Results 1 to 11 of 11
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Sheered blot head ideas
    Hey guys and gals,
    I was doing my sway bar end links last weekend, and when taking the lower bolt out of the passenger side, the head sheered off. I've tried easy outs, acetelyne welding torches for thermal shock, and trying to drill the bolt out, but it doesn't want to budge. Any ideas?
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Jul 17 2011
    Sin City, USA
    Sound like you tried everything. Have you tried a reversing bit? It is normally for stripped screws.
    '09 C6.5 A6
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    do you have a welder
    you can put a nut over the end and weld it to the bolt
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    +1 for the welding idea ^^^
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Not much left to weld too....
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    You're gonna have to go with the welding idea. Or maybe just go for a sway bar upgrade?
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Quote Originally Posted by Nizmo View Post
    Yeah that was the next step. There isn't much to grab onto like you said though..
    - - - Updated - - -
    Could a machine shop drill out the old bolt and then rethread or helicoil the holes?
    2005 BMW K1200S
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Quote Originally Posted by skylinrcr01 View Post
    - - - Updated - - -
    That's doable.
    Would be best if it could be pulled off the car first. In that case, you could drill out the core and shove a giant bolt out bit in there.
    Sent from my SM-N910T using Tapatalk
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Oct 09 2015
    Boston
    This is prob in the area of a 30mm bolt length, make sure you get in there all the way with the drill, step up size until you catch the bolt and it starts to spin out.
    Don't just use 1 single drill bit, step up sizing, but be careful not to cut the threads of the sway bar.
    If you do get the threads its not the end of the world. You would then need to Tap a new thread in the sway bar, (Tap and Die) and new bolt for the sway bar end.
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    This worked. 10 bucks for a tap kit was way cheaper than the 100 for a new sway bar, thanks all! My clicking went away when I turn too. :)
    Oct 09 2015
    Boston
    Sweet man!
