From the Factory Service Manual:
All Wheel Drive Control Module (J492), Additional Work after Replacing
¤ Only perform the additional work only if the All Wheel Drive Control Module (J492) was replaced.
•Connect the Vehicle Diagnostic Tester and switch on the ignition.
•On the Vehicle Diagnostic Tester select the function 22 - Control Module, Replacing under Guided Functions in the directory 22 - AWD electronics.
¤ Follow the instructions given by the Vehicle Diagnostic Tester exactly.
"Adapt" the installed rear final drive to the All Wheel Drive Control Module (J492) with the Vehicle Diagnostic Tester.
¤ A system check will take place when the 22 - Control Module, Replacing function is complete. If malfunctions appear, then use "Guided Fault Finding" to correct them.
Account
