk
    May 14 2016
    Grand Rapids, MI
    Quote Originally Posted by 907DAVE View Post
    It does about the same it'll boot up to 8psi briefly then drop to 0 pretty much no boost nor vacuum.
    Sent from my SM-N920V using Tapatalk
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    You don't boost when revving your engine...
    Noob.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by adam044 View Post
    Noob.
    +1 lol
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    I want in on this
    Noob
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Big nooooob!
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Established Member Two Rings Forge04's Avatar
    Mar 20 2016
    2007 Audi A4 2.0T FWD 2009 Chevrolet Avalanche LTZ PAST: 1979 IH Scout II 1971 IH Scout II
    Middleton, ID
    I thought I had a handle on mechanics... but I'm not that savvy on thungs I haven't learned about, like turbos.
    So why wouldn't you have boost while revving? Exhaust is still coming from the engine more with the higher RPM, spooling up the turbo, in turn forcing air to the intake, hence boost right?
    I assume I'm missing some valve. The blowoff is normally for when the turbo goes from high RPM to low. I understand our DV does something along those lines.
    Mar 08 2015
    Alaska
    Put simply, a turbo needs heat to create boost. It's the rapid expansion of gasses as they are heated during the combustion process that provides this. A quick free rev cannot do this.
    Get us a video of a 3rd gear pull and maybe we can get you headed in the right direction.
    Oct 01 2014
    Audi Q5
    chicago,il
    Isn't using torque app not accurate reading boost?
    Sent from my SM-G900T using Tapatalk
    Mar 20 2016
    Middleton, ID
    Oh we're talking about a quick gun of the throttle? No it takes time to spool up yeah?
    Apr 24 2016
    California
    Not time, but work done. In physics, work is the product of Force times distance (F • d), meaning in order for work to be done, a mass needs to accelerated by a force a certain distance. In thermodynamics, there's a law stating that the change in heat of a system is equal to the work done on the system.
    These are pretty simplified principles but in short, if no work is done then no heat is generated. Obviously exhaust is still hot when idling/revving, because *some* work is being done accelerating the reciprocating assembly and obviously an explosion is going to make heat. However, the total heat energy in your exhaust system while accelerating the car is much higher than the total heat energy when idling or revving, and it's this heat expanding the exhaust gasses that drives the turbine, not simply the airflow from the exhaust. This is why your car doesn't boost while revving.
    That being said, a small amount of boost can be made depending on the turbo/engine size etc. My old mk4 GTI would blow off a bit while revving the motor, but the blowoff was a faint whoosh instead of the sharp screech it made under full boost.
    As for blowoff valves vs. diverter valves, google it or search the forums, there's many many explanations of the difference. You don't want a blowoff valve for VAG cars, recirculation/diverter valves only.
    Mar 20 2016
    Middleton, ID
    Gotcha. That was nicely put in just hair more than layman's terms :)
    Oct 20 2008
    Denver
    i think the reason OP made this thread is because he posted this over in the B8 S4 section.
    Mar 21 2015
    ^ Haha, I replied to that thread too. Whats he thinking?
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by RakkCity View Post
    Yes, but we are talking about power, which has a time component. Therefore spool time will effect power.
    My respray thread
