Results 1 to 23 of 23
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Widow Maker Jack Strikes Again
    Pot hole takes out tire. Rgr that. No biggie - swap to spare and switch to my all-season shod rotor replicas until the local shop opens on Monday. Break out the widow maker after loosening bolts and carefully jack car up. Parking brake is set. Remove first bolt and turn to put it down just in time to hear the jack collapse. Lower trim where the jack mounts has cracked. Bunch of small pieces that apparently hold the fender in place are broken. I'm guessing $1500 easily? Already soaked by rain, I wimped out and called roadside assistance.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    Dude... Watch out for black cats.
    Sep 10 2015
    VA
    This jack in these cars is so damn dangerous it's not even funny. I took mine out the car so there's no way to even use it. I have nitro fill so I will call them if I need roadside.
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    It is almost an insult to include a jack that unusable in a car. Sorry to hear about your incident, but glad you are ok. Reminder to just call roadside when it is needed.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    Wow glad your ok. It's probably also good you weren't in the middle of swapping the wheel. Had this dropped without a wheel on you'd likely have a much more expensive repair. Also, I had no idea these jacks were this bad. I might look into a replacement option.
    Current:
    '13 S7 (Innovation, B&O, LED's, AWE Exhaust, RS-Grille) -- '12 FJ Cruiser (Heavily modded) -- '14 QX80
    Gone but not forgotten:
    2014 Porsche Carrera S -- 2014 Toyota 4Runner -- 2002 Acura TL-S (My first 'luxury' car)
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    If the jack collapsed, Audi should pick up the tab on the repair and cover any diminished value to the car as a result.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Veteran Member Three Rings redrocker55's Avatar
    Feb 21 2010
    St Louis, MO (USA)
    Just an FYI for anyone who needs to use the OEM jack...it's a smart idea to loosen the lug bolts before you jack the car up. This way you have much less chance of rocking the car on that small jack and risking a fall. I had this happen to me on a Expedition I used to own. It's scary when that car comes crashing down.
    2016 S6 Prestige, Misano Red Pearl, Driver Assist, B and O, Sport Pkg, Carbon Atlas, Black Headliner,
    Alu Kreuz, 034 Motor Sport DSG Insert, RS7 Intake Box, APR Stage 1 w/ Dongle
    Sold 2010 S4 Brilliant Red DSG with Prestige Pkg
    Sold 2008 VW GTI DSG
    Veteran Member Three Rings AudiA6A5's Avatar
    Dec 06 2013
    RI
    screw that POS jack!....AAA or road side assistance every time, that's why we have it.....glad your wife isn't a widow!
    C7 A6 Prestige - Phantom - Sport - LED - 35% Llumar - Eibach Pro-Kit - EC S+Ls - 034 TM - RS Grill - APR Stg II
    Cayman S - Rhodium Silver - PDK - Sport Chrono| B8 A5 Cabrio - Meteor Grey (for sale) | Pathfinder - Cayenne Red
    past audis: B5 S4 | B7 A4 S-line
    May 08 2004
    NoVA
    Lug bolts were completely loosened. Failure occurred while I was pulling the bolts out with my hand. Just glad it didn't happen while the wheel was off.
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Tbh I am glad on this thread since it shows how shitty the jack is and I am not the only one who got fucked. I hit a pothole, tire blew out on an embanked road. I was stranded on a curve. Already knew it wont be a good idea to use the car's jack so called up Audi roadside. Mother****** contractor took up the job and then called them about 90mins later to cancel saying he didnt have the right equipment. Wtf? Same stuff happened with Michelin's roadside assistance- same contractor. After about 2hrs out on the road, pulled the jack out, yanked the car up, only for the jack to roll a bit and end up sliding inside the rocker panel. Luckily the rocker panel didnt crack. Took about 2 more tries and a rock to stabilize it. I hate that jack with a burning heart.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Feb 26 2010
    Los Angeles, CA, USA
    Ouch...that was so dangerous.
    I always call AAA and have them change the tire for me if I ever get a flat. Too much trouble and dangerous to change a tire on a busy Frwy in Los Angeles.
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Quote Originally Posted by redrocker55 View Post
    That is the proper procedure for any jack.
    Dec 18 2014
    DMV
    Quote Originally Posted by chucky0731 View Post
    +1, agreed.
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    May 31 2014
    Alabama
    Good info. I assume this car jack is the same used on the S4?
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    May 08 2004
    NoVA
    VW has been shipping that jack since at least my 1998 Passat. Estimated damage is coming in surprisingly low. Apparently the side skirt and associated small parts come in at about $450 unpainted. All together, I might walk out of this for about $2k total, including the replacement Conti DW. I took a closer look and it appears the jack was so well seated in the factory pocket, that once the car started coming down the jack's angle eventually reached a point where it wouldn't give any more. When that happened, the side skirt gave. The jack "pocket" completely ripped out and the side skirt snapped near that area, as did a couple of clips under there. I'm hoping the front fender just needs to be re-secured to the side skirt once its been replaced. Going to go ahead and have my front and rear bumpers repainted as well. Someone parked on my rear bumper last year, and my front bumper is littered with rock chips. Debating now whether to have the entire wheel refinished or just touch up the small area that looks to have had some paint chipped away. Of course, the county filled the potholes on that road two days later.
    Established Member Two Rings ayoo456's Avatar
    Apr 23 2014
    queens ny
    I hate that jack as well. Dropped on me the second day I had the car
    Galaxy S7
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    Since you're having your bumper repainted you should consider a clear bra after the cure time. Glad that the damage is coming in relatively low. Those widow makers suck.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    May 08 2004
    NoVA
    Definitely. Had planned to do that as soon as a bought the car but the paint was jacked up from jump street!
    Quote Originally Posted by RRF985 View Post
    Mar 04 2015
    Houston, TX
    Details on your brake setup, it looks so nice! Did you powder coat your calipers?
    Mar 29 2014
    Hampshire, UK
    Ive been driving Audis and using Audi jacks for the best part of 15 years and never had one collapse on me when using it for intended purpose (Changing out a flat tire)
    What are you guys doing to them??
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Three Rings MyXbfS4's Avatar
    Jan 18 2015
    2000 B5 S4 Light Silver w/ Onyx (no sunroof), 2009 A4 Black
    Los Angeles, California
    So this happened right now while my bf was changing his tire. the jack fell and smashed his arm. even crazier the fire dept attempted to put the tire back on (see red arrow) and the jack fell again, luckily not injuring anyone this time.
    ....look at the the fire man's expression if you zoom in. even he's like wtf lol
    2002 Laser Red B5 S4 Sedan
    2011 Ibis White B8S5 4.2V8 Coupe
    2000 Silver B5S4 6mt Sedan(no sunroof)- SOLD
    2001.5 Silver B5S4 6mt Sedan stg3- RIP
    2000 Santorin B5S4 Tip Sedan- RIP
    Jan 27 2016
    Denver
    Jeesh. Is his arm going to be ok? I guess it's good his arm was the only thing smashed.
    Current:
    Jan 18 2015
    Quote Originally Posted by jfeger View Post
    yeah they put a splint on it. I'm sure its going to get pretty swollen and he says its painful.
    I know I'm relieved it wasn't worse.
